Author Topic: Mala Frontend "Error reading tree file"  (Read 4913 times)
motleyjoe
  • Last login:September 02, 2016, 04:02:05 pm
« on: September 02, 2016, 03:18:41 pm »
Hello. New here, thanks for reading and possibly helping. When I start up Mala the 1st thing that happens every time is I get an error message that says "Error reading tree file". I can exit out of the error message and go on to Mala fine after that, it is just very annoying to get that error EVERY TIME I start up. I don't want to use the tree, I am very happy with my current setup. Any help would be greatly appreciated, as I have searched and searched and found no answers..Thank you...Joe
Scassidy24
  • Last login:October 12, 2023, 11:56:34 am
  • I love my Nostalgia Machine
    • forum.arcadecontrols.com/index.php/topic,150379.0.html
Re: Mala Frontend "Error reading tree file"
« Reply #1 on: September 27, 2016, 10:47:47 pm »
Make sure that you dont have the "use tree" checkbox enabled.
from your main mala screen right click to bring up the menu, the click configuration, the go to the GUI tab, and under that the Layout tab, and see if "use tree" is checked. if so , uncheck it .
hope that helps if you're still around looks like its been almost a month since you posted.
