Author Topic: New arcade monitor discoloration  (Read 3646 times)
kalkin
  • Last login:January 20, 2004, 02:33:51 am
  • I'm an arcade builder wannabe!
« on: January 19, 2004, 06:01:29 am »
I have a new Hantarex 28" PoloStar and it's got a quite large yellow-ish discoloration which can be seen on a completely red screen. I thought this was a typical degaussing problem and while I was looking for a TV to strip a degaussing coil from I found out that a regular magnet will fix the problem temporarily (until I unplug/plug the monitor). Now that I built my degaussing coil it doesn't help the discoloration. In fact it will bring it back if I had fixed it with the magnet. This leads me to believe there's either a hardware error or a misaligned setting.
Any ideas? I'm completely new with arcade monitors.
Ken Layton
  • Guru
  • Technician
Re:New arcade monitor discoloration
« Reply #1 on: January 19, 2004, 10:52:23 am »
Buy a good quality MANUAL degaussing coil from Bob Roberts or Happ Controls. It'll fix your problem and save you much grief.
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: January 19, 2004, 04:40:14 pm »
Doesn't your Polostar have a degauss coil standard? My 25inch model has one, it just needs to be fitted with a switch.
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« Reply #3 on: January 19, 2004, 06:44:59 pm »
I got a 25$ manual deguass on ebay that works really good. May want to try that.
kalkin
« Reply #4 on: January 20, 2004, 03:03:34 am »
Something I forgot to mention is that this discoloration was present when I got the monitor, so it's quite possible it broke in some way during transport.
I didn't even notice the discoloration until I saw Blinky turning yellow/orange in one area of the screen. Then I got the Nokia monitor test app and saw that the discoloration affects a quite large portion of the red spectra.
@b3atmania
Yup, it's got a coil standard which is activated each time you turn the monitor on. It doesn't help removing the discoloration though. On the contrary it brings the discoloration back if I fixed it with a magnet. At first I thought the built-in coil wasn't strong enough but the same thing happens with my home-built coil.
@Ken Layton
I would have done this but it's too much hassle. I'm living in a 220V country and I suppose these coils are made for 110V. Don't know if a step-up converter would work.
I think my home-built coil is working fine though. It should be since it gives the same result as the built-in one. I'm more concerned with the monitor itself.
