Author Topic: FS : Wico Perfect 360 --- Lafayette, LA  (Read 3274 times)
kj4860
  • Last login:February 24, 2025, 12:09:10 am
« on: July 12, 2016, 08:57:26 pm »
I’ve got a rather nice selection of the elusive and exclusive Wico P360 and Perfect 360 Happ/Wico base assemblies (no shaft) im looking to sell/trade:
X5 Wico P360 pcb & bases with necessary Wico shaft accessories redrawn & newly 3D printed (wood/metal panel spacer+pivot cone combo, actuator), pcb/bases all in very good used shape -------- $140/ea. shipped in USA $115/ea. shipped in USA
X1 Wico/Happ Perfect 360 upgrade board with Wico base & base adapter. Honestly not  sure what size shaft the stock white spring base on this uses. Comes with Wico P360 accessories (wood/metal panel spacer+pivot cone combo, actuator, spring base) redrawn & newly 3D printed IF NEEDED, all in very good used shape------- $125 shipped in USA $105 shipped in USA
X1 Wico/Happ Perfect 360 upgrade board with Happ housing adapter only (can be used on Happ Super housing), repaired/replaced missing quick connect; comes with accessories of either Wico (wood/metal panel spacer rings, cone, actuator, spring retainer) or Happ (actuator, spring retainer) redrawn & newly 3D printed; cleaned as best as possible but considered OK/gamer condition overall, ***BONUS*** Comes with original WICO 360 dust washer ------- 110$ shipped in USA $95 shipped in USA
All pcb tested working on a single base with a MC Cthulhu setup.
3D Printed parts:
Copied Originals:
-USA Happ Super Spring Base
-USA Happ Super Round Actuator
-USA Wico P360 Spring Base
-USA Wico P360 Actuator
Modifications:
-Happ Super Spring Base+8 Way Actuator (for using a Happ Comp shaft in Happ Super base; allows 2nd lowest e-clip ringlet to be used; tested with Perfect 360 upgrade board ONLY)
-Wico P360 Pivot Cone+Spacer (due to the diameter of the original spacer rings being nearly impossible to print, i have merely combined the pivot cone with each spacer to form four separate pieces --- pivot cone no spacer, pivot cone wood spacer, pivot cone metal spacer, pivot cone both spacers; no setup test performed with this design, only fit and function with the base)
-Wico P360 8 Way Actuator for Balltop shaft (the NOS balltop shafts typically offered on eBay are ever so slightly too short for using the original P360 actuator)
***Note #1: While i have printed/modified/redrawn all of the components dozens of times and tested each, i cannot attest to them being 100% identical to the original in the "feel" department". The current array of designs i have made works great for me, but this will vary from person to person.
***Note #2: All parts provided with assemblies will be printed in black
***Note #3: No warranty on 3D printed or Wico/Happ parts.
***Note #4: I will not provide STL or any other drawing files; willing to sell the printed parts individually/as kits once the above joysticks are out of here.
Looking to get prices listed –or– part $/part trade for NOS Wico P360 battop shafts (in color other than black), Stainless SlikStick, and/or Perfect 360 buttons (spill resistant opticals) in yellow, green, or black.
Ebay username : kj4860
Any questions, comments, concerns, let me know. Thank you :D
« Last Edit: July 13, 2016, 10:50:53 pm by kj4860 »
kj4860
Re: FS : Wico Perfect 360 --- Lafayette, LA
« Reply #1 on: July 13, 2016, 10:51:30 pm »
Price drop. See first post
kj4860
« Reply #2 on: July 17, 2016, 04:20:06 pm »
going back to ebay. Thanks !
