Author Topic: RetroPie Daphne (DL) and 8BitDo NES Pro 30 controller set up  (Read 4419 times)
mindbinge
  • Last login:January 23, 2017, 10:23:39 pm
« on: January 22, 2017, 11:16:21 am »
Anyone else have an 8BitDo NES Pro 30 controller and set it up for Dragon's Lair?
I've got it mapped out to where the D pad buttons work correctly, the B button is the sword, the select and start add the coins and start the game...but no luck in getting the select+start buttons to exit the game?
Anyone happen to know what number I'd assign for that in the /opt/retropie/configs/daphne and open the dapinput.ini file
or if you have this same controller working, post up your dapinput.ini file?
mahuti
Re: RetroPie Daphne (DL) and 8BitDo NES Pro 30 controller set up
« Reply #1 on: January 23, 2017, 11:01:40 am »
I can't help you specifically with dapinput.ini file, however I have it working with a similar NES controller.
Using the default Retropie image with Emulationstation to configure the inputs for Retroarch worked out of the box for Daphne. I'm sure this doesn't help you much, but I thought it might be useful to at least mention.
