Running a M3129 tri-sync and XT2400HD. My Win7 64b and latest GA ASIO build works fine, except... The medium resolutions are way off. I've used the latest beta of CRT emu driver, but for example MK2 "does not start" -> blank screen. If I run it from cmd it shows: "SwitchRes: [mk2] horizontal (400x256@54.706841)->(768x512@54.706841)
That's way beyond my monitor spec (if I've understood this correctly). What's wrong in my setup?
I agree, I'm no pro here, but is this my fault, or what?
Thanks again guys, I know you have the answer
*edit*
I just ran Arcade OSD and noticed that there's no such resolution as 400 x 256 in the list (and not something even close/doubled). I've ran VMM, but it generated only 20 resolutions (no errors were shown) and there are no resolutions with 400 pixels horizontal width at all.
Might this be the cuplrit here?
Vertical games work fine and also 15Khz games are working properly.Just switched from Linux to Win7, so everything related to ArcadeOSD and VMM is kinda new to me.
*SOLVED* Just had to rerun vmmaker
