Author Topic: Tandy CM-5 RGB Monitor usable for arcade game?  (Read 3633 times)
« on: October 12, 2016, 01:51:35 pm »
Hi all, I have an Arkanoid cocktail which had a broken Toei monitor.  Attempted to fix it, but that thing is beyond my scope of knowledge since the parts are rare I am told.  I replaced it with a temporary 13" LCD I had lying around with an RGB converter.  It works great, but I'd like to swap in a tube monitor eventually.
I'm no monitor expert by any means, but I saw a Tandy CM-5 RGB monitor on my local CL for cheap.  It's about the same size as the one that's in there.  My question is:  Can I easily attach all of the wires and make it work with my PCB?  I'm thinking it's possible, but haven't tried yet.  It's listed as a CGA monitor at 60Hz.
Here's the pinout I found online:
I checked the Arkanoid manual and found the following:
Think it will work?
DeL
« Last Edit: October 12, 2016, 02:05:20 pm by DeLuSioNal29 »
Ken Layton
  • Guru
  • Technician
Re: Tandy CM-5 RGB Monitor usable for arcade game?
« Reply #1 on: October 15, 2016, 12:09:05 am »
Arkanoid outputs composite NEGATIVE sync signal. The Radio Shack monitors are designed for seperate POSITIVE sync signal.
I know for sure the Radio Shack CM-11 is positive sync and your CM-5 is also likely positive sync. We used to use the CM-11 on Medalist "DartStar" coin op dart boards because those boards generated positive sync.
Perhaps your RGB converter board has selectable sync output so you could use the Radio Shack monitor?
ed12
« Reply #2 on: October 15, 2016, 12:46:59 am »
holy ---steaming pile of meadow muffin--- welcome back KEN LAYTON
ed
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 15, 2016, 11:54:04 pm »
Here's my guide on the Radio Shack CM-11 monitor if you happen to run across one:
https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxtdHBhY2lmaWNvfGd4OjJkNWFiYTFiMjkwNGE1NmI
They were fairly easy to repair from what I recall.
If anyone needs any other of my repair guides they are now here:
https://sites.google.com/site/mtpacifico/kens_korner
A CM-11 could probably be used perfectly fine with games that generate positive sync like Centipede, Defender, etc.
« Last Edit: October 16, 2016, 01:24:55 am by Ken Layton »
