Author Topic: [SOLVED] Smash TV player 2 controls not working  (Read 3738 times)
TheOnlyShad0w
  • Last login:November 24, 2016, 03:45:48 pm
« on: November 01, 2016, 05:25:44 pm »
So my second joystick works fine in all the other games I've tried (Mario Bros, Track & Field, X-men, 1943) but it just doesn't register in Smash TV. Interestingly, the coin and start buttons for player 2 do function, but nothing else does. Player 1 controls function perfectly.
Does Smash TV have a weird control layout?
I'm using Mame4All 0.37b5.
« Last Edit: November 01, 2016, 08:42:34 pm by TheOnlyShad0w »
JDFan
Re: Smash TV player 2 controls not working
« Reply #1 on: November 01, 2016, 05:29:59 pm »
HAve you tried going into the tab controls and setting the Input (this machine) settings ?
Smash TV is a dual joystick game for 1 player -- ie. the one joystick controls movement and the other shooting direction so would need 4 joys for 2 player !!
« Last Edit: November 01, 2016, 05:31:30 pm by JDFan »
TheOnlyShad0w
« Reply #2 on: November 01, 2016, 05:40:11 pm »
I have player 1 set up to use the joystick for movement and 4 buttons for shooting. Player 2 is exactly the same. I've tried remapping all of the available controls to the joystick and nothing responds. I know the joystick works because I can map the player 2 joystick to the player 1 controls and it works fine.
« Reply #3 on: November 01, 2016, 07:26:37 pm »
Map player 1 joystick 1 to directions and player 1 joystick 2 to the buttons and it should work.
Same goes for player 2 joystick 1 directions, player 2 joystick 2 to the buttons.
TheOnlyShad0w
« Reply #4 on: November 01, 2016, 07:54:59 pm »
I think that's how I have it. Player 1 joystick is movement and my four buttons control shooting. Player 1 works fine. Player 2 is mapped the same only for player 2 controls and I get no response.
Does it maybe have something to do with running through Retroarch?
TheOnlyShad0w
« Reply #5 on: November 01, 2016, 08:42:14 pm »
Ok I figured it out. Looks like the Libretro Mam4All build for Retropie doesn't play well with Smash TV so I changed the emulator to the regular Mame4All version and it's working great now!
Re: [SOLVED] Smash TV player 2 controls not working
« Reply #6 on: November 01, 2016, 08:49:42 pm »
glad you figured it out, and its good you posted what the fix was. :cheers:
