Author Topic: Golden Tee Live 2010 PC problems  (Read 19788 times)
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
Re: Golden Tee Live 2010 PC problems
« Reply #40 on: June 18, 2016, 06:33:35 am »
that's what I was after..
thk-u for chiming in shawn
ed
Any luck with sound problem? Ed
ed12
« Reply #41 on: June 18, 2016, 11:50:47 pm »
this is what we are yacking about (compare-manual-please) >sound chip is important<
ed
Spitfire
« Reply #42 on: June 19, 2016, 07:37:08 am »
ed
Can you please clarify what you need me to do Ed? What is the end result?? Is it an easy fix or is it just better to buy another motherboard that as the right sound hardware?
« Last Edit: June 19, 2016, 07:57:53 am by Spitfire »
ed12
« Reply #43 on: June 19, 2016, 11:59:14 am »
at this point spitfire the last pdf I upload is the board best used to fit your needs and correct the problem.
unless u are good at Linux ?
ed
Spitfire
« Reply #44 on: June 19, 2016, 06:40:07 pm »
ed
So to fix the sound problem you suggest to replace the motherboard that you already told me to buy earlier in this thread with a D865GBF board as per the manual you posted now.  Is that right?
lilshawn
  • Last login:Yesterday at 05:55:53 pm
« Reply #45 on: June 19, 2016, 08:50:36 pm »
unless you can manage to somehow configure the linux installtaion to use the different? (if it's different) sound chip on board.
have you tried the audio output from the HDMI port on the videocard?
Spitfire
« Reply #46 on: June 19, 2016, 09:07:49 pm »
I will try to run the sound directly off the motherboard and see what happens. As it is runninh from the little power board left of pc to the io board and then out the jamma harness to the speakers. May this make a difference?
As the Video card im running doesnt have a hdmi sound output only 2 dvi plugs. Its a nvidia gt6600 card.
lilshawn
« Reply #47 on: June 19, 2016, 10:39:01 pm »
yeah, the flat cable that plugs onto the motherboard basically taps the front panel header connection for use out the back RCA's... switching to the headphone on the rear won't help. it's more or less the exact same output.
the 6600GT is a really old card. i'm surprised it still works.
they switched from the 6600 to a 7600...then a 9500 the 9500GT was the first card they used that had HDMI (used SPDIF from the mobo for HDMI audio)
the GT430 card after that was the first card used in the Golden tee's that have a separate audio encoder device for the HDMI.
ed12
« Reply #48 on: June 19, 2016, 10:59:09 pm »
from what i read and know
i posted on  it >the sound chip dose indeed vary<
now i do not work for its but lord knows when we did up-dates like that >hardware< we would include as a matter of course older
audio chips,if the mfg of the board did a up-date mid stream,then there is no way without sending out a tsb and patch file we could offer support.
shawn hit on a good point
worth a try
dead board to running is not to bad
ed
Spitfire
« Reply #49 on: June 19, 2016, 11:09:26 pm »
Thx Shawn for the insight mate. Unfortunately this game is running on a old style Jamma golden tee cab with medium resolutiin old school moniter thats the reason for the old school video card i guess. I need to get this cab running sound. So is the better or cheaper option buying a new motherboard as ed suggested for the second time? And if so can you confirm that the one ed suggested D865GBF is the biard to buy? Or is there a better one? Or is the better option to buy new video card? If so please confirm exact one that will donthe job? Either way just want to buy and get this sucker working! Ha ha
Also have this board on its way will this do the job correctly??
https://www.ebay.com.au/itm/131233015650
As for your comments ed always unsure exactly what you mean or need me to do. Ha ha pardon  my ignorance!
lilshawn
« Reply #50 on: June 19, 2016, 11:18:53 pm »
sent you a PM.
I will also get back to you first thing in the AM regarding board model numbers.
ed12
« Reply #51 on: June 20, 2016, 12:44:41 am »
its no problem mate
glad shawn is on board to help
3 minds will get it worked out
what we need to keep in mind
is its-gamming did a few different things.
and a company in usa found a way to mix and match it worse >bmgamming< for 1
will sell u a converison kit
blackhawk - mix and match parts (gen1-2)
so it was like a bag of nuts@bolts different grab a whole new hand full
ed
Spitfire
« Reply #52 on: June 20, 2016, 02:00:53 am »
So what i understand from all this discussion is that a realtek sound board codec is the one we need to get the sound to run as the other board i bought although it being a lga775 chipset which will run the game the sound chip was a sigmatel or something which it doesnt like and hense no sound. So saying all this looking to buy this  motherboard will it work?
https://www.ebay.com.au/itm/141711782079
« Last Edit: June 20, 2016, 08:02:42 am by Spitfire »
lilshawn
« Reply #53 on: June 20, 2016, 10:57:04 am »
okay, so the computer I currently have by my desk here is a GT live 2013 so it's board might be newer than what was available during the 2010 time... thus, may not have built in driver support in 2010 for the newer board.
I will post the model # for posterity's sake.
This GT2013 computer has an Intel DB65AL motherboard with 1 GB factory supplied ram.
so I can absolutely confirm that model board will work with GT versions 2013/14/15/16 and so on into perpetuity. I cannot confirm any backwards compatibility from 2013 as I'm not sure when driver support was added.
as for your suggested board...
I know of a D915GUX board, i'm unsure of the year it was introduced. it is a confirmed GT model number though.
i'm, not sure what the difference between the D915GRV and the D915GUX boards are, but it could be quite significant... it could be inconsequential. it could be as trivial 4 vs 2 sata ports....it could be a totally different northbridge chipset to different CPU compatibility... this is the reason intel boards are kind of a bugger to source...they have literally endless variations of the same board. for our setup here, you pretty much have to source an exact replacement model number.
I'll keep digging up model information and post it here as I get it.
lilshawn
« Reply #54 on: June 20, 2016, 01:35:52 pm »
I have here what appears to be an old target toss/ Bags nighthawk computer one of the other vendors literally just brought in for me to repair....so to add to the list...
it is a Intel DG965SS it has some kind of sigmatel audio chipset STAC9227 ? (hard to read)
Spitfire
« Reply #55 on: June 20, 2016, 07:13:12 pm »
It seems to be a bit of a hit and miss mate as the board that isnt working at the moment is an intel board D975XBX2 with the same sigmatel audio chipset 9227 but why no sound with GT 2010 live???? Will try the board posted above with realtek audio chip and report back how i go.
mclovin
  • Last login:March 03, 2025, 11:17:30 am
  • GT newbie
« Reply #56 on: June 21, 2016, 01:50:26 am »
Mine is a D915GUX and it was an original 2005 LIVE, I bought it with 2009 installed and now 2016.
Spitfire
« Reply #57 on: June 21, 2016, 06:06:10 am »
I have 3 of those D915GUX boards and not one of them work. Thats what started this thread. All power on and fans spin but nothing apears on screen or loads. Maybe i shoild look to someone fixing these motherboards. Where or who would i look to repairing these??
lilshawn
« Reply #58 on: June 21, 2016, 01:42:59 pm »
I've seen one a few weeks ago that specifically does golden tee nighthawk boards.  If I recall it was 30 bucks for the estimate and bout 100 to fix.  Comes with some kind of warranty.
All in,  I think a guy could buy a used board for about the same price.  So either way at that point.
When I'm not on my phone and back at the  computer,  I'll dig through my history and see if I can find it.
Spitfire
« Reply #59 on: June 24, 2016, 06:54:37 pm »
So the intel D915GRV motherboard arrived and i am back in the game with all working as it should. This board has realtek sound driver. I will try that old board on the 2016 upgradr and see if i get sound on it?? Thx All for help.
lilshawn
« Reply #60 on: June 24, 2016, 07:19:50 pm »
mclovin
  • GT newbie
« Reply #61 on: June 24, 2016, 07:24:57 pm »
Hey lilshawn, just wondering if motherboard failure is common with these units? I'm wondering if maybe I should pick one up as a spare while they are available?
ed12
« Reply #62 on: June 24, 2016, 08:04:00 pm »
yes they are
caps/video /fans
common crap
ed
lilshawn
« Reply #63 on: June 24, 2016, 08:25:51 pm »
it's pretty common.
basically if you see blown caps and it still works, replace them. it'll probably be okay.
if it's dead and you open it up and the caps are blown...your chances of resurrecting it are 50/50...and then it's likely not going to be reliable. (random crashes...reboots etc.)
basically if you can get to it BEFORE its a problem, your golden.
Spitfire
« Reply #64 on: July 06, 2016, 02:21:19 am »
So the old GT LIVE dedicated cab with 2 screens is what i have. I was told by Scott at IT that it is no longer supported and the offline versions i have 2016 and 2013 GT Live no longer support this cab so my 2nd screen is upside down. The dip switch that flips the screen is also no longer supported on the offline version. So to cut a long story short had to manually flip the 2nd screen which was a big pain in the butt. Urghhh!!
lilshawn
« Reply #65 on: July 06, 2016, 11:39:33 am »
such is the arcade operator life.  :dunno
companies abandon their hardware and we are left holding the bag.
manually flipping the screen is a huge PITA but you got it  :cheers: at least the screen still works instead of just displaying garbage, clone of the main screen, or worse yet...nothing anymore.
ed12
« Reply #66 on: July 06, 2016, 12:50:08 pm »
ya..
like I said they drop support at a whim
at 1 time I thought 10 years was going to be there bench mark
now days it is more like 2 if u are lucky
ed
Spitfire
« Reply #67 on: July 07, 2016, 06:12:17 am »
Second screen is worthless in the offline version as it only clones main screen. Disaster!!
lilshawn
« Reply #68 on: July 07, 2016, 10:29:55 am »
*sad trombone*
awww that sucks.
mclovin
  • GT newbie
« Reply #69 on: July 08, 2016, 10:47:05 pm »
Yes I found the same problem, has to flip the top monitor with my 2015 unplugged and then has to flip it back again for 2016 home online.
ed12
« Reply #70 on: July 08, 2016, 11:19:20 pm »
truly I need to rotf and lol....
think exactly what is the second screen for exactly...
hum >>>>>live<<<< hum the name  GOLDEN TEE LIVE
it is easy to understand the theory here
you are to be playing with another "group" of ppl u never met ON LINE
ed
ed12
« Reply #71 on: July 09, 2016, 01:09:29 am »
here is another pick up for the dog "pgaserver"...
snag a copy of the "cid" chip...it is not locked....
embed the "cid" code call....SERVE AWAY.....
ed
