Author Topic: Sega Naomi Nanao 29 and Multiboard Video Issue  (Read 4468 times)
anthony.cerantonio
  • Last login:February 09, 2017, 07:21:01 am
« on: January 31, 2017, 05:56:08 am »
Hi all!
First post here! Hope you're all well! Just brought my first cab in a few years and having issues.
It's a Sega Naomi Universal Cab - Monitor is Nanao, supposedly tri-sync chassis. Removed Naomi system.
I purchased a Pandoras Box knockoff (Heroes of the storm 2) output is both JAMMA and VGA.
When I connect the board to VGA cable for the monitor, all I get is static (see image)
I can connect my laptop to VGA cable and get picture (see image)
Would anybody know what this issue would be? I do not have any other JAMMA boards to test with.
Would one of those VGA video converters help? This is driving me crazy, any help would be very much appreciated :)
Thanking you :)
grantspain
Re: Sega Naomi Nanao 29 and Multiboard Video Issue
« Reply #1 on: January 31, 2017, 08:58:45 am »
naomi cabs with nanao used ms2932 and ms2934 chassis,both are fixed 31khz
the tri sync nanao are ms2930,2931 and 2933
how does the multigame know what res to output,is it dil switches?
grantspain
« Reply #2 on: January 31, 2017, 10:20:15 am »
try a different vga cable
anthony.cerantonio
« Reply #3 on: January 31, 2017, 02:01:06 pm »
So the chassis has no place to connect the rgb from Jamma harness (weird I know) - only vga is connected.
I will grab a new vga cable today and see if this helps
Thanks for your quick replies! Much appreciated
Any other issues you think could be causing? Do you thing one of those cga > vga or vga > cga converter boards / scalers may help?
grantspain
« Reply #4 on: January 31, 2017, 03:24:06 pm »
could be an odd sync signal from the game board or its not actually outputting 31khz
anthony.cerantonio
« Reply #5 on: January 31, 2017, 04:45:59 pm »
If this was the case, what could be used to scale the signal down to 31 /25 or even 15khz using the vga cable?
grantspain
« Reply #6 on: January 31, 2017, 04:55:02 pm »
something like a gbs8200
anthony.cerantonio
« Reply #7 on: January 31, 2017, 09:09:35 pm »
Thanks I just ordered one - annoying how the chassis doesn't take rgb connection from the Jamma board !
So here's hoping that the vga in to vga out works!
In the meantime should I get a pc and test with Mame?
grantspain
« Reply #8 on: February 01, 2017, 05:00:35 am »
yes but do not output more than 31khz to these monitors as it can short the HOT
anthony.cerantonio
« Reply #9 on: February 02, 2017, 11:21:11 pm »
connected a laptop running 640 x 480 - and with some great help form the team at aussie arcade it works :) see pic
assuming that the Pandoras Box 4 gameboard puts out possibly 800 x 600 VGA?
Maybe I'll use that board for another project - now to find a decent desktop with XP for MAME :) Ordered an IPAC 2 this morning!
