Author Topic: 4-way 45 degree rotated joystick games  (Read 5946 times)
Batchman
  • Last login:November 26, 2020, 08:03:49 pm
« on: June 24, 2016, 01:56:02 pm »
Just wondering ... other than the two that I always hear mentioned (Q*bert and Congo Bongo) what other games are there that use a rotated 4-way joystick? Are there any?
Just found myself wondering ....
  • Last login:Yesterday at 11:02:51 pm
Re: 4-way 45 degree rotated joystick games
« Reply #1 on: June 24, 2016, 03:19:55 pm »
AFAIK, the only other one is Q*bert's Qubes.
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
« Reply #2 on: June 25, 2016, 08:32:50 am »
Inferno does but you also need a second 45-degree 4-way stick with a button to aim and shoot.
Jack Rabbit seems like it should use one.  MAME has it as an 8-way joystick where you have to push diagonally to move. Nothing happens if you just up, down, left or right.
« Reply #3 on: June 25, 2016, 04:55:54 pm »
Good call on Inferno. (Williams)   :cheers:
Jack Rabbit looks like the other diagonal games, but it definitely uses an 8-way stick.
Moving during game play uses only diagonals, but entering high-score initials uses only up/down/left/right.
EDIT: dgame has a more comprehensive list here, but it still boils down to Q*bert variants, Congo Bongo variants, and Inferno.
« Last Edit: June 25, 2016, 06:24:29 pm by PL1 »
Batchman
« Reply #4 on: June 25, 2016, 07:38:04 pm »
Then it sounds like a -very- good argument for a programmable U360 as opposed to a dedicated rotated 4-way unless one is doing a Q*bert rebuild.  ;D
GeoMan
  • Last login:Yesterday at 01:20:03 pm
« Reply #5 on: June 26, 2016, 07:27:08 am »
Indeed! I use a couple of U360s and work exceptionally well with the above games.
RandyT
  • Last login:September 29, 2025, 06:30:20 am
    • GroovyGameGear.com
« Reply #6 on: June 29, 2016, 10:05:49 am »
Many 8-way sticks use square restriction, and a diamond rotated 45 degrees is... a square.  Just a bit of set-up for the controls in MAME, goes a long way in making these work well for diagonal games.
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« Reply #7 on: June 29, 2016, 08:07:24 pm »
Does Zaxxon play at a diagonal??
« Reply #8 on: June 29, 2016, 08:40:08 pm »
Zaxxon has an isometric perspective, but uses a normal 8-way triggerstick.
You can see that the carriage bolts are parallel with the monitor and microswitches are in the standard positions (not rotated) on pg 50 of the manual here.
Mr. Peabody
  • Last login:March 05, 2025, 05:44:10 pm
« Reply #9 on: July 06, 2016, 01:34:59 am »
In my experience, 8-ways typically have narrow diagonals. I won't play diagonal games without a properly-oriented stick.
RandyT
« Reply #10 on: July 06, 2016, 02:44:56 am »
Most of the square restricted 8-ways use microswitches with blade actuators.  They can be adjusted, if necessary, to make the diagonal actuation zone larger.
