Author Topic: Megatouch Force Radeon to XL Cabinet  (Read 3889 times)
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« on: September 14, 2016, 12:30:07 am »
Got a buddy with a working Force Radeon that has a bad tube and he asked me about moving his part to an upright cabinet.
Has anyone around here done this before?  I'm guessing it should be fairly simple, but Megatouch unit always seem to have a gotcha. lol
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
mahkeymike
  • Last login:January 15, 2026, 03:00:29 pm
Re: Megatouch Force Radeon to XL Cabinet
« Reply #1 on: September 14, 2016, 07:56:07 am »
Aside from finding a place to mount the mobo and ioboard , the only issue i could see is the touchscreen glass not working with the force touchscreen controller if the XL has a ELO touchscreen. If it has the 3M microtouch SMT-3 then you can just swap the black force controller out and your good to go.
You will probably need to use the force power supply aswell and depending how the switch in the back is wired you might have to splice something like a surge protector in to the hot, nuetral, and ground so everthing turns on when you flip the switch.
