Author Topic: rowe/ami ri5 romantica  (Read 2541 times)
gary64
  • Last login:June 28, 2016, 02:38:14 pm
« on: June 28, 2016, 02:28:33 pm »
I have RI5 romantica and the coin acceptor doesn't seem to be working .is there any way to test it whilst still in the unit.
the coins just stick in the mech,the reject works but nothing else.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: rowe/ami ri5 romantica
« Reply #1 on: July 01, 2016, 09:34:52 am »
Hi Gary64,
Is the coin mechanism mechanical or electronic?
If it is mechanical then take it out of the jukebox in its carrier so you can work on it on the bench, remove the coin mehanism and clean it.
The best way is to use a damp cloth with a smal amount of washing up liquid on it, dry it off and check that the coin rockers are working correctly and not fouling with the coin, check that they will pass through the plate that holds the magnets etc.
If it is electronic check that there is voltage to the coin mechanism interface and again the coin maechanism is clean.
Regards
Alan
Alan Hood
ami-man
UK
