Author Topic: GroovyMAME 0.227 - Switchres v0.017t  (Read 453935 times)
haynor666
  • Last login:Yesterday at 10:07:18 am
  • retro maniac
Re: GroovyMAME 0.179 - Switchres v0.016 alpha 3
« Reply #160 on: November 19, 2016, 01:39:03 pm »
I hope support for XP will stay as long as it is possible :)
keropi
  • Last login:December 28, 2022, 11:06:35 am
« Reply #161 on: November 19, 2016, 01:55:14 pm »
Notes on compiling GM for newbies (like me  :laugh:)
- MKChamp's suppression patches are here: http://mamestuff.lowtrucks.net/MKChamp/ , there is a new one for version 0.179 (download and rename .txt to .diff)
- If you are installing in a location other than the default (c:\msys64 or c:\msys32), after you unpack run autorebase.bat
- Use this detailed guide here: http://forum.attractmode.org/index.php?topic=348.0 but apply the different patches with the following order and pay attention to the patch command that changes for the suppression .diff
a. 0179_groovymame_016_alpha3.diff with command: patch -p0 -E <0179_groovymame_016_alpha3.diff
b. d3d9ex.diff with command: patch -p0 -E <d3d9ex.diff
c. suppression_0179u0.diff with command: patch --binary -p0 -E <suppression_0179u0.diff
- If you want to make an arcade-only exe (like mame before mess/ume) then use the "SUBTARGET=arcade" option, like this for example: "make SUBTARGET=arcade -j5"
Here is a download link for groovymame64_0179.016_alpha3_d3d9ex with the suppression patch: http://www.mediafire.com/file/4x5jwkbha98557w/GroovyMame64_0179.016_alpha3_d3d9ex_suppression0179-k.rar
and an arcade-only one: http://www.mediafire.com/file/rq6yzwjxlylp8h6/GroovyMame64_arcade-only_0179.016_alpha3_d3d9ex_suppression0179-k.rar
« Last Edit: November 19, 2016, 03:52:30 pm by keropi »
  • Last login:May 02, 2024, 04:59:06 am
« Reply #162 on: November 22, 2016, 11:46:53 am »
The user oomek has measured a consistent latency increase when comparing the old 0.171 build with current versions of GM, even when using Direct3D 9Ex and frame delay. Fortunately we have probably found the source of problem on a change in the code base made a few months ago.
There's a new test build on the drive that performs as good as 0.171 latency-wise, according to oomek's measurements: groovymame64_0179.016_alpha3_d3d9ex_test
keropi
« Reply #163 on: November 22, 2016, 05:30:55 pm »
great news I suposse!
I can't help in verifying the test so I'll wait for the new .diff to appear :)
krick
  • Last login:February 08, 2023, 08:30:27 pm
  • Gotta have blue hair.
« Reply #164 on: November 23, 2016, 01:24:52 pm »
So this is a different issue than the std::chrono::high_resolution_clock issue?
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
« Reply #165 on: November 23, 2016, 01:29:30 pm »
Yes, and we still need to check if it affects baseline as well before we report it to MAMEdev.
keropi
« Reply #166 on: November 27, 2016, 05:57:53 am »
any news on this patch? or it's still on testing phase?
oomek
  • Last login:June 03, 2024, 08:24:35 am
  • Mame forever.
    • https://github.com/oomek
« Reply #167 on: November 27, 2016, 08:07:40 am »
My testing confirmed an issue with mame's input polling. There are two builds in the 0.179 folder. Alwayspoll which fixes the hid lag and d3d9ex test which reduces the lag even more if you set the frame_delay to 1
The input lag reduction is massive comparing to the original mame. It's around 60-70 ms
« Last Edit: November 27, 2016, 08:20:37 am by oomek »
keropi
« Reply #168 on: November 27, 2016, 11:15:35 am »
really great news then , thanks for the update!
I hope we get a .diff sooner or later :)
javierluisbravo
  • Last login:November 28, 2016, 02:26:35 pm
« Reply #169 on: November 27, 2016, 03:33:29 pm »
Thanks for your hard work.
Tough i am a little lost here.  I have 0179 alpha 3 installed now in my cab with windows 10 and an AVGA 3000.
To which one would be better to update:  alpha3_d3d9ex test? or 0179_always_poll? to get better experience and less lag...
so there was a little delay in 0179 alpha 3... i could feel something compared to 0149 i had installed in parallel before. Playing wboy in 0149 felt like less lag... maybe i was paranoid about that.. but now i think you are confirming that 0179  has more lag that previous groovymame verisions..
Thanks again :)
oomek
  • Mame forever.
« Reply #170 on: November 27, 2016, 05:01:57 pm »
Always poll version is just an original mame with tweaked input polling by Calamity to allow me to investigate the delays. Get groovymame64_0179.016_alpha3_d3d9ex_test.7z and enjoy d3dx9ex benefits and faster input polling. You just set video to d3d and frame_delay > 0 and vsync_offset accordingly.
« Last Edit: November 27, 2016, 05:06:34 pm by oomek »
javierluisbravo
« Reply #171 on: November 27, 2016, 05:26:55 pm »
Thank you so much for clarifying this..
Amazing! i will be testing that version...
and.. vsync_offset.. i never touched it.. i will research about it.  Thanks a lot oomek and Calamity for all this groovymagic.
antoniomauro
  • Last login:Yesterday at 06:31:09 am
« Reply #172 on: November 28, 2016, 09:12:31 am »
Great!
Waiting for the diff to recompile
befensor
  • Last login:March 13, 2017, 03:29:50 pm
« Reply #173 on: November 29, 2016, 07:27:30 am »
Keropi please, could you compile both version, but 32bit if it is possible? Thank you so much in advance but my cab test is win xp 32 based  :soapbox:
Quote from: keropi
haynor666
  • retro maniac
« Reply #174 on: November 29, 2016, 09:04:46 am »
D3Dex is only for Vista and above so this version will not work on XP.
keropi
« Reply #175 on: November 29, 2016, 10:44:13 am »
haynor666 is correct about the D3D9ex version.
I have uploaded some 32-bit binaries in the meantime in case someone finds them usefull - they don't include the latest code that helps reduce latency, once Calamity releases something I'll post binaries
GroovyMame32_0179.016_alpha3_d3d9ex_suppression : https://www.mediafire.com/?89v5ct3jx2zbg9u
GroovyMame32_0179.016_alpha3_suppression : https://www.mediafire.com/?h408drz639b0imr
GroovyMame32_arcade-only_0179.016_alpha3_suppression : https://www.mediafire.com/?7v1wmb0lwrupxue
befensor
« Reply #176 on: November 29, 2016, 11:36:57 am »
Thank you....so THANK YOU so much  :notworthy:
BTW, are there any benefits to use 64bit version (such to install a win xp 64 on to my cab)?
haynor666
  • retro maniac
« Reply #177 on: November 29, 2016, 03:48:35 pm »
From mine experience it works even worse that XP x32. At least with Radeon cards.
befensor
« Reply #178 on: December 01, 2016, 01:06:48 pm »
In mame.ini can you help me to take a test? In my GM I set
full_screen_gamma 0.7
gamma 0.7
(but what differences are between these two?)
Ok, problem is that these settings are too strong: is it possible to the first will add to second? In my cab, brightness is too "strong" and if I low brightness trimmer it darken image too much while mame.ini brightness is more accurate. So, what best setting is in your tests?
Now I'm trying GM 0.179 arcade ("no nag" compiled version posted by keropi).
« Last Edit: December 01, 2016, 02:50:05 pm by befensor »
Re: GroovyMAME 0.180 - Switchres v0.016 alpha 4
« Reply #179 on: December 03, 2016, 05:09:02 am »
GroovyMAME v0.180 is out (Switchres v0.016 alpha 4):
What's new in SwitchRes v0.016 alpha 4 (December 2016)
- Full implementation of dynamic mode switching on the BGFX renderer (D3D11 backend). Now it shouldn't crash when launching games from the internal UI. Games that switch video modes dynamically now work.
- Improved dynamic mode switching for -video bgfx (D3D11) and -video d3d (D3D9/D3D9Ex*). Now transitions should be smoother, and the desktop shouldn't flash on the background anymore. There should be a comparative advantage here for D3D9ex (and D3D11) over plain D3D9 since the former doesn't need to destroy and recreate resources upon a mode switch.
- Attempt at reducing input latency, now it should be on a par with previous versions of GM (0.171). Experimental confirmation needed.
* Re-added D3D9Ex support, now as a separate build. Remind using -video d3d even for the D3D9ex build, instead of the old deprecated setting -video d3d9ex.
Paradroid
  • Last login:May 12, 2024, 07:24:24 pm
    • SCART Hunter
« Reply #180 on: December 03, 2016, 01:55:31 pm »
Thank you!!! :)
Sent from my SM-A300Y using Tapatalk
keropi
« Reply #181 on: December 03, 2016, 02:57:08 pm »
Awesome, thanks for the update Calamity!
I have compiled several flavors with MKChamp's 0.180 suppression patch:
GroovyMame64:
GroovyMame64_0180.016_alpha4_suppression0180 : https://www.mediafire.com/?9egdiv8vklid772
GroovyMame64_arcade-only_0180.016_alpha4_suppression0180 : http://www.mediafire.com/?dgzfbse8m762onm
GroovyMame64_0180.016_alpha4_d3d9ex_suppression0180 : https://www.mediafire.com/?o6mxwzze6abnm1m
GroovyMame64_arcade-only_0180.016_alpha4_d3d9ex_suppression0180 : https://www.mediafire.com/?w509scud0i24wwk
GroovyMame32:
GroovyMame32_0180.016_alpha4_suppression0180 : https://www.mediafire.com/?112gyp4qtcqgb6q
GroovyMame32_arcade-only_0180.016_alpha4_suppression0180 : https://www.mediafire.com/?qmx78m3gteo91a1
GroovyMame32_0180.016_alpha4_d3d9ex_suppression0180 : https://www.mediafire.com/?dhpccryuzm6989x
GroovyMame32_arcade-only_0180.016_alpha4_d3d9ex_suppression0180 : https://www.mediafire.com/?urpehq7mnn2a66g
« Last Edit: December 07, 2016, 07:42:29 pm by keropi »
RobeeJ
  • Last login:Today at 03:38:58 am
« Reply #182 on: December 04, 2016, 09:26:17 am »
Having a compilation error with 180 :( Anyone have any ideas?
[root@mame mame180]# make
GCC 6.2.1 detected
Compiling src/osd/modules/render/drawogl.cpp...
../../../../../src/osd/modules/render/drawogl.cpp: In member function ‘ogl_texture_info* renderer_ogl::texture_update(const render_primitive*, int)’:
../../../../../src/osd/modules/render/drawogl.cpp:2714:26: error: ‘class osd_window’ has no member named ‘platform_window’; did you mean ‘osd_window’?
      set_mame_focus(win->platform_window<SDL_Window*>());
../../../../../src/osd/modules/render/drawogl.cpp:2714:52: error: expected primary-expression before ‘*’ token
../../../../../src/osd/modules/render/drawogl.cpp:2714:53: error: expected primary-expression before ‘>’ token
../../../../../src/osd/modules/render/drawogl.cpp:2714:55: error: expected primary-expression before ‘)’ token
make[2]: *** [osd_sdl.make:1192: ../../../../linux_gcc/obj/x64/Release/osd_sdl/src/osd/modules/render/drawogl.o] Error 1
make[1]: *** [Makefile:19: osd_sdl] Error 2
make: *** [makefile:1224: linux_x64] Error 2
mdd45
  • Last login:April 02, 2024, 04:56:41 pm
« Reply #183 on: December 04, 2016, 10:19:44 am »
GroovyMame64:
GroovyMame32:
GroovyMame32_arcade-only_0180.016_alpha4_suppression0180 : https://www.mediafire.com/?urpehq7mnn2a66g
I'm kind of lost with all those new releases. For a winxp 32 with a Pentium 4 setup what is the best groovymame32_0180 to test? what suppression exactly means? Also d3d9ex works on winxp 32?
keropi
« Reply #184 on: December 04, 2016, 10:56:20 am »
suppression = no warning/load messages displayed
d3d9ex = works only on vista/7
« Reply #185 on: December 04, 2016, 12:11:32 pm »
Try replacing win->platform_window<SDL_Window*>() by std::static_pointer_cast<sdl_window_info>(win)->platform_window().
Doozer
  • Z80 ERROR
« Reply #186 on: December 04, 2016, 12:33:53 pm »
@Calamity, the mame_set_focus temporary fix can be dropped from the groovy patch. It is not required anymore thanks to SDL 2.0.5
I have uploaded the Linux build without focus fix.
tom5151
  • Last login:September 16, 2023, 09:21:11 am
« Reply #187 on: December 04, 2016, 03:05:54 pm »
Thanks @Calamity and @keropi for these new builds  :applaud:
mdd45
« Reply #188 on: December 04, 2016, 05:06:14 pm »
Thanks for the info.
nikolash
  • Last login:June 03, 2024, 12:01:57 pm
« Reply #189 on: December 05, 2016, 10:36:02 am »
Thanks @Calamity and @keropi for these new builds  :applaud:  :cheers:
cbcduna
  • Last login:January 28, 2017, 04:46:35 pm
« Reply #190 on: December 05, 2016, 04:00:51 pm »
Sorry Keropy,
i have in doubt with the news modes, i not understand fine the difference betwen d3d11 and d3dex.
 I use win 7 64 bits with CRT. What is the better release im my case?
You can help me please?
Regards,
keropi
« Reply #191 on: December 05, 2016, 04:55:33 pm »
Heh thanks all for the kind words but let's not forget that the brains behind Groovymame is Calamity. Without him there would be no stuff to compile and post :)
From what I know (and correct me if I am wrong on this) normal D3D11 has a frame queue of 4 frames in it's rendering proccess and D3D9ex only has 1. So right from the start there is an obvious advantage in using D3D9ex.
cbcduna
« Reply #192 on: December 06, 2016, 08:06:46 am »
Ok Keropi,
thanks for the answer...
another question mate. What is the diference in arcade_only vs normal in your releases?
Thanks in advance,
C.
keropi
« Reply #193 on: December 06, 2016, 01:09:56 pm »
arcade_only is just mame like in the old days, arcade games only
normal is mame+mess , arcade + consoles + home computers all in one
Isstanar
  • Last login:February 19, 2018, 12:38:39 am
« Reply #194 on: December 07, 2016, 12:53:15 pm »
Thank you, thank you, thank you! I don't mind MAME adding more consoles, but it's been such a hassle for me making a gamelist for a frontend with all the extra stuff.
EDIT: I also noticed that the "GroovyMame32_arcade-only_0180.016_alpha4_suppression0180" mediafire link is the same as the D3D9ex Groovymame32 version. Is that correct or should there be a separate non-D3D9ex version?
« Last Edit: December 07, 2016, 01:08:19 pm by Isstanar »
keropi
« Reply #195 on: December 07, 2016, 07:41:47 pm »
^ yes the link was wrong, thanks for reporting that! I have fixed the post with the links :)
oomek
  • Mame forever.
« Reply #196 on: December 07, 2016, 08:29:07 pm »
I've just compiled GM 0.180 GM with d3d9ex.diff and comapred to the Calamity's build.
The thing I've noticed is that my build is a bit slower (I had to increase vsync_delay) and I wonder why is that.
Also my build is reporting resolution differently.
SwitchRes: [shdancer] (1) horizontal (320x224@57.230000)->(796x448@57.978447)
where Calamity's shows a full number.
SwitchRes: [shdancer] (1) horizontal (320x224@57.230000)->(796x448@58.000000)
Does anyone else have this?
« Reply #197 on: December 08, 2016, 12:15:31 pm »
@oomek, you're probably missing the dummy dlls.
burn_654
  • Last login:March 06, 2024, 03:31:13 pm
« Reply #198 on: December 08, 2016, 12:21:19 pm »
Thanks for the update Calamity! Looking forward to trying out the d3d9ex version...
oomek
  • Mame forever.
« Reply #199 on: December 08, 2016, 12:44:52 pm »
