Author Topic: Retroarch fails when steering wheel is connected  (Read 2080 times)
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« on: June 30, 2016, 11:33:48 am »
Retroarch has worked fine with the two xbox 360 controllers, but when I plug in a Thrustmaster FGT 3 in 1, the controllers dont get recognized in the game, but only in the menu. Is there a way to have retroarch ignore controller setups? When I unplug the wheel, everything works as normal.
Thanks for any help you can provide.
MydknyteStyrm
  • Makeup FX Gamer
Re: Retroarch fails when steering wheel is connected
« Reply #1 on: July 01, 2016, 07:33:53 pm »
Okay I figured it out. My steering wheel is registering as the first controller and I only had two controllers set under number inputs. I changed the number to three, disabled the third player as a wheel, and discovered that if I delete the remaps I saved before plugging in the wheel, everything works perfectly now!
