Author Topic: Calamity drivers / CRTEmudriver / VMM : No picture (HD 5450)  (Read 4447 times)
demol
  • Last login:April 23, 2017, 12:43:09 pm
« on: January 04, 2017, 06:39:19 pm »
Hello, i wanted to play arcade games on a real crt tv and bought everything for it : an HD5450 with DVI-I input (no vga on the cord), a DVI-I to VGA adapter and a scart to VGA cable. i plugged everything, installed calamity drivers, everything went smoothly (was following calamity guide). Then, i had to enable EDID stuff on VMM, bur after that i don't get any picture. In fact, i never get a picture.
Everything is installed correctly, VMM shows me that on the DOS screen :
Getting driver information for \\.\DISPLAY40
ADL Library found, retrieving functions...
ADL functions retrieved successfully.
CRT Emudriver 2.0 (12.6) found.
but i can do anything i want, i never get a picture through the analog port, only in digital. I tried lots of profiles (Pal, NTSC, Arcade, generic), tried with extended unchecked and checked, installed with a IGPU activated and the CRT plugged, or with the IGPU disabled and no cabl and my monitor plugged on the HD5450, rebooted a hundred times, installed on every analog port listed... I even tried to hook the scart on my HDTV to see if it was my crt that was difficult, but still no picture at all...
I've been doing that for the past 2 hours, i really don't know what's the issue and it's driving me crazy...
I'm wondering if it's simply a sync issue and that the VGA to scart is not enough and i need a "converter" ? I use this cable http://www.ebay.fr/itm/SCART-Cable-to-SVGA-VGA-15-PIN-HD-PLUG-Lead-1-5M-UK-/361224212922?hash=item541aa411ba:g:tW0AAOSwJb9WrymM
« Last Edit: January 04, 2017, 06:54:06 pm by demol »
demol
Re: Calamity drivers / CRTEmudriver / VMM : No picture (HD 5450)
« Reply #1 on: January 06, 2017, 06:37:39 am »
anybody ?
Sky25es
  • Last login:November 24, 2025, 12:35:19 pm
« Reply #2 on: January 06, 2017, 03:22:05 pm »
I would ask that on the correct forum section
http://forum.arcadecontrols.com/index.php/board,52.0.html
demol
« Reply #3 on: January 06, 2017, 03:45:14 pm »
Oh ok, i wasn't sure i should post there. thanks
  • Last login:Today at 03:03:03 pm
« Reply #4 on: January 06, 2017, 03:46:57 pm »
No worries.  Topic moved.
buttersoft
  • Last login:Today at 05:15:43 pm
  • Is running at 15kHz
« Reply #5 on: January 07, 2017, 07:03:09 pm »
Moved where? I'm not seeing it in the GroovyMAME section.
« Reply #6 on: January 07, 2017, 07:14:37 pm »
Oops!  Accidently moved it to Monitors/Video.   :embarassed:
Thanks for the correction.   :cheers:
Calamity
  • Moderator
  • Last login:Today at 04:51:39 am
  • Quote me with care
« Reply #7 on: January 08, 2017, 03:15:09 pm »
Hi Demol,
As Recap pointed on the Eiusdemmodi site, the problem is the cable you're using.
Most VGA-SCART cables you'll find on the internet are worthless for our purposes because they're designed to output from SCART to VGA, instead of from VGA to SCART that's what you want.
Steps to create a log:
demol
« Reply #8 on: January 08, 2017, 03:16:27 pm »
Interesting... Guess i'll have to order a UMSA from arcade forge then ! Thanks for the answer :)
