Author Topic: LINUX - Regression on some dynamic res. switch. systems since gm 0.178  (Read 3890 times)
tiben
  • Last login:September 17, 2019, 12:54:34 pm
Hi,
I'm on Ubuntu Linux, with Groovymame versions compiled myself using official Mame source + groovymame patchs.
I noticed a bug with two systems when they switch the resolution during the runtime since GM 0.178 and remains on 0.179
First is with Genesis driver:
Code: [Select]
$ groovymame genesis contra
After the display of the Konami logo, the display seems to switch then the screen become white and the emulation seems to freeze internally (GM remains launched)
Second is with Playstation driver:
Code: [Select]
$ groovymame psj -cdrom <any-psx-game>.iso
The Playstation logo appears then GM crash with a segfault.
Theses behaviors do not occur with official Mame.
More generaly it seems to concern systems with dynamic resolution switching.
« Last Edit: November 18, 2016, 05:40:50 pm by tiben »
tiben
Re: LINUX - Regression on some dynamic res. switch. systems since gm 0.178
« Reply #1 on: November 12, 2016, 03:34:37 pm »
Its seem a false positive.
I think i forgot to remove old cfg and nvram files which messed up my setup.
It works as expected now.
Sorry for the inconvenience.
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #2 on: November 14, 2016, 03:41:10 am »
Hi tiben,
Thank you for reporting this. Indeed, resolution switching issue under Linux should be fixed.
Is it still feasible for you to diff the old and current mame.ini files to identify the option causing misbehaviour?
tiben
Sure:
Code: [Select]
$ diff mame.ini.broken mame.ini.good
92,97c92,97
< artwork_crop              1
< use_backdrops             0
< use_overlays              0
< use_bezels                0
< use_cpanels               0
< use_marquees              0
> artwork_crop              0
> use_backdrops             1
> use_overlays              1
> use_bezels                1
> use_cpanels               1
> use_marquees              1
128c128
< mouse                     0
> mouse                     1
215c215
< frame_delay               1
> frame_delay               0
306c306
< switchres                 1
> switchres                 0
311,312c311,312
< filter                    0
< prescale                  1
> filter                    1
> prescale                  2
348c348
< audio_latency             2.0
> audio_latency             2
353c353
< bgfx_path                 bgfx
> bgfx_path                 /usr/local/share/mame/bgfx
426a427
After some tests the issue seems to come from the "switchres" option which i mistakenly sat to 1.
Do you mean there is another known issue with resolution switching on Linux ?
More generally, does Groovymame still supports Linux builds or is it more of a side effect because of Mame compile natively on Linux or because of GroovyArcade history ?
I ask because i see mainly Windows users on the forum!
One last question, is it normal i need to put waitvsync=1 to have perfect scrolling ? If not the scrolling is great but i have an annoying tearing line on most (if no all) systems. This line does appears at differents positions at each launch but remains stable (it does not scan the screen). Sometimes the scroll is perfect, i think that's because the tearing line is located out of the screen. It is not a big issue as i don't notice input lags but i would like to know if this points out that something is fundamentally broken with my setup.  I use Nvidia/nouveau drivers.
« Last Edit: November 14, 2016, 02:25:14 pm by tiben »
Doozer
  • Z80 ERROR
Some multi resolution game like Tekken were impacted by a crash during in-game resolution change. This was prior to alpha2 release. Now it is fixed.
waitvsync is not necessary if you go for 15kHz output. I assume you do bgfx with LCD monitor which then need it to avoid tearing effect.
tiben
No, i think you assume that because of the bgfx parameter of the diff but i mistakenly intertwined the mame.ini from a vanilla Mame install and the Groovymame one.
I do real 15khz, i use a JVC CRT TV set connected using an UMSA adapter and opengl.
Here is my complete Groovymame mame.ini:
(i set waitvsync on the command line, because setting it on mame.ini has no effect)
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   /usr/local/share/mame/roms
hashpath                  /usr/local/share/mame/hash
samplepath                /usr/local/share/mame/samples
artpath                   /usr/local/share/mame/artwork
ctrlrpath                 /usr/local/share/mame/ctrlr
inipath                   $HOME/.15khz-mame
fontpath                  /usr/local/share/mame
cheatpath                 /usr/local/share/cheat
crosshairpath             /usr/local/share/crosshair
pluginspath               /usr/local/share/plugins
languagepath              /usr/local/share/language
swpath                    /usr/local/share/software
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             $HOME/.15khz-mame/cfg
nvram_directory           $HOME/.15khz-mame/nvram
input_directory           $HOME/.15khz-mame/inp
state_directory           $HOME/.15khz-mame/sta
snapshot_directory        $HOME/.15khz-mame/snap
diff_directory            $HOME/.15khz-mame/diff
comment_directory         $HOME/.15khz-mame/comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
# CORE RENDER OPTIONS
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
use_cpanels               1
use_marquees              1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
language                  English
# CORE SWITCHRES OPTIONS
modeline_generation       1
#monitor                   generic_15
monitor                   custom
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                15625-15750, 49.50-65.00, 2.000, 4.700, 5.000, 0.064, 0.192, 0.600, 0, 0, 192, 288, 448, 576
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD OUTPUT OPTIONS
output                    auto
# OSD INPUT OPTIONS
keyboardprovider          auto
mouseprovider             auto
lightgunprovider          auto
joystickprovider          auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     opengl
numscreens                1
window                    0
maximize                  1
waitvsync                 0
monitorprovider           auto
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 0
# OSD ACCELERATED VIDEO OPTIONS
filter                    1
prescale                  2
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2
# BGFX POST-PROCESSING OPTIONS
bgfx_backend              auto
bgfx_debug                0
bgfx_screen_chains        default
bgfx_avi_name             auto
# SDL PERFORMANCE OPTIONS
sdlvideofps               0
# SDL VIDEO OPTIONS
centerh                   1
centerv                   1
scalemode                 none
# SDL FULL SCREEN OPTIONS
useallheads               0
# SDL KEYBOARD MAPPING
keymap                    0
keymap_file               keymap.dat
# SDL JOYSTICK MAPPING
joy_idx1                  auto
joy_idx2                  auto
joy_idx3                  auto
joy_idx4                  auto
joy_idx5                  auto
joy_idx6                  auto
joy_idx7                  auto
joy_idx8                  auto
sixaxis                   0
# SDL MOUSE MAPPING
mouse_index1              auto
mouse_index2              auto
mouse_index3              auto
mouse_index4              auto
mouse_index5              auto
mouse_index6              auto
mouse_index7              auto
mouse_index8              auto
keyb_idx1                 auto
keyb_idx2                 auto
keyb_idx3                 auto
keyb_idx4                 auto
keyb_idx5                 auto
keyb_idx6                 auto
keyb_idx7                 auto
keyb_idx8                 auto
# SDL LOWLEVEL DRIVER OPTIONS
videodriver               auto
renderdriver              auto
audiodriver               auto
gl_lib                    auto
« Last Edit: November 15, 2016, 12:35:17 pm by tiben »
Calamity
  • Moderator
  • Last login:Today at 01:16:09 am
  • Quote me with care
If you're using a CRT the the -switchres option needs to be enabled.
-syncrefresh and -waitvsync are managed automatically by GM (recommended) as long as -autosync is enabled.
-autosync will remove tearing in the situations were the achieved refresh is close enough to the target refresh (-syncrefresh_tolerance). When it's too off, -autosync will disable -syncrefresh causing tearing, but keeping the correct speed.
Steps to create a log:
tiben
Thanks Calamity for giving me deeper insights about these options.
What is the difference between the "switchres" and the "changeres" options ? i believed "switchres was relevant with vanilla Mame only.
So i followed your recommendations .
Unfortunately, i confirm the segfault problem on dynamic resolution switching systems and it doesn't fix the tearing issue.
Here is my last up-to-date mame.ini including your recommendations :
Code: [Select]
readconfig                1
writeconfig               0
state
autosave                  0
playback
record
record_timecode           0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
autosync                  1
sleep                     1
speed                     1.0
refreshspeed              0
keepaspect                1
unevenstretch             1
unevenstretchx            0
unevenstretchy            0
autostretchxy             0
intoverscan               0
intscalex                 0
intscaley                 0
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
use_cpanels               1
use_marquees              1
brightness                1.0
contrast                  1.0
gamma                     1.0
effect                    none
beam_width_min            1.0
beam_width_max            1.0
flicker                   0
samplerate                48000
samples                   1
volume                    0
coin_lockout              1
ctrlr
mouse                     1
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
natural                   0
coin_impulse              0
mouse_device              mouse
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
autoboot_command
autoboot_delay            0
autoboot_script
console                   0
plugins                   1
plugin
noplugin
language                  English
#monitor                   generic_15
monitor                   custom
connector                 auto
interlace                 1
doublescan                1
super_width               2560
changeres                 1
powerstrip                0
lock_system_modes         1
refresh_dont_care         0
dotclock_min              0
frame_delay               0
vsync_offset              4
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
output                    auto
# OSD INPUT OPTIONS
mouseprovider             auto
debugger                  auto
debugger_font             auto
watchdog                  0
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     opengl
numscreens                1
window                    0
maximize                  1
waitvsync                 0
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
switchres                 1
filter                    1
prescale                  2
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2
bgfx_backend              auto
bgfx_debug                0
bgfx_avi_name             auto
sdlvideofps               0
# SDL VIDEO OPTIONS
centerh                   1
centerv                   1
scalemode                 none
useallheads               0
keymap                    0
joy_idx1                  auto
joy_idx2                  auto
joy_idx3                  auto
joy_idx4                  auto
joy_idx5                  auto
joy_idx6                  auto
joy_idx7                  auto
joy_idx8                  auto
sixaxis                   0
# SDL MOUSE MAPPING
mouse_index1              auto
mouse_index2              auto
mouse_index3              auto
mouse_index4              auto
mouse_index5              auto
mouse_index6              auto
mouse_index7              auto
mouse_index8              auto
keyb_idx1                 auto
keyb_idx2                 auto
keyb_idx3                 auto
keyb_idx4                 auto
keyb_idx5                 auto
keyb_idx6                 auto
keyb_idx7                 auto
keyb_idx8                 auto
videodriver               auto
renderdriver              auto
audiodriver               auto
gl_lib                    auto
Edit: I removed the '[Fixed]' prefix from the post title as it appears there is really an issue with switchres
« Last Edit: November 18, 2016, 05:42:03 pm by tiben »
