Author Topic: Pcb wires  (Read 1070 times)
Iceman81
  • Last login:November 30, 2018, 05:57:54 am
Pcb wires
« on: June 26, 2016, 03:51:00 pm »
Hey all, I bought a cp from monster arcade a while back and decided to build a bigger one. To save money I used all the parts from the monster cp.
Anyway, the wires are a bit short and it's very tight.
Is there anywhere to buy just the wires? I'm also concerned if I bought an ipac, would I have the same issue?
aldub516
  • Last login:November 29, 2018, 03:32:46 pm
Re: Pcb wires
« Reply #1 on: June 26, 2016, 07:35:19 pm »
you can either re-wire everything with standard wiring and start scratch, which involves crimping and such. Or you can buy some daisy chains for the grounding and and some pre made wire harnesses for the buttons.  Alternatively, if there are only certain wires that are too short, you can simply snip them, and extend them with some regular old stranded 18/20 gauge wire.
