Guys this was thought to be a long post and ideed it was
... unfortunatelly, after writing for half an hour, I got logged out and I lost everything
Let's try to start from scratch, but I'm not sure I'll remember everything.
First of all: we made it
!!! ... thanks to RataPlan kind assistance I got what I was doing wrong
In few words, the resolution I put inside CRU, was my monitor native one (1600x1024@60Hz) and Windows/CRU was not picking it up as a real
custom one and, as such, it was not adding the EDID_OVERRIDE key inside the registry.
Adding a more 'exotic' refresh rate (59.59Hz) made the trick
After configuring everything as Rataplan suggested, I prepared myself to enter the truth test: running a game with a non 60Hz refresh !
I used Ghost 'n Goblins as my benchmark since this was one of the main reasons for embarking into this 'refresh rate' adventure !
Unfortunatelly results were good but not what I was expecting (slightly better that running @60Hz though)
What I mean with poor results ?
I mean that the scrolling is not 'smooth' but a bit 'jerky' ... not excessively but still something noticeable
Now how can I know there isn't something wrong in my procedure and this is the reason for the disappointing results ?
Just because many, many games are now really close to perfection as never before, no matter how hard I played with the MAME settings
... here I must thank really much RataPlan for the hard work and I won't quit stressing how this guy didn't (so far) receive the attention and
gratitude he deserves
How well now Neo-Geo games run, how smooth are Mortal Kombat side scrolling portraits (the ones of the characters when you insert coin)
So what about GnG
To be honest I got few ideas about it which I'd like to share with you; according to my opinion there could be three reasons:
- my LCD doesn't like/pick up the 59.59Hz refresh rate
- MAME GnG driver is not optimized (other games behave similarly while others are simply perfect)
- the original arcade was exclty the same but I never noticed it (I was 8 at the time!)
To rule out the first one, I ask you the favor to do a test:
could you please run Gng (bootleg @59.59Hz) and compare it to Black Tiger (bootleg @60.00Hz) ?
Have a close look at the background: in GnG, tombstones or the far mountains for example, don't move smoothly while in Black Tiger everything is silk smooth !
Since I'm still stuck in finding a way to check my 'real' monitor refresh rate, I did some research and find a little tool, presented inside this same forum.
The tool is FreqTest and you can find it here:
http://forum.arcadecontrols.com/index.php/topic,135230.0.htmlIs it reliable ? Can I succesfully check if my panel took the refresh rate I put inside RatRefresh ?
Now for the to do part
I noticed, as RataPlan himself said in the beginning, that my MAME frontend (FEEL), whenever I switch refresh rate, crashes (it goes black screen eventually crashing in a couple of minutes)
Now, if there's no way to prevent this behavior, I'm scr**d
Indeed, it won't be feasible, inside a cabinet to manually start/stop applications.
Please tell me there's a solution since I cannot believe we went so far just to surrender now to evil windows events
One last thought:
I tried the same procedure on a laptop with Intel graphics; I managed to get the EDID_OVERRIDE key and to run RatRefresh but, according to the tool above (and also to various web based testers) I'm still at 60Hz ! ... obviously I tried mame, just in case, and results were trash (same as without RatRefresh), confirming I'm still at 60Hz
I'm afraid there's not so much to do with my portable rig since probably the vendor locked something to prevent users tampering around with video settings !
I'll leave you alone guys for the moment, hoping that when I'll come back, someone will have really good news for the front end issue
Don't forget I still have some room, on the left of the cabinet, for a second statue (the one on the right is already booked for RataPlan's)
Cheers
