Author Topic: 25Khz to 15Khz manual switch - Is it possible ?  (Read 2304 times)
AMIGrAve
  • Last login:June 11, 2024, 03:56:35 pm
« on: January 22, 2004, 10:26:14 am »
Hi,
Here's the molex where I can switch from 25Khz to 15Khz.
I would like to know if I make a switch on my control panel in order to be able to switch easily from 15 to 25 Khz, will this hurt the monitor ? I mean, can I damage the monitor when switching from 15Khz to 25 Khz when the monitor is running ?
Ken Layton
  • Guru
  • Technician
Re:25Khz to 15Khz manual switch - Is it possible ?
« Reply #1 on: January 22, 2004, 10:41:00 am »
Don't know---never tried it.
StephenH
« Reply #2 on: January 24, 2004, 03:52:34 am »
You may be able to use a multi-pole relay (or relays that switch each line.
Just a thought
AMIGrAve
« Reply #3 on: January 29, 2004, 05:32:15 am »
But do you think that switching high voltage on a monitor could damage it ?
