Author Topic: Jukebox Rock ola 442 - Where can I connect the upper speakers  (Read 3069 times)
fulkano
  • Last login:January 11, 2017, 02:05:05 pm
« on: January 08, 2017, 07:43:30 am »
Hi there,
I just bought a Rock ola 442 and the upper speakers are not working. Understandable because at the right a grey 3 pin cable hangs loose. Does anyone know where to connect it? It doesn't seem to fit anywhere.
grtz
Fulko
« Last Edit: January 08, 2017, 07:50:15 am by fulkano »
whammoed
  • Last login:August 19, 2025, 10:46:15 am
  • Crack don't smoke itself
    • NiceMite
Re: Jukebox Rock ola 442 - Where can I connect the upper speakers
« Reply #1 on: January 11, 2017, 10:04:14 am »
There can be unused cables meant for accessories or add ons you don't have so that may or may not be it.
Your best bet is to simply trace the wires from your upper speakers until you find the end.  Either they are not plugged in and that is your issue or they are plugged in and it is something else.
fulkano
« Reply #2 on: January 11, 2017, 02:05:51 pm »
Allright thx. I traced down a red en black wire, but where do I plug them to the amplifier?
whammoed
    • NiceMite
« Reply #3 on: January 21, 2017, 08:17:07 am »
Should have 4 wires.  2 for each speaker.  What does the end of the wires look like?  Cut? Connector?  Take a picture.
Regardless there should be a connector for them to plug into that comes from a transformer that is fed from the amplifier.  Should be a 4 position connector.
If I get a chance I'll post a pic of how my 464 is wired.
