Author Topic: Wg 18K7601 monitor manuals??  (Read 1942 times)
James Hughes
« on: June 11, 2002, 06:39:36 am »
Hi all  ;D Hope someone can help me with this problems. I am trying to set my arcade monitor up with AvanceMame but non of the preset resolutions work?? When i select a generic 15khz monitor when it comes to testing the screen goes black so i have to break the program. The only way i can think of getting this to work is to find the exact settings for the monitor. Any help with this monitor would be greatfully apreciated ::)
Thanks to all in advance.
Computers aren't intelligent, they only think they are.
redeye
  • Last login:January 01, 2003, 02:19:22 pm
  • I'm tired of Looking
Re:Wg 18K7601 monitor manuals??
« Reply #1 on: January 01, 2003, 02:51:48 pm »
Trainguy
  • Last login:October 16, 2003, 02:59:36 am
  • Have Train will Travel
    • Kevin's Train Page
« Reply #2 on: October 10, 2003, 02:00:46 am »
I'm having the same problem. Did you ever find out what to do to fix the situation?
Hi all
rampy
  • *shrug*
  • Last login:March 02, 2007, 11:32:16 am
  • ...as useless as a JPG is to Helen Keller
    • Build Your Own PVR
« Reply #3 on: October 10, 2003, 12:09:32 pm »
uhm... do you know how to run the vid config helper program for advance mame (ADVV ? i don't remember exactly)
With it you can use different keys to dial in the exact settings for a given resolution to match your monitor.
There was a great resource that walked you through this at the purple mame page
even if it doesn't match you situation exactly, the info in the whole process is helpful imho.
*shrug*
rampy
Trainguy
Need help setting up a Wg 18K7601 monit
« Reply #4 on: October 11, 2003, 01:44:47 am »
I've tried using the video config utility with advancemame "advcfg" and tried to set up the resolutions Las Vegas suggests on his Purple mame page. but I can not get the higher resolutions and it seems that I have to manual config every game to run in a half decent screen resolution. The WG K7601 monitor has a 15.1 - 16.8 khz Hort scan and 47-63 hz vert scan with a native resolution of 400 pixels x 240 lines.
Is the monitor just not capable for display the higher resolutions or does the problem lie somewhere else?
