Author Topic: On the ultimate I/o - led blinky/wiring confirmations  (Read 1219 times)
bcgamer
  • Last login:September 30, 2021, 02:33:37 pm
« on: November 10, 2016, 10:18:06 am »
Needing to certify some info.
I have plain single colour led's on my ultimate I/o
Blues for p1
Reds for p2
White / green / yellow for admins
1.  Having a hard time getting ledblinky to recognize the layout let me see if I have this right:
    The first "row" of pins 1-3 - in ledblinky I just let it know the single pin my led is connected to right? Followed by the ultimarc keycode (p1b1 woulld be lcntrl?)
     Since they are just single colour led, should I do my next button below it in a new row of pins or just go right beside it in pin 2? Does it matter?
    I'm talking about the ledblinky General input map that is done first correct?
    I've got my led's hooked up on the board, LED blinky sees the board, but I cannot get the program to take control of the buttons, been trying to find online guides that get straight to the point for noobs but they just are not out there.
    I understand if all my buttons are rgb then each button would have its own row, seeing that most blinky apps are geared towards rgb.  My last hurdle to get over and I'm done!!
Thanks In advance.
bcgamer
Re: On the ultimate I/o - led blinky/wiring confirmations
« Reply #1 on: November 10, 2016, 10:25:44 am »
Might as well post a pic of the panel
Yay getting close
bcgamer
« Reply #2 on: November 10, 2016, 04:09:43 pm »
   I'm a bit confused by the I/o led section.
  I have daisy chained my positives all around the panel and pinned into the first "+" on the I/0.  No problem there.
   I have 6 blue player one buttons, and 6 red player 2 buttons.  2 white/2green/2yellow up top for admins/coin etc.
  I am confused how to run single colour led's on the board so I can properly run led blinky.  The board is being weird.  The first row, where the daisy chained positive is channeled to the first"+" pin, pins 1,2,3 light up p1 buttons 1,2,3.  Nothing wrong there.
  Second row, only pin 4 works (R) (button4-blue), pins 5 and 6 won't light up buttons 5&6 (blue) Pin 7 will light up button 5 (blue) and pin 11 for button 6(blue).
  What am I doing wrong for single colour led?  I tried doing all the player 1blue buttons (6) into just the "B" pins (3/6/9/12/15/18) and that didn't work either.
  I'm not trying to confuse you I'm just trying to figure out what I'm doing wrong because this doesn't look right.
   Should every button be on its own "row"? (1-3)(4-6)(7-9) and if so being the buttons are a dedicated colour (not rgb) should they be pinned Into a certain "colour" on the board (r/g/b)?  I thought all the blues would go in the "B", the red buttons in the "R" and so on, I'm obviously an idiot.
   This seems a lot more difficult then what it should be so I'd like to see what I'm doing wrong.  I can get them all to light but they have to be  pinned all over the place and doesn't seem right.
   I obviously only have one "+" plugged into the board from the daisy chain, and it's pinned into the very first input.
I'm trying to figure this out on my ow. But I'd really like to get this sorted out so I understand.
