Author Topic: Cabinet Mock Up  (Read 1680 times)
Lucky S.O.B.
  • Last login:June 02, 2021, 03:02:50 pm
  • Mmmmm.... Donuts!
Cabinet Mock Up
« on: June 03, 2016, 11:23:38 pm »
All,
I starting the planning phase of my build and I see a lot of different ways people are mocking up their builds... What software are people using to do these 3-D designs that they can rotate and view from different angles?
Also there used to be a site with templates for the different controller/button layouts is this still around?
Finally I have seen a few mock ups done full size in cardboard, cant decide if they are geniuses or wasting time... Thoughts?
n3wt0n
Re: Cabinet Mock Up
« Reply #1 on: June 04, 2016, 12:23:55 am »
People around here typically use sketchup for their 3D stuff. http://www.sketchup.com/
Autocad also makes a free modeling software called 123d www.123dapp.com/
The site with button layouts is slagcoin. There is a lot of other good info on that site as well but here is a link to the buttons page. http://www.slagcoin.com/joystick/layout.html
I don't think a full size cardboard mockup is necessary but some people do. If you are doing something radically different I can see doing a trial or a 1/2 size mockup. I do cardboard mock up of smaller pieces to make sure the lines are right but then again I don't take the time to do any 3D modeling. Totally a personal call on that one.
Good luck. I hope to see your post in the project announcements soon.  ;)
JDFan
Re: Cabinet Mock Up
« Reply #2 on: June 04, 2016, 08:52:04 am »
All,
1. Pretty much any 3d modeling software can be used if you are familiar with them as mentioned sketchup is pretty widely used and there is a pretty good library of cabinets that can be downloaded as a starting point but also 3ds max or Blender could also be used.
2. Covered by n3wt0n
3. The cardboard mockups are a good idea if building something different to test the actual look and feel without spending $ on it and then finding out it is not comfortable to play on etc.
matsadona
Re: Cabinet Mock Up
« Reply #3 on: June 08, 2016, 03:56:41 am »
I have done downscaled cardboard mockups for my builds. Perhaps I'm old school, but it gives med a better feeling for the design to actually "see" it.
But since then I have learned Sketchup and got myself a 3D printer, so perhaps it will be done digitally for the next build...
« Last Edit: June 08, 2016, 03:59:49 am by matsadona »
