Author Topic: model2 in hyperspin execute in background  (Read 2929 times)
eldiego
  • Last login:June 07, 2024, 11:18:22 pm
  • I do my daytona twin, arcade 4 players and vpin!!!
« on: May 17, 2016, 11:29:42 pm »
Hi, i am having problems with model2 and hyperspin, when i run a game of model 2 from hp in the first start appear correctly, but if i return to list of model 2 and run the same or other game this time the game run in background. Any idea? with mame list and hp i don īt have any problem.
  • Moderator
Re: model2 in hyperspin execute in background
« Reply #1 on: May 18, 2016, 11:51:25 am »
I don't use Hyperspin, but I do remember that model 2 emulator won't close completely via a keyboard key.  You have to use some other program to close it.
I used a program called closemul to make the escape key close it.
It could be that model 2 is exiting the game, but not the emulator.
Is Model 2 exiting completely when you exit the game?
(is it still running in task manager?)
eldiego
« Reply #2 on: May 18, 2016, 11:13:16 pm »
yes it close completely. Is very stranger because the first time open normal, second time no open (if i press esc return to normally list hyperspin). Out of hyperspin works fine. i was making a lot of test and nothing. I have other daytona module with no problems.
« Last Edit: May 18, 2016, 11:19:02 pm by eldiego »
eldiego
« Reply #3 on: May 19, 2016, 12:34:20 pm »
is something about my nvidia drivers 175.31 because i open a game from hp (mame or model 2) in the task manager it appear nvsvc32.exe, when i exit the game emulator close but this file remains in the task m. If i kill this process work fine one and every times that i open the model2 game.
i need a command to add in a hyperlaunch ahk to kill this process when model 2 start. If anybody can help me i appreciate
  • Last login:February 21, 2026, 05:58:33 pm
« Reply #4 on: May 19, 2016, 01:49:42 pm »
nvsvc32.exe is the network verification service in windows.  I don't want to scare you, but having that service hang is often a symptom of a corrupted windows install and/or malware.  You might want to run an anti-malware app just to be on the safe side.
