Author Topic: From Groovymame 149 to 179 alpha 3 + CRT + ArcadeVGA3000 + Win10  (Read 3002 times)
javierluisbravo
  • Last login:November 28, 2016, 02:26:35 pm
« on: November 10, 2016, 06:58:57 pm »
Hi my friends!
My first post here. This is an amazing forum full of people that knows a lot! Very happy to be part now of it.
I used Groovymame 149 in XP 32 bit. All was fine. Now i updated to windows 10 in an SSD drive (Hyperspin runs great now).
It was tricky the installation of the AVGA3000 drivers. As i used 2 monitors to install.. as it was impossible for me to install windows 10 from the 15hz Arcade Monitor alone.
After the install of the AVGA3000 drivers... when i disconnected the Normal Monitor to let the Arcade Monitor alone.. Windows 10 did BSOD when reboot.
.. and the solution i found was super simple... I had to make the Arcade Monitor as main monitor (extending the other one) before disconnecting the Normal Monitor from the DVI port. Then all worked. Seemed a bug in windows 10 not automatically switching monitors.
After that i installed Groovymame 179 alpha3 while keeping my 149 version at the same time in another folder. I found out that lot of things changed.
1) When GM loads the rom... i can see windows 10 pointer loading (blu circle)... (it does not happen in win10 with GM149)
Is there something in mame.ini there to hide it?
2) I got crazy trying to make GM179 not tearing. In GM149 i have no tearing. Thanks god i found a Calamity post recommending this in mame.ini so i put it in my GM179:
lock_system_modes   0
refresh_dont_care      1
multithreading            1
This made it work! So thanks Calamity!. Anything else is recommended for the AVGA 3000 to put in mame.ini?
3) In GM149 I had frame_delay set to 1. Worked great!  Now in GM179... i have a feeling that something is different even putting it in 1.  Don't know what?
Do i put frame_delay in 1?. Or now there's another way to make the input lag better?  As i am very outdated about this.  Because i got confused with a guide that's around that talks about d3d9ex or something like that.. that now was removed.
Thanks in advanced my friends... I know that you think that the AVGA is very limited. I know..
But it's what i have... and i want to make it the better regarding setups..
Love from Argentina!
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
Re: From Groovymame 149 to 179 alpha 3 + CRT + ArcadeVGA3000 + Win10
« Reply #1 on: November 11, 2016, 04:41:59 am »
There was discussion about ArcadeVGA already: http://forum.arcadecontrols.com/index.php/topic,151767.0.html
In short: use any other standard Radeon card like HD4350 or HD5450 to use fully GM features.
For short time I'm using two TV CRTs setups with HD5450 and GM 179alpha3/GM 178 under windows 7x64. When I set numscreens 2 and frame_delay 2 I get bizarre slowdowns (from 100% to 50%) in many games like 1943 or mslug2. With GM 171 everything was fine.
Not using numscreens 2 or frame_delay [any] and everything is fine. But that's on windows 7x64, under windows 10 You may get different results.
javierluisbravo
« Reply #2 on: November 11, 2016, 10:38:49 am »
Thank you Haynor666 for your reply.
Yeah. I had read that thread.. but that is pointed in another direction.
I wanted to know if there are more tips around for the ArcadeVGA3000 to setup inside mame.ini to get a better experience in GM. Besides those i pointed out.
I am not planning in changing the videocard right now really...
...and what about the pointer of the mouse to hide... i have read there are something like that for Linux.. or am i wrong?
The pointer of the mouse with the loading blue circle in windows 10.. appears over a black screen while the ROM is loading... before the nag screens.
This is not related to windows 10 as i have GM149 and there it does not happen. I already tried to turn off the ui_mouse option. That didn't work.
haynor666
  • retro maniac
« Reply #3 on: November 11, 2016, 12:59:20 pm »
Cheapest I've found HD5450 cost about 9 USD so ArcadeVGA is much more expensive.
javierluisbravo
« Reply #4 on: November 11, 2016, 01:02:35 pm »
Thank you!
Here where i live.. (in Argentina)... nothing related to computers is cheap hahaha
Anyway i will have it in mind for sure if i travel to USA/Europe
ArcadeVGA works great anyway if you can live with some black borders some times... or a little crop at bottom/top.
javierluisbravo
« Reply #5 on: November 11, 2016, 01:57:46 pm »
and...
what's the render engine you are using in mame to get a better feeling in the CRT?
Does it worth switching from d3d to bgfx? or another?
haynor666
  • retro maniac
« Reply #6 on: November 11, 2016, 02:32:10 pm »
I have auto setting.
