Author Topic: 720 controller and Optipac  (Read 3262 times)
Captain No Action
  • Last login:February 26, 2019, 05:38:17 pm
« on: October 31, 2016, 01:30:58 am »
Hey all. I have finally hit a snag and have to ask questions. I bought a real 720 controller and the Optipac and cannot get it to work properly. What I do get or can is the skater will turn directional left and right only. Sluggishly. The input for game controller is set to joystick and the curser will move everytime vertical. Ive searched here and mame forum but it doesnt help with my current release or problem. I know the best rated was MAME 0.141. Whatever help I can get is much appreciated. Specs are as follows:
Win 7 Home x64
MAME 0.172 only, no emulator, basics first
720 rev 4
Optipac P1 track ball x and y
I have the whole ultimarc package. I am new to this but have a 2 player joystick and spinner working so I believe I am not completely brain dead.
Thanks, Matt
paigeoliver
  • Awesome face!
Re: 720 controller and Optipac
« Reply #1 on: October 31, 2016, 01:52:06 pm »
Ok, you are going to have to do some digging for this one. I believe you need a custom mame build to actually use a real 720 controller.
  • Last login:January 29, 2026, 12:04:48 pm
« Reply #2 on: October 31, 2016, 02:25:37 pm »
I'm not sure they ever did incorporate the second optical disc into MAME correctly.
As far as the sluggish and absolute turning, have you tried adjusting the sensitivity in MAME?
Nothing should be mapped to axis inc and axis dec.  (not exactly sure of the phrasing on 720)
jerryjanis
  • Last login:February 02, 2023, 01:56:44 am
  • Skate or Die!!!
    • Jake's Joystick
« Reply #3 on: October 31, 2016, 02:41:38 pm »
Is there an option to select something like "Real" as the controller type? This option was created for users of a real 720 joystick. I can't say for sure if it's still in effect (sorry, it has been a while for me), but might be worth a try.
Here is an old discussion that took place when the code was first added to Mame:
http://forum.arcadecontrols.com/index.php/topic,108728.0.html
Here is a link to the mame driver which appears to include code to choose the "Real" controller type:
https://github.com/mamedev/mame/blob/master/src/mame/drivers/atarisy2.cpp
Captain No Action
« Reply #4 on: October 31, 2016, 06:42:13 pm »
Thank you gentleman.
Custom MAME, uh oh. Not sure what you mean.
I did adjust the sensitivity in MAME, Analog Controls that were at 10 were increased to 100. So all is at a 100.
I did try real for the input and nothing happened. Only joystick worked. The CP joystick and buttons work fine. I read the link to the older threads and got a headache. I will continue reading those and try and understand it. I am unsure as to what to do with that text though.
Off question. Is it better to run an older version of MAME to get the games to work properly or try and keep up with the latest version. I am thinking that you need the highest MAME version for the weakest current version of that game.
paigeoliver
  • Awesome face!
« Reply #5 on: October 31, 2016, 10:51:04 pm »
You can run multiple versions of mame on the same machine. I normally run most of my games through an older (pre .100) version because there won't be any slowdowns. I only go to newer mame versions for specific titles that don't work right in the older versions.
In the case of 720, whatever version you can get the controller working in is what you will want. The game itself has been running fine and full speed for as long as I can remember (maybe 15 years now), so any improvements in the code will not be as important as getting the controller working right.
Captain No Action
« Reply #6 on: November 01, 2016, 03:20:08 am »
Thank you paigeoliver, I will try the older versions of 720 and MAME. Will post what I find. Hopefully we can get this figured out and leave some info for the future poor soul that attempts this.
  • Online Online
  • Last login:Today at 04:49:10 am
« Reply #7 on: November 01, 2016, 03:55:17 am »
Here are several links that you might find useful.
http://www.720zone.com/720-Joystick-Help.html
http://jstookey.com/arcade/720/720-arcadejoy.php
As of Mame 142, support for the 720 arcade joystick has been added to the official Mame build, so there is no longer any need to run an old version of Mame Analog+ or build your own old version of Mame in order to use the 720 arcade joystick.
Captain No Action
« Reply #8 on: November 02, 2016, 01:49:41 am »
Thanks PL1. I have seen the 720zone web site. I revisited and saw I didnt use the right connection on the OptiPac. jstookey does not have the info up anymore.
SUCCESS. It works. The next problem is figuring out which holes, that are not marked, are the push buttons. Hah. Love it. I still suck at it but thats ok. The main problem was the wiring done by the person I bought it from was backwards. I just played around till I got it. Ill post picks and write up what I have for others when their time comes.
Thanks guys.
« Reply #9 on: November 02, 2016, 08:52:15 am »
Now that we know it works, this is one of those controllers that I'd like to have a shoddy $30 homebrew version of.
I'll add it to my list of things I'll never get around to.
Aceldamor
« Reply #10 on: November 05, 2016, 01:25:10 am »
Authentic ones only go for about 600-800 nowa days......
Fuzzy Wuzzy was a woman!
