Author Topic: LED replacement  (Read 4247 times)
bbkobeman
  • Last login:April 08, 2017, 07:27:51 pm
LED replacement
« on: October 01, 2016, 08:04:18 pm »
I bought some LED buttons off Amazon and they work fine except one of the LEDs burnt. I have been looking everyplace to find a replacement LED but am not having any luck.  It's an LED that is in a collar that kind of snaps onto the top of the cherry switch.
Does anybody know where I could purchase a replacement as I have looked everywhere without much luck.  It's the black LED piece in the picture.
  • Last login:Today at 04:29:13 pm
Re: LED replacement
« Reply #1 on: October 01, 2016, 08:53:37 pm »
Welcome aboard, bbkobeman.   ;D
That looks like a standard pushbutton LED/socket.
The part you need to replace is the red part (LED/current limiting resistor/holder) that plugs into the black part. (socket)
Here are several sources for replacement LEDs.
Paradise Arcade Shop - http://www.paradisearcadeshop.com/369-button-leds
JAMMA Parts - https://www.jammaparts.net/leds-micros/53-colored-single-leds.html
8LineSupply - https://www.8linesupply.com/mm5/merchant.mvc
P.S. Is the LED burnt out or is it just installed backward?
« Last Edit: October 01, 2016, 08:55:58 pm by PL1 »
bbkobeman
Re: LED replacement
« Reply #2 on: October 01, 2016, 09:51:12 pm »
Thank you. I will check those out and see what I can find.
