Author Topic: Getting Windows 10 to work on an 800x600 monitor  (Read 2678 times)
mcsizzles
  • Last login:December 30, 2016, 04:22:04 pm
« on: December 30, 2016, 04:06:28 pm »
Hi,
I have the Makvision SVGA 800x600 monitor. It worked fine when my rig had windows XP on it, but I installed windows 10, so I could use internet safely and play some modern titles, now I get a message that says OVER SPECIFICATIONS.
The only way I can get the monitor to work in windows 10 is if I boot up the computer on a regular pc monitor and then switch the vga cable over to the Makvision once it is all booted up. Is there a way I can get this thing to work with my Makvision without having to plug and unplug it? lI have an arcadevga I could use if that helps, but right now i'm using my old GTX 570 video card.
Angel
buttersoft
  • Last login:Today at 07:20:39 pm
  • Is running at 15kHz
Re: Getting Windows 10 to work on an 800x600 monitor
« Reply #1 on: January 02, 2017, 08:02:48 pm »
Hmmm, something like CRU can instruct the system to use specific modelines only. You can remove the modes you don't want. It might work, if there's a Win10 update? I say that, as my own efforts to have CRU produce 15kHz modes on Nvidia have failed abysmally. But 15kHz on Nvidia is a special case, and this isn't a 15kHz mode you're after.
TGov
  • Last login:March 21, 2017, 02:07:54 pm
« Reply #2 on: March 21, 2017, 12:43:21 pm »
Going to bump this.  I have had a terrible time with my 2929 SVGA and Windows 7.  I can get the desktop to come up fine and Hyperspin, but half of the games go to Out of Range..... Then I can't get it back to the desktop without saying out of range and....well it has been a nightmare.
