Author Topic: $20 smoked plexi glass?? look here  (Read 2713 times)
NiN^_^NiN
« on: January 24, 2004, 07:42:15 am »
Hey thought id share with u guys a cheap way to get smokes plexi glass effect :)
I brought this do it yourself limo tinting from a auto shop for $20 and it didnt really work for me as i couldnt get it on proper without taking my windows out which screwed it up cause it scracted the ---steaming pile of meadow muffin--- out of it when i put it back anyway.
I wanted to hide certin stickytape from the blackcardboard i had on my monitor and i remembered the tint
i sprayed some water on the glass then laying the tint over it and rub the air bubbles out and it looked great :)
i trimed the edges with a stanely knife and when i put it on the screen area was BLACK
i couldnt see anything then i thought hmmm its limo tint can i see the screen so i fired up the pc and the screen and BAM it look great nothing but the screen u could see and it only cost $20 and 2mins max :)
its a great cheap simple way i think
you might be able to put it on the inside of the glass if your woried about it getting scratched
i can see throught it both sides the same i guess 1 side is just the sticky side when water drops are applyed.
but yeah cheap simple and oh so cool so what do u think?
its big enough to put on a cocktail cab and the roll covers all 4 doors of a car with leftovers :)
i think 4 cocktails could be done and have a very short bit left for a plexi control panel not that u would use it for that :)
so what do u guys think?
MonitorGuru
Re:$20 smoked plexi glass?? look here
« Reply #1 on: January 24, 2004, 11:44:53 am »
You can get 85% or 70% (I think those are the numbers) grey tint at Wal-Mart for ~$10 a roll that will do multiple machines.
It works great.  Just be sure to add a touch of soap in the water spray bottle first to help get out all the bubble and let you smooth it out easier/shift it if you dont get it right the first time.
NiN^_^NiN
« Reply #2 on: January 24, 2004, 08:53:59 pm »
Thanks for the tip :)
i think its alot better than getting smoked plexi glass cause u can try out different % of shade
also im in australia and it cost $20 down here so its even better in usa  ;D
