Author Topic: 15kHz RGBHV to SCART - about to cry!  (Read 2315 times)
AE35
  • Last login:January 18, 2022, 01:48:24 pm
  • That sure is a nice raygun!
« on: August 27, 2016, 05:31:51 pm »
Hi guys
I am trying to get my source, 15kHz RGBHV, to work with RGBS SCART. The former monitor, Wells-Gardner,
accepted TTL sync from the source, and I think one is negative and one is positive. I believe that SCART uses
negative sync(?).
I have tried building this circuit, which should make both sync negative and output negative. but the picture is not syncing.
I did lower the voltage to 1V using resistors.
http://www.geocities.ws/podernixie/htpc/vga2csync.gif
Can anyone advice me? I do not need amazing image quality, I just need okay sync and a stable image.
SailorSat
  • Last login:Today at 05:23:40 am
    • For Amusement Only e.V.
Re: 15kHz RGBHV to SCART - about to cry!
« Reply #1 on: August 28, 2016, 03:40:50 am »
The most simple way seems to be a simple 74ls04 to negate the positive sync signal, and an 74ls86 to XOR both seperate syncs to a combined one.
*edit*
as the 74ls04 has 6 inverters, you could invert both syncs if needed.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
AE35
« Reply #2 on: August 28, 2016, 06:28:12 am »
Thanks, that does sound like the right way. Since the output will be TTL, should I make voltage divider with two resistors
the get to 1v?
AE35
« Reply #3 on: August 28, 2016, 04:15:06 pm »
That didn't work either. Picture is not syncing. I have to---give up I think.
