Author Topic: GroovyMAME 0.227 - Switchres v0.017t  (Read 762583 times)
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
Re: GroovyMAME 0.196 - Switchres v0.017h
« Reply #680 on: March 29, 2018, 01:21:26 pm »
GroovyMAME 0.196 is out!
Wow! Great MAME release (C chip!) and a great Groovy release too. Well done and thanks! :)
Sent from my SM-G955F using Tapatalk
My MAME/SCART/CRT blog: SCART Hunter
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #681 on: March 29, 2018, 01:59:47 pm »
The Linux groovymame version is available too!
josete2k
  • Last login:February 07, 2025, 08:39:53 pm
« Reply #682 on: March 30, 2018, 12:39:12 pm »
I can't proper run MSYS32 so I cannot compile this mame. I'm on W7 x86 and make.exe don't want to work on my computer...
Could someone, please, compile a nonag groovymame for my XP cabinet (32bit)?
I attached the needed files (I think I didn't make any mistake).
« Last Edit: March 30, 2018, 04:32:28 pm by josete2k »
keropi
  • Last login:December 28, 2022, 11:06:35 am
josete2k
veggav
  • Last login:December 28, 2024, 06:53:22 am
« Reply #685 on: April 01, 2018, 08:29:43 am »
Have a few noob questions:
Is it possible to have a Nvidia card and Radeon in the same windows 10 system and have CRT emudrive to work on a secondary display?
Also the first post claims R9 support but recommends the 7000 family.
Does the R9 really works?
And if using a dedicated system, with groovymame on windows 10, if you add groovymame to your startup, does it have a front end to select games or you still need a keyboard for that?
vicosku
  • Last login:November 25, 2020, 10:02:52 am
« Reply #686 on: April 01, 2018, 06:23:26 pm »
What's new in Switchres v0.017h (March 2018)
- Added slider control for frame delay [intealls]
Big thanks to Calamity and Intealls for this feature. However, I can't seem to find it. I assume it should be in the Slider Controls in the tab menu, but I don't see it. I'm sure I'm missing something, but am unsure what. I've attached a log and screenshot. Any ideas?
intealls
  • Last login:January 16, 2026, 05:54:53 pm
« Reply #687 on: April 01, 2018, 08:01:13 pm »
Hi, frame delay needs to be set to (at least) 1 for it to show up.
vicosku
« Reply #688 on: April 01, 2018, 08:51:11 pm »
Thanks, Intealls! Your patch has the added benefit of making it easy to check that Frame_delay is actually active. Apparently at some point my driver-level ini files containing individual frame_delay settings stopped working. I probably wouldn't have realized without this change. Thanks again.
intealls
« Reply #689 on: April 01, 2018, 09:26:12 pm »
Don't thank me, thank Calamity. :) He's done all the difficult stuff.
veggav
« Reply #690 on: April 03, 2018, 06:58:05 am »
I just got my groovy mame setup working.
I was considering buying a new PC just for emulation but I added a radeon 4850 and Crt emudriver worked. I'm using the VGA output to a Kramer FC 14 to a Sony Trinitron and it's awesome.
Just a question why would anyone want super resolutions?
The only reason I see for it is for those setups that can't output the correct resolution.
But why would you want a game that can be displayed perfectly at 320x240 with switchRes to display 2560x240?
I tried both and while I see little to no difference I rather have the emulator outputting the exact same resolution as the arcade board.
Calamity
  • Moderator
  • Last login:Yesterday at 05:28:27 pm
  • Quote me with care
« Reply #691 on: April 03, 2018, 07:14:33 am »
Reason 1.- Keep your mode list short *
Reason 2.- Make horizontal centering 100% consistent between modes.
* Since Windows 7 having a long mode list can slow down your system. The execution time of some system calls grows at an exponential rate based on the number of video modes available (literally).
Steps to create a log:
veggav
« Reply #692 on: April 03, 2018, 08:54:08 am »
Got it, thanks for explaining it.
But don't get it the wrong way, it's possible to have super resolutions in virtually any setup with windows.
I used to have it on my nvidia 1060 with a hdmi to vga adapter to the kramer or even just combining H and V sync to my sony PVM or RGB modded CRT.
So if you add all the modelines in nvidia custom resolution control panel, switchRes could detect it, isn't it?
Basically my point being the only benefit of crt emudriver with AMD using super resolution compared to adding custom resolutions in Nvidia regular drivers would be the using windows desktop on a crt without the need for an external monitor or am I missing something?
Again, my question isn't suppose to offend you or your work, which I think is amazing. I'm just new to using a PC with CRT TVs and I'm not even close to have 1% of your knowledge on this.
Calamity
  • Moderator
« Reply #693 on: April 03, 2018, 09:48:03 am »
No worries. You can certainly do super resolutions in any setup, true. What you CAN'T have is on-the-fly custom vertical refresh rates. That's what GM with and AMD card does (infinite dynamic video modes out of a single stored resolution).
Custom vertical refresh rates are necessary for arcade emulation, where 60 Hz is minority. Other non-dynamic solutions are popular in the console emulation scene where everything is 60 Hz.
zige79
  • Last login:April 17, 2018, 02:57:46 pm
« Reply #694 on: April 08, 2018, 08:49:28 am »
First off a BIG thank you to Calamity and everyone who has contributed to crt_emudriver and Groovymame.
Second, I was hoping someone would be able to point me to the latest nonag 64bit d3dex build please without all the hacks.
Thanks.
galaxian77
  • Last login:November 05, 2025, 03:03:26 am
  • Groovyarcade fan !
    • Arcade Sunday (YouTube)
« Reply #695 on: April 09, 2018, 03:39:43 am »
A MASSIVE thanks to all who are involved in the GroovyMAME development. It's truly amazing, and is super stable. The new 0.196 build (I use the Linux version - thanks Doozer!) is just brilliant. Paired with GroovyArcade and Attract Mode, I have the perfect setup on all of my MAME cabinets.
Thanks you all for keepin the classics alive!
Check out my home Arcade YouTube channel: https://www.youtube.com/channel/UCLKl6BrSjDsvCHIL2Blql-A
Still loving the classics, 30+ years later! 5 dedicated MAME cabinets: GroovyArcade, some Arduinos, real CRTs, ATI VGA cards, and some crazy hacks... Love it.
b4nd1t0
  • Last login:February 11, 2025, 01:35:18 am
    • b4nd1t0's repository
« Reply #696 on: April 09, 2018, 07:18:50 am »
Thanks.
you can take it here
veggav
« Reply #697 on: April 12, 2018, 12:00:36 pm »
Once again, thanks for clearing things up for me.
Just wanted to ask another question.
What about using PC CRT monitors that only accept 31khz? If you use super resolutions the monitor will work, at least on my end here with a Sony G520.
So, do you think it would be possible to use CRT emudriver in this setup?
Or just do the 120hz trick?
zige79
« Reply #698 on: April 13, 2018, 11:25:37 pm »
Thanks.
Many thanks that's exactly what I was looking. Bookmarked!
Calamity
  • Moderator
« Reply #699 on: April 16, 2018, 11:18:02 am »
Yeah, why wouldn't it? CRT Emudriver is about custom video, not only 15 kHz.
anchounio
  • Last login:January 04, 2026, 08:28:56 am
« Reply #700 on: April 20, 2018, 01:35:31 am »
Any chance to have a groovymame compilation with no nag ?
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #701 on: April 22, 2018, 02:53:38 am »
look around.. you'll find it
keilmillerjr
  • Web Developer.
« Reply #702 on: April 22, 2018, 12:51:33 pm »
4 posts above yours is a link.
Sledge
« Reply #703 on: April 22, 2018, 06:07:55 pm »
awww i was trying to get him to look
i thought it was easy to find :)
keilmillerjr
  • Web Developer.
« Reply #704 on: April 22, 2018, 08:11:31 pm »
I know. I decided to be nice. Too tired of being angry and frustrated. It’s hard work. Lol
terranigma
  • Last login:March 20, 2019, 04:03:17 am
« Reply #705 on: April 23, 2018, 12:05:29 pm »
Hi Calamity,
Can you host this great project on github? The patch you provide contains DOS style line endings Is this is because mame upstream distributes the code in this way?  Due to this, it requires manual intervention via dos2unix utility on Linux/Unix before patching.
« Last Edit: April 23, 2018, 12:21:48 pm by terranigma »
Calamity
  • Moderator
Re: GroovyMAME 0.197 - Switchres v0.017h
« Reply #706 on: April 26, 2018, 07:20:25 am »
GroovyMAME 0.197 is out!
b4nd1t0
« Reply #707 on: April 26, 2018, 08:03:04 am »
thank's Calamity
Doozer
  • Z80 ERROR
« Reply #708 on: April 26, 2018, 08:35:41 am »
The Linux binary is also on the drive now.
josete2k
« Last Edit: April 29, 2018, 04:48:06 am by josete2k »
schmerzkaufen
  • Last login:April 16, 2025, 09:46:43 am
  • Multiple Electronic Machine Emulator
« Reply #710 on: May 12, 2018, 06:46:11 pm »
Hi! is there a 197 d3d9ex 64 build available somehere please? I've found more 196 builds in the 197 forlder on google drive (?)
Another question; where is the slider for adjusting frame_delay ? of course I still use 196 but I thought it was included in that one already...
went through the menu ingame but couldn't find it
josete2k
« Reply #711 on: May 12, 2018, 07:12:08 pm »
You have to set
frame_delay=1
in mame.ini first.
Then the option will be available at slider controls.
I had to set again to 0 because tekken and other 3D games were very slow even setting frame delay to the min value.
makya
  • Last login:January 14, 2026, 05:53:17 am
« Reply #712 on: May 14, 2018, 03:04:15 pm »
Into 197 folder are 197 builds even though marked as 196.
schmerzkaufen
« Reply #713 on: May 15, 2018, 03:07:31 am »
Ah ok looks like that was corrected. thank you all!
anchounio
« Reply #714 on: June 11, 2018, 01:31:14 pm »
No GroovyMame 0.198 ?   :'(
moloo
  • Last login:June 16, 2020, 06:10:12 pm
« Reply #715 on: June 17, 2018, 07:14:29 am »
Hi, I use GroovyMame under Linux (GroovyArcade). Is it possible to tweak modelines for a specific resolution in arch linux (as does the Arcade OSD on Windows)? Alternatively, can you import tweaked modelines from OSD Arcade to linux? Which file to edit?
« Last Edit: June 18, 2018, 06:07:54 am by moloo »
haynor666
  • Last login:January 09, 2026, 02:33:07 pm
  • retro maniac
« Reply #716 on: June 18, 2018, 12:12:06 pm »
For now You can use my own GM build - http://forum.arcadecontrols.com/index.php/topic,154799.msg1655249.html#msg1655249
From what I know ArcadeOSD tool is only for windows (Am I right ?) so right now the only way is create custom modeline in ArcadeOSD, and paste into ini file for specific driver or game.
moloo
« Reply #717 on: June 18, 2018, 12:16:15 pm »
thanks, but where is folder with mame specific games or driver ini's under groovy arcade?
alex_bb23
  • Last login:September 07, 2025, 03:16:03 am
  • I want to build my own arcade cabinet!
« Reply #718 on: June 18, 2018, 12:48:14 pm »
Inside of "ini" folder you have to define, e.g roomName.ini
b4nd1t0
« Reply #719 on: June 18, 2018, 01:57:54 pm »
You can find some folders in /home/arcade   and some others in /home/roms/MAME
