Author Topic: megatouch rx keeps rebooting after cmos battery died  (Read 6587 times)
gmtransman2
  • Last login:August 27, 2022, 10:10:37 pm
« on: November 22, 2016, 09:01:28 pm »
rx with a intel mb in it the cmos battery died replaced battery now just keeps rebooting. have reset date time and loaded defalts, saved before i exit cmos. replaced hard drive same thing. any ideas thanks
mahkeymike
  • Last login:November 21, 2025, 04:40:35 pm
Re: megatouch rx keeps rebooting after cmos battery died
« Reply #1 on: November 22, 2016, 09:16:04 pm »
Where does it reboot and is there any error on the screen before it reboots? Reason being, if your IOboard isnt being detected it will cause a reboot loop. Any hardware change or failure will cause a reboot loop. If you replaced the hard drive, that would rule out corrupt data.
gmtransman2
« Reply #2 on: November 22, 2016, 10:23:27 pm »
it has no red failed  all green ok it goes all the way up to localhost login than reboots
gmtransman2
« Reply #3 on: November 26, 2016, 08:27:29 pm »
last thing is says is
usb 2-1: usbsf:   interface 0 claimed by usbtouchscreen while 'twdriver' sets config #1
than reboots and reboots???
lilshawn
  • Moderator
  • Last login:December 04, 2025, 08:10:20 pm
« Reply #4 on: November 29, 2016, 06:04:50 pm »
try going into the bios and loading the default configuration. sometimes something gets enabled or disabled in the bios that throws things into a boot loop.
double check that the computer is set to turn on after an AC power loss.
gmtransman2
« Reply #5 on: January 16, 2017, 04:35:18 pm »
i got it going dip switch #6 on instead of #3, third from the right instead of the left. thanks all for the help.
