Author Topic: USB ports  (Read 2280 times)
thedarkknight228
  • Last login:March 17, 2017, 05:55:22 am
USB ports
« on: January 24, 2017, 06:38:08 am »
Hi,
Just a quick question.
If I wanted to add USB ports to the outside of my cabinet so extra players can play games do I just need to buy the USB port and plug it into the USB slot in the raspberry pi?
Then players can plug in controller on the outside of the cabinet?
StefanBurger
  • Last login:October 28, 2025, 10:44:03 pm
Re: USB ports
« Reply #1 on: January 24, 2017, 07:03:12 pm »
https://www.amazon.de/gp/aw/d/B01CEKYSYC/ref=mp_s_a_1_12?__mk_de_DE=ÅMÅZÕÑ&qid=1485302454&sr=8-12&pi=AC_SX236_SY340_QL65&keywords=usb+durchführung+buchse
Plus usb cable and evtl usb hub
lisowskikevin
  • Last login:April 02, 2024, 07:49:55 pm
  • If you take shortcuts, you get cut short.
Re: USB ports
« Reply #2 on: January 24, 2017, 07:46:49 pm »
thedarkknight228
Re: USB ports
« Reply #3 on: January 25, 2017, 09:31:52 am »
If I plug USB hub into the raspberry pi will it drain much more power?
Will my raspberry pi run slower?
JDFan
Re: USB ports
« Reply #4 on: January 25, 2017, 10:03:20 am »
Depends on what you plug into the hub and whether or not the Hub is powered or passive (ie. does it also plug into an AC source for it's own power.
A hub by itself will only use a very little amount of power but if you plug in several usb devices into that hub that use the usb port to get their power then the usage starts to add up !
A hub will not make any change to how the pi runs as far as speed goes but if you place too many devices that are all using power and it gets to a point that there is not enough power available for all of them the pi may begin to shut down randomly as it lacks the power to run. (which is why having a good ac outlet device becomes more important as you add more devices that get their power from the USB bus)
