Author Topic: Arcade Monitor or PC Monitor  (Read 1902 times)
killbill
  • Last login:December 01, 2025, 07:27:26 pm
  • When I die, I want to go to arcade heaven!
« on: January 16, 2004, 08:44:14 pm »
Hi,
I am a newbie and came across this great site.  I need some serious advice from some of you pros out there.  I searched the forums and never really found the answers to what I'm looking for.  I hope that this hasn't been covered before.  Thanks a lot for your help.
I am in the process of building a cabinet.  I want it to run MAME 32 along with several console emulators including NES, SNES, Sega Genesis, Atari, Colecovision, Neo Geo, Game Gear, Sega Master System, N64, Daphne.  Now here's the decision I have to make:
1.  Use cabinet's existing 25" arcade monitor (I don't know what model or wattage), or
2.  Scrap it and use a PC monitor.
My question is, is there a way to run all of these emulators, and games correctly on an arcade monitor?  I'm worried the arcade MAME games will look good, but the console games with have problems displaying properly.
I've heard about the Arcade VGA card, but don't know if this would help in this case.  Please help.
I want to use the arcade monitor, but want the cabinet to be able to play both arcade and console game emulations
Thanks for your time.
Jason
« Last Edit: January 16, 2004, 09:07:02 pm by killbill »
XtraSmiley
  • Last login:November 02, 2024, 06:07:19 pm
  • Kill the Big Dog
Re:Arcade Monitor or PC Monitor
« Reply #1 on: January 16, 2004, 11:16:56 pm »
This is a GREAT question, one I have myself.  Can anyone give some insight?
hearingprotectionBIGDOG@yahooBIGDOG.com
Kill the Dog man.
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: January 17, 2004, 09:22:41 am »
If the arcade monitor is a standard (15kHz) or extended resolution (16.5kHz) type, it should be perfect for console emulation!
A standard resolution arcade monitor is the same resolution as a regular television. Can't get closer to the original than that. :D
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #3 on: January 17, 2004, 07:03:44 pm »
The ArcadeVGA is great for console emulation, especially if you can find ones that run at the native resolution fo the console.
In Daphne, you have to turn off hardware acceleration, but that's the only issue for the uses you mentioned.
