Author Topic: Golden Tee Fore! Complete - Does not load to courses  (Read 28570 times)
mattyams
  • Last login:December 23, 2016, 10:21:56 am
  • Game Tech transformed into SysAdmin
Re: Golden Tee Fore! Complete - Does not load to courses
« Reply #40 on: November 02, 2016, 08:20:21 pm »
Yeah, no problem.
ed12
« Reply #41 on: November 02, 2016, 09:41:56 pm »
ok let me ask a few questions here
are u using a off board ide reader/writer like a unit that will do the hard drive through usb ?
or are u slaving it on your personal computer ?
reason I ask is it is a lot easier to do it as a off board drive (usb to ide like)
converter
next if u do not mind download partition magic "mini" make sure it is "mini"
it is best for what u need to do and it is freeware and not bloated with crap
once this is done let me know. it gets real easy
ed
mattyams
« Reply #42 on: November 02, 2016, 10:20:03 pm »
converter
ed
Yes, using IDE to USB 2.0
I think I was using mini but I will check when I get back to the shop tomorrow.
I am not sure when I am getting the drive back, but not as long as last time.
And if I haven't said it yet, I appreciate all your help.
ed12
« Reply #43 on: November 02, 2016, 10:45:43 pm »
oh you are more then welcome
how with the drive hooked up (usb)
what u want to do is open partition magic mini  (use admin here)
allow it to open and detect the system
ie your internal stuff and the usb drive
once that is done
go to the # it says the usb drive is
2-x but not 1 never ever 1 as that is your base system drive
once u are at the drive # click on the left side delete partition
then apply (chk mark at top of screen)
once it is done
on the left side click clean (it will ask u to fill with 00's)
click enter
and start
wait for it to be done
once done (do not unhook the drive)
just shut down partition wizard
now we go to diskmgmt.msc "run as admin) very important
have it assign a drive letter
number (no need to format and or disk part)
it will spit back a #
now min the diskmgmt (do not close it)
now go to cmd prompt run this in admin mode also
type cd\.
type cd\chdman (this is chdman main exe is)
find the .chd u want to load to the disk
now type this command exactly as I post it
chdman createhd -o kinst2.chd -i \\.\PHYSICALDRIVE3 -f
the reason for the -f is it will format the amount of space the file needs
the kinst2 name is an example
when I do this I use like  gt06.chd
physicaldrive # is the 1 that diskmgmt told u it would be (reason for not closing it btw)
once it is done error free
u have written the file from chd to a hard drive
also remember remove any jumper settings u have on the drive
there is no real need for it in a single sided system (gt complete)
ed
mattyams
« Reply #44 on: November 03, 2016, 01:47:55 pm »
Getting an error "Can't guess CHS values because data size is not divisible by 512"
I need to provide those from the HDD correct?  Will I still need to do -f?
ed12
« Reply #45 on: November 03, 2016, 02:02:52 pm »
the exact way I typed the cmd
-f (fits file to table) (forces file to fit)
ed
mattyams
« Reply #46 on: November 03, 2016, 02:12:54 pm »
I did that. Except changed the chd to my file name and the drive number to the correct one.  See attached image.
ed12
« Reply #47 on: November 03, 2016, 02:25:19 pm »
pm me your e-mail I will send u gt06 (complete)
I can .zip it up and it should go
unless u try this
instead of renaming it
just write the complete name of the chd down and type it in full
also u were doing all of this in admisitor right ?
as u must be in adm mode
ed
mattyams
« Reply #48 on: November 03, 2016, 02:33:45 pm »
I got this after manually putting in the chs values. I don't think that was an issue with the chd file, just the HDD.
ed12
« Reply #49 on: November 03, 2016, 02:41:17 pm »
well congrads
and holy crap
never had to do that before
did u format the drive as I explained to do in partition wizard ?
ed
mattyams
« Reply #50 on: November 03, 2016, 02:42:17 pm »
And I just thought of something....doesn't 'createhd' create a hard disk image file?  Shouldn't I be using 'extracthd'?
ed12
« Reply #51 on: November 03, 2016, 03:02:06 pm »
my bawd sorry
u are right
I thought about that this morning but did not have time to correct myself
again sorry
so
we go back to square 1
partition wizard/delete/fill with 0's
diskmgmt.msc
cdman etc etc  but do replace the cmd with the proper 1
chdman extracthd -o gt6.chd -i  \\.\physicaldrive # -f
chdman extracthd -i kinst2.chd -o \\.\PHYSICALDRIVE0 -f
lord I feel like an idiot
sorry
ed
mattyams
« Reply #52 on: November 03, 2016, 04:13:10 pm »
Got it finished up. Time to get the drive to the client.
ed12
« Reply #53 on: November 03, 2016, 04:20:50 pm »
lets hope it works
ed
mattyams
« Reply #54 on: November 04, 2016, 09:19:43 pm »
Well ---steaming pile of meadow muffin---.  Still the same damn issue. This is getting frustrating as hell.   :banghead:
ed12
« Reply #55 on: November 04, 2016, 09:24:58 pm »
do u have the hard drive back ?
ed
mattyams
« Reply #56 on: November 04, 2016, 10:21:29 pm »
Yes
ed12
« Reply #57 on: November 04, 2016, 10:35:42 pm »
ok 1 more time for old time sake
please do not give up , we WILL get this 1
first question
1=did u remove any and all hard drive jumpers ?
if so good
if not do so
2=u stated u used parition magic ?
exactley like i asked u to
delete all paritions ?
then do a wipe disk on the # that it showed u on screen ?
ie right now i am wipping a 500 gig it shows as disk index #2
with a usb drive as u said u are using it should be asigned a #
u need to WIPE THAT NUMBER
then we can colse it out (parition magic)
and go to diskmgmt.msc
and assign a number (NOT A LETTER)
then we min that we do not colse and we go to cmd
from there we go chdman
and enter the exact (last cmd) i pasted for u
of course in windows 7 and up u must be in adm. or it is for not
if this dose not him ?
then time to ask a few questions
1=is the (red light blinking) ? this is (ide-call-ack led) if it is not blinking he has other problems
and u will need the board for repair
ed
mattyams
« Reply #58 on: November 04, 2016, 11:37:53 pm »
No HDD jumpers.
Deleted all partitions, wiped disk on the disk labeled #2.
In your previous post you asked me to assign the disk (labeled as #2) a letter. Which I did. I have never heard of assigning a number in diskmgmt.msc.  Am I missing something?
Did the chdman command as you has posted with the changes made for my particular file name and disk number (#2).
Everything done as administrator.
I do know that the red IDE light does blink when reading the drive.  Plus I can hear it spin up and down in the speakers of the game.  (Something else to note is the sound does not work, maybe not related)  When the game freezes up, the IDE light does not blink anymore.
ed12
« Reply #59 on: November 04, 2016, 11:52:40 pm »
ok now we are getting some where
with the sound freezing and video  (courses not loading)
stop looking at the hard drive..and driving your self nuts..
sound freezing is a problem with its codec
but with video doing the same thing (not loading)
u have a few board problems to address
i will need a few answers
u have 2 status lights 1 @ 2 what  are they doing ?
well this freezing is going on ?
never mind the IDE light it is not relevant right now
we need to know status 1 @ 2
they must and i repeat blink at all times
ed
mattyams
« Reply #60 on: November 05, 2016, 12:03:08 am »
Alright, I will hit up the guy tomorrow and see what is happening.
Oh and BTW, there is no sound at all, except that you can hear the HDD spin up and down in the speakers when powered on.
ed12
« Reply #61 on: November 05, 2016, 12:09:39 am »
ok i will a tad for u to read please
u sound like u have some tech inside so i think this may help u understand alot better :)
but first SCOTT get on the stick this thread should be moved...
1=there is 3 led's on these board's and 2 bank's of dip switchs
sw's 5 and sw's 51
these switch's control what the board is to do
i will not touch on some fine nite detail's expect to explain they put the board into various
state's >game/test<
for general use as follows
sw5 sw1 = off
sw5 sw2 = on
sw5 sw2 = on
sw5 sw4 = on
sw51 sw1-4 =on
this is normal operation mode
*for advanced user's please refer to chapter #3*
Now for the led's like i said there is 3 of them
staus 1 status 2 ide
status 1 and 2 MUST blink at all time's
red led (ide) will blink when the ide interface is getting polled
at boot the red ide led will blink once
then the post boot load's,then u will see it blink serval time's >game-loading<
so in short the "board" passed all of it's chk-sum's
Now if the green status led 2 dose not "flash"?
make sure u53 is good and in the right way,try to have a good spare on hand
any build will do (golden tee/buck hunter) any u53...for now
i have never seen the rs232 stop this,but the bat back-up will
this why i remove them for testing
status light 1 dose not flash u have problem's with
the ide interface chip u2/u15/u26
as these chips are tied to the main bus and they are polled first
they will cause a "lock-up" of the board ie :staus1: not blinking
the audio and vidoes are on status #2
so they are not the problem
as status 1 led and the ide interface are problem childern
i will put them in chapter #3
this will inculde the "special switch setting's" NOTE THESE ARE FOR BOARD TEST OLNY
AND MUST BE RETURNED TO THERE NORMAL STATE FOR PROPER GAME USE
that should help u
heres is what i need u to do
keep an eye on green leds 1 @2 most important
if they stay blinking ?
u are basicly home free (new video card ) common problem
sound is easy as pie also
servive switch (inside coin door) is 4 switchs
1=vol up
1=vol down
1=test
1=service
hit test and wait a sec
u will get a full screen of things u can do
scrool to sound turn it up
wa la u have sound
ed
mattyams
« Reply #62 on: November 05, 2016, 05:56:13 am »
I have a little tech sense. I am a systems administrator....prior game tech for about 10 years. Ha.
I'll get on the steps over the weekend.
mattyams
« Reply #63 on: November 05, 2016, 02:02:39 pm »
So once the game freezes up, the leds keep on flashing.
Bad video card?
ed12
« Reply #64 on: November 05, 2016, 02:12:32 pm »
thats where i would start
leds flashing means board is responding
remeber the video/sound are very last in the chain
and little to 0 attenion is paid to the video board/audio codec
ed
mattyams
« Reply #65 on: November 05, 2016, 02:32:58 pm »
Great.  Now where to find one?
ed12
« Reply #66 on: November 05, 2016, 02:53:37 pm »
very hard
are u usa bound ?
be very carefull of ebay crap
u could ask at klov ?
ed
mattyams
« Reply #67 on: November 05, 2016, 06:50:36 pm »
Found this.  http://www.ebay.com/itm/252622249922
Bought it for $35.
No big if nothing works I suppose.
ed12
« Reply #68 on: November 05, 2016, 07:28:32 pm »
no loss there
my god that person must have bought the market of gt's and bb's out
ed
mattyams
« Reply #69 on: November 12, 2016, 11:47:42 am »
Well, he put in the other card and the game was still doing the same thing.
I asked him to replace the whole board making sure to swap out U53 and U15.  Once he did that he said the monitor wouldn't even come on.  :banghead:
ed12
« Reply #70 on: November 12, 2016, 01:01:06 pm »
u need to explain to this person the dip sw's must be set the same as the old board
ed
mattyams
« Reply #71 on: November 12, 2016, 01:09:46 pm »
Gotcha.  Just as a note, I just noticed from that photo on the first post all the dip switches are set to on. Would that be causing an issue?
mattyams
« Reply #72 on: November 12, 2016, 01:19:34 pm »
Scratch that, nevermind. I just checked again. All the switches are in the same position but still nothing on the monitor.
mattyams
« Reply #73 on: November 12, 2016, 01:44:28 pm »
Ok so we are back at square one. Game freezes in the same spot even with the replacement video card. No guarantees that the card worked prior however.
ed12
« Reply #74 on: November 12, 2016, 02:07:38 pm »
different board ? and game freeaes in exact same spot's ?
or same board as before and new "used" video card ?
ed
mattyams
« Reply #75 on: November 12, 2016, 03:31:58 pm »
ed
Same board, new "used" video card. Same issue.
ed12
« Reply #76 on: November 12, 2016, 04:06:18 pm »
ok
put a fan on the heat sink of the video card
and see if it plays longer before it stalls out
this is important
because the person may have a bad ram
either u111,u110,u113,u112,u18,u17,u19,u16
these 2 banks control video and audio
both (post processing) for the main micro
ed
ed12
« Reply #77 on: November 12, 2016, 05:18:53 pm »
tried a post wont go
edit
i did a little note pad .txt for u to c the path
if it messes up in note pad try wordwarp in note pad
ed
« Last Edit: November 12, 2016, 09:12:59 pm by ed12 »
mclovin
  • Last login:December 15, 2025, 11:59:25 pm
  • GT newbie
« Reply #78 on: November 19, 2016, 12:38:14 am »
Does it do it at the exact same place every time?
ed12
« Reply #79 on: November 19, 2016, 12:47:32 am »
yes on multi drives
ed
