Author Topic: Need Help: Cover Holes in CP  (Read 3039 times)
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
« on: December 13, 2016, 12:58:43 pm »
I need to move some buttons around and need to know how to cover the holes left over. What do I need? Thanks! :dunno
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
behrmr
  • Last login:April 23, 2021, 09:17:13 am
Re: Need Help: Cover Holes in CP
« Reply #1 on: December 13, 2016, 01:04:59 pm »
What kind of panel? Wood, metal, plexiglas overlay, etc? Are you replacing anything, putting on new artwork?
If you just want to fill the hole you can always get an arcade button hole plug.
Ortizimo
« Reply #2 on: December 15, 2016, 11:41:48 am »
wood. i just want to move some buttons from the sides to the cp top and fill them up, sand them and paint them. what is a good product that can give me a good result? thnx.
DynastyDJ
  • Last login:December 16, 2016, 03:14:06 pm
« Reply #3 on: December 16, 2016, 02:58:09 pm »
I had a similar issue, although from my mistake instead of just wanting to move them.  I used a wood dowel that was very close to the hole size and then filled with bondo.  The dowel was only a buck or two from Michael's. I then sanded and painted it and you cannot even see where the hole was to begin with.
