Author Topic: GroovyMAME suddenly broken for me :(  (Read 6202 times)
RobeeJ
  • Last login:August 20, 2025, 03:36:59 am
« on: May 02, 2016, 05:22:42 pm »
This week after booting up my MAME cabinet, groovymame has gone kaput and started hitting 100% cpu on launch and no visual indicator it is running, other than a tiny white line in the top right and bottom left corners of my LCD monitor. :/
I've not changed anything afaik, and I've gone back and tried older GMs and they all show the same problem. I'm so confused. :(
I'm running Arch Linux, and I've tried downgrading SDL2 and mesa which are the only things I can think of that may have been updated. After clutching at straws I now get the monitor flashing this:
fD: 6.6Mhz (in red, outside of it's range)
fH: 15.6kHz (in red, outside of it's range)
fV: 60.0Hz (not in red, so within it's spec)
Downloading the official Linux binaries from mamedev.org I can run it fine with SDL, but GM won't run with anything so I presume this could be switchres related?
Default config changes are just:
Code: [Select]
modeline_generation       0
monitor                   lcd
GroovyMame is definitely running but may possibly be running at full speed with no throttling, here's a log:
Code: [Select]
SwitchRes: v0.015m, Monitor: generic_15, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15625.00-15750.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,192,288,448,576
SwitchRes: Found output connector 'DVI-I-1'
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.015m:[empty] Calculating best video mode for 640x480@61.000000 orientation: normal
SwitchRes: (   1)x(   1)_(60=60.000000Hz)
   rng(0):  640 x 480_60.576923i 15.780289 [integ] scale(1, 1, 1) diff(0.00, 0.00, -0.4231) ratio(1.000, 1.000)
SwitchRes: [empty] (1) horizontal (640x480@61.000000)->(640x480@60.576923)
SwitchRes: Modeline "640x480_60 15.780289KHz 60.576923Hz" 13.129200 640 664 728 832 480 482 488 521 interlace  -hsync -vsync
SwitchRes: Running 'xrandr  --newmode "640x480_60.576923" 13.129200 640 664 728 832 480 482 488 521 interlace  -hsync -vsync'
SwitchRes: Running 'xrandr  --addmode DVI-I-1 "640x480_60.576923"'
SwitchRes: Running 'xrandr  --output DVI-I-1 --mode "640x480_60.576923"'
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -autoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -nomultithreading
SwitchRes: Setting option -nosyncrefresh
SwitchRes: Setting option -nowaitvsync
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -nounevenstretch
SwitchRes: Setting option -filter
SwitchRes: Setting option -prescale 1
Available videodrivers: x11 wayland dummy
Current Videodriver: x11
Display #0
Renderdrivers:
    opengl (0x0)
opengles2 (0x0)
  opengles (0x0)
  software (0x0)
Available audio drivers:
pulseaudio
alsa
dsp
disk
dummy
Build version:      0.171 (May  1 2016)
Build architecure:
Build defines 1:    SDLMAME_UNIX=1 SDLMAME_X11=1 SDLMAME_LINUX=1
Build defines 1:    LSB_FIRST=1 PTR64=1 SYNC_IMPLEMENTATION=tc
SDL/OpenGL defines: SDL_COMPILEDVERSION=2003 USE_OPENGL=1
Compiler defines A: __GNUC__=5 __GNUC_MINOR__=3 __GNUC_PATCHLEVEL__=0 __VERSION__="5.3.0"
Compiler defines B: __amd64__=1 __x86_64__=1 __unix__=1
Compiler defines C: __USE_FORTIFY_LEVEL=0
Enter init_monitors
Adding monitor screen0 (640 x 480)
Leave init_monitors
Enter sdlwindow_init
Using SDL multi-window OpenGL driver (SDL 2.0+)
/dev/dri/card0 successfully opened
Hints:
SDL_FRAMEBUFFER_ACCELERATION             (null)
SDL_RENDER_DRIVER                        (null)
SDL_RENDER_OPENGL_SHADERS                (null)
SDL_RENDER_SCALE_QUALITY                 (null)
SDL_RENDER_VSYNC                         (null)
SDL_VIDEO_X11_XVIDMODE                   (null)
SDL_VIDEO_X11_XINERAMA                   (null)
SDL_VIDEO_X11_XRANDR                     (null)
SDL_GRAB_KEYBOARD                        (null)
SDL_VIDEO_MINIMIZE_ON_FOCUS_LOSS         (null)
SDL_IOS_IDLE_TIMER_DISABLED              (null)
SDL_IOS_ORIENTATIONS                     (null)
SDL_XINPUT_ENABLED                       (null)
SDL_GAMECONTROLLERCONFIG                 (null)
SDL_JOYSTICK_ALLOW_BACKGROUND_EVENTS     (null)
SDL_ALLOW_TOPMOST                        (null)
SDL_TIMER_RESOLUTION                     (null)
SDL_RENDER_DIRECT3D_THREADSAFE           (null)
SDL_VIDEO_ALLOW_SCREENSAVER              (null)
SDL_ACCELEROMETER_AS_JOYSTICK            (null)
SDL_MAC_CTRL_CLICK_EMULATE_RIGHT_CLICK   (null)
SDL_VIDEO_WIN_D3DCOMPILER                (null)
SDL_VIDEO_WINDOW_SHARE_PIXEL_FORMAT      (null)
SDL_VIDEO_MAC_FULLSCREEN_SPACES          (null)
SDL_MOUSE_RELATIVE_MODE_WARP             (null)
SDL_HINT_RENDER_DIRECT3D11_DEBUG         (null)
SDL_VIDEO_HIGHDPI_DISABLED               (null)
SDL_HINT_WINRT_PRIVACY_POLICY_URL        (null)
SDL_HINT_WINRT_PRIVACY_POLICY_LABEL      (null)
SDL_HINT_WINRT_HANDLE_BACK_BUTTON        (null)
Leave sdlwindow_init
Enter sdl_info::create
OpenGL: nouveau
OpenGL: Gallium 0.4 on NVC8
OpenGL: 3.0 Mesa 11.2.1
OpenGL: texture rectangle supported
OpenGL: non-power-of-2 textures supported (new method)
OpenGL: vertex buffer supported
OpenGL: pixel buffers supported
OpenGL: framebuffer object supported
OpenGL: GLSL supported, but disabled
OpenGL: max texture size 16384 x 16384
Leave renderer_ogl::create
Keyboard: Start initialization
Input: Adding Kbd #0: System keyboard
Keyboard: Registered System keyboard
Keyboard: End initialization
Mouse: Start initialization
Input: Adding Mouse #0: System mouse
Mouse: Registered System mouse
Mouse: End initialization
Joystick: Start initialization
Input: Adding Joy #0: Ultimarc IPAC 2 Ultimarc IPAC 2
Joystick: Ultimarc IPAC 2 Ultimarc IPAC 2
Joystick:   ...  4 axes, 32 buttons 1 hats 0 balls
Joystick:   ...  Physical id 0 mapped to logical id 1
Joystick: End initialization
output: unable to open output notifier file /tmp/sdlmame_out
Audio: Start initialization
Audio: Driver is pulseaudio
Audio: frequency: 48000, channels: 2, samples: 256
sdl_create_buffers: creating stream buffer of 25600 bytes
Audio: End initialization
Region ':user1' created
Searching font Liberation Sans in -fontpath
font Liberation Sans is not TrueType or BDF, using MAME default
OpenGL: VBO supported
OpenGL: PBO supported
OpenGL: FBO supported
OpenGL: using vid filter: 1
Starting No Driver Loaded ':'
  (missing dependencies; rescheduling)
Starting Video Screen ':screen'
Optional device 'finder_dummy_tag' not found
Mameinfo.dat games found = 9501
Mameinfo.dat drivers found = 1330
Rev = v0.172
Command.dat games found = 632
Messinfo.dat games found = 2351
Messinfo.dat drivers found = 672
Rev = v0.171
Sysinfo.dat games found = 735
Rev = 2012-09-11.
History.dat games found = 26946
History.dat softwares found = 52879
Rev = 1.72
Any ideas? :(
Calamity
  • Moderator
  • Last login:January 26, 2026, 05:28:27 pm
  • Quote me with care
Re: GroovyMAME suddenly broken for me :(
« Reply #1 on: May 03, 2016, 09:09:06 am »
Code: [Select]
monitor                   lcd
These options are definitely not being used, check your log, it's using the default generic_15 which obviously outputs 15 kHz.
« Last Edit: May 03, 2016, 09:11:32 am by Calamity »
Steps to create a log:
ozfalcon
  • Last login:November 30, 2025, 12:40:52 am
  • ZSystem
« Reply #2 on: May 03, 2016, 07:42:36 pm »
Any ideas? :(
Possibly you have a double entry and the last entry is the generic_15, Check your entire mame.ini for any other monitor lines...?
« Last Edit: May 03, 2016, 07:44:40 pm by ozfalcon »
RobeeJ
« Reply #3 on: May 04, 2016, 07:15:51 am »
Thanks guys, (sorry for the delay in replying the forums are so slow and 500ing all over the place).
I think Calamity is right, I suspect I may have updated the arch linux sdlmame package without realising it and somehow it is now using that config rather than the one it should be.
RobeeJ
« Reply #4 on: May 04, 2016, 06:18:13 pm »
Right, uninstalled sdlmame package, removed ~/.mame directory, searched entire HDD and ensured only one mame.ini exists, and also ran groovymame to check config, it's definitely running the same old config as it ever was. :(
Code: [Select]
robee@mame:/home/mame$ ./groovymame -showconfig | grep lcd
monitor                   lcd
lcd_range                 auto
robee@mame:/home/mame$ ./groovymame -showconfig | grep monitor
monitor                   lcd
I think tomorrow I'll install expac and try to see all the packages I've installed in the last month to see what has been updated that might have caused it.
ozfalcon
  • ZSystem
« Reply #5 on: May 04, 2016, 08:35:20 pm »
From my understanding, If your using GM 171, Then that includes (Doozers) patch that corrects out of focus window for SDL 2.0.4.
ie. You should not need to downgrade SDL2 to 2.0.3.
« Last Edit: May 04, 2016, 08:38:32 pm by ozfalcon »
ozfalcon
  • ZSystem
« Reply #6 on: May 04, 2016, 08:40:01 pm »
Also, Whats going on here?
Are you using 0.172 dat files on Mame 0.171 or something I'm not understanding?
Code: [Select]
Rev = v0.172
Rev = v0.171
Rev = 2012-09-11.
Rev = 1.72
ozfalcon
  • ZSystem
« Reply #7 on: May 05, 2016, 12:46:11 am »
Another thought is that for some reason GM is unable to find/load your Mame.ini and it's reverting to the default (generic_15).
+   { OPTION_MONITOR ";m",                               "generic_15",OPTION_STRING,     "Monitor type, e.g.: generic_15, arcade_15, lcd, custom, etc." },
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #8 on: May 05, 2016, 05:00:26 am »
Hi there,
I have also ran 0.172 sets with groovymame 0.171 for a while without any trouble ;-) The sdl library does not affect how the mame.ini file is processed. Any particular reason to mention SDLmame in your post? (could be a typo)
Based on the groovymame build date, I can see that you are using a different built compare to those available on the google drive. Have you already tried one of the those?
Code: [Select]
v0.171 (Feb 24 2016) [good] - versus - 0.171 (May  1 2016) [personal build?]
RobeeJ
« Reply #9 on: May 05, 2016, 04:09:27 pm »
I'm running a 171 set with 171 groovymame. I mentioned sdlmame because I'd had that installed as a package on arch linux and a recent pacman update had upgraded it, and it creates its own ini file that I thought GM might be using, but it isn't. :/
Running GM with -showconfig lists the config I'd expect it to be using, it's very strange.
RobeeJ
« Reply #10 on: May 12, 2016, 04:54:34 pm »
I've tried downgrading mesa, mesa-libgl, xorg-server, xorg-server-common and sdl2. I've also made sure it is using the correct mame.ini file.
Latest log file seems to show it's trying to do the right mode:
Code: [Select]
SwitchRes: v0.015m, Monitor: lcd, Orientation: horizontal, Modeline generation: disabled
SwitchRes: Using default vfreq range for LCD 59.000000-61.000000
SwitchRes: Creating automatic specs for LCD based on VESA GTF
SwitchRes: Monitor range 73278.00-75762.00,59.00-61.00,0.696,1.044,1.740,0.013,0.040,0.510,0,1,1200,1200,0,0
SwitchRes: -resolution was set at command line or in .ini file as 1600x1200@60
SwitchRes: v0.015m:[pacman] Calculating best video mode for 224x288@60.606060 orientation: rotated
SwitchRes: [1600]x[1200]_[60=60.000000Hz]
   rng(0): 1600 x1200_60.000000p 0.000000 [integ] scale(4, 4, 1) diff(0.44, 5.48, -0.6061) ratio(7.143, 4.167)
SwitchRes: [pacman] (1) vertical (224x288@60.606060)->(1600x1200@60.000000)
SwitchRes: Setting option -noautoror
SwitchRes: Setting option -multithreading
SwitchRes: Setting option -nofilter
SwitchRes: Setting option -prescale 3
Display #0
Renderdrivers:
    opengl (0x0)
opengles2 (0x0)
  opengles (0x0)
  software (0x0)
pulseaudio
alsa
dsp
disk
dummy
Build architecure:
Enter init_monitors
Adding monitor screen0 (1600 x 1200)
Leave init_monitors
Hints:
OpenGL: nouveau
sdl_create_buffers: creating stream buffer of 18432 bytes
Region ':maincpu' created
Region ':gfx1' created
Region ':proms' created
Region ':namco' created
Starting Pac-Man (Midway) ':'
Optional shared pointer 'patched_opcodes' not found
Optional shared pointer 'rocktrv2_prot' not found
Optional shared pointer 's2650_tileram' not found
Optional shared pointer 's2650_spriteram' not found
Starting Z80 ':maincpu'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Speaker ':mono'
Starting Namco ':namco'
Rev = v0.172
Rev = v0.171
Rev = 2012-09-11.
Rev = 1.72
Here is a list of packages that have been updated recently:
Code: [Select]
2016-04-30 17:59:16 tzdata
2016-04-30 17:59:17 fontconfig
2016-04-30 17:59:17 gdk-pixbuf2
2016-04-30 17:59:17 glib2
2016-04-30 17:59:17 gtk-update-icon-cache
2016-04-30 17:59:17 harfbuzz
2016-04-30 17:59:21 cracklib
2016-04-30 17:59:21 elfutils
2016-04-30 17:59:21 iptables
2016-04-30 17:59:21 libelf
2016-04-30 17:59:21 libmnl
2016-04-30 17:59:21 libnftnl
2016-04-30 17:59:21 libutil-linux
2016-04-30 17:59:21 util-linux
2016-04-30 17:59:22 libxml2
2016-04-30 17:59:22 texinfo
2016-04-30 17:59:23 librsvg
2016-04-30 17:59:23 mesa-libgl
2016-04-30 17:59:23 pango
2016-04-30 17:59:24 adwaita-icon-theme
2016-04-30 17:59:24 alsa-lib
2016-04-30 17:59:24 alsa-utils
2016-04-30 17:59:24 archlinux-keyring
2016-04-30 17:59:26 inputproto
2016-04-30 17:59:31 at-spi2-atk
2016-04-30 17:59:31 at-spi2-core
2016-04-30 17:59:31 atk
2016-04-30 17:59:31 btrfs-progs
2016-04-30 17:59:31 sqlite
2016-04-30 17:59:32 colord
2016-04-30 17:59:32 dconf
2016-04-30 17:59:32 desktop-file-utils
2016-04-30 17:59:32 device-mapper
2016-04-30 17:59:32 dhclient
2016-04-30 17:59:32 dhcp
2016-04-30 17:59:32 dhcpcd
2016-04-30 17:59:32 f2fs-tools
2016-04-30 17:59:32 iproute2
2016-04-30 17:59:33 ffmpeg
2016-04-30 17:59:33 libavc1394
2016-04-30 17:59:33 libiec61883
2016-04-30 17:59:33 libraw1394
2016-04-30 17:59:34 glib-networking
2016-04-30 17:59:34 gsettings-desktop-schemas
2016-04-30 17:59:34 json-glib
2016-04-30 17:59:34 libcups
2016-04-30 17:59:34 libsoup
2016-04-30 17:59:34 libxkbcommon
2016-04-30 17:59:34 shared-mime-info
2016-04-30 17:59:34 wayland-protocols
2016-04-30 17:59:35 gtk3
2016-04-30 17:59:36 gtk2
2016-04-30 17:59:37 icu
2016-04-30 17:59:41 firefox
2016-04-30 17:59:41 flashrom
2016-04-30 17:59:41 fltk
2016-04-30 17:59:41 glib2-docs
2016-04-30 17:59:41 grep
2016-04-30 17:59:41 imlib2
2016-04-30 17:59:41 xdg-utils
2016-04-30 17:59:42 iputils
2016-04-30 17:59:42 libinput
2016-04-30 17:59:43 libx86emu
2016-04-30 17:59:43 libxkbcommon-x11
2016-04-30 17:59:46 linux-firmware
2016-04-30 17:59:52 linux
2016-04-30 18:00:07 linux-docs
2016-04-30 18:00:09 linux-headers
2016-04-30 18:00:13 linux-lts
2016-04-30 18:00:27 linux-lts-docs
2016-04-30 18:00:28 linux-lts-headers
2016-04-30 18:00:28 logrotate
2016-04-30 18:00:29 lvm2
2016-04-30 18:00:31 qt4
2016-04-30 18:00:32 qt5-base
2016-04-30 18:00:37 sqlite-doc
2016-04-30 18:00:37 sqlite-tcl
2016-04-30 18:00:38 syslinux
2016-04-30 18:00:38 unzip
2016-04-30 18:00:38 vte-common
2016-04-30 18:00:38 xf86-input-evdev
2016-04-30 18:00:38 xorg-server
2016-04-30 18:00:38 xorg-server-common
2016-04-30 18:00:38 xorg-xinit
2016-05-01 18:06:58 file
2016-05-01 18:06:58 gzip
2016-05-01 18:06:59 git
2016-05-01 18:06:59 libtasn1
2016-05-01 18:06:59 nettle
2016-05-01 18:07:00 gnutls
2016-05-01 18:07:00 libdrm
2016-05-01 18:07:00 libgcrypt
2016-05-01 18:07:00 libgpg-error
2016-05-01 18:07:00 nano
2016-05-01 18:07:26 sdl2
2016-05-01 18:15:18 pacutils
2016-05-02 22:06:15 mesa
2016-05-02 22:25:18 fuse
2016-05-02 22:25:19 ntp
2016-05-02 22:25:19 pacman-mirrorlist
Doozer
  • Z80 ERROR
« Reply #11 on: May 13, 2016, 10:01:17 am »
Here is my package list and associated version. I am running the groovymame binary from the google divre without issue.
Code: [Select]
a52dec                         0.7.4-8
acl                            2.2.52-2
adwaita-icon-theme             3.20-2
alsa-lib                       1.1.1-1
alsa-utils                     1.1.1-1
archlinux-keyring              20160402-1
at-spi2-atk                    2.20.1-1
at-spi2-core                   2.20.1-1
atk                            2.20.0-1
attr                           2.4.47-1
autoconf                       2.69-2
automake                       1.15-1
avahi                          0.6.32-2
bash                           4.3.042-4
bc                             1.06.95-1
binutils                       2.26-4
bison                          3.0.4-2
bluez                          5.39-1
bluez-firmware                 1.2-8
bluez-libs                     5.39-1
bluez-plugins                  5.39-1
bluez-utils                    5.39-1
boost-libs                     1.60.0-4
bzip2                          1.0.6-5
ca-certificates                20150402-1
ca-certificates-cacert         20140824-2
ca-certificates-mozilla        3.23-3
ca-certificates-utils          20150402-1
cairo                          1.14.6-1
cantarell-fonts                1:0.0.24-1
cifs-utils                     6.5-1
colord                         1.3.2-2
compositeproto                 0.4.2-3
coreutils                      8.25-1
cpupower                       4.5-2
cracklib                       2.9.6-1
cryptsetup                     1.7.1-1
curl                           7.48.0-1
damageproto                    1.2.1-3
db                             5.3.28-3
dbus                           1.10.8-1
dbus-glib                      0.106-1
dcadec                         0.2.0-1
dconf                          0.26.0-1
deadbeef                       0.7.2-1
desktop-file-utils             0.22-2
device-mapper                  2.02.150-1
dhcpcd                         6.10.2-1
dialog                         1:1.3_20160209-1
diffutils                      3.3-2
ding-libs                      0.5.0-1
dmxproto                       2.3.1-3
dnssec-anchors                 20150403-1
dos2unix                       7.3.3-1
dosfstools                     4.0-1
downgrade                      5.2.3-1
dri2proto                      2.8-2
e2fsprogs                      1.42.13-1
elfutils                       0.166-1
enca                           1.18-1
expat                          2.1.1-1
faad2                          2.7-4
fakeroot                       1.20.2-1
fbset                          2.1-5
ffmpeg                         1:3.0.2-2
fftw                           3.3.4-1
file                           5.26-2
filesystem                     2015.09-1
findutils                      4.6.0-1
fixesproto                     5.0-3
flac                           1.3.1-3
flex                           2.6.0-3
fontconfig                     2.11.95-1
fontsproto                     2.1.3-1
freeglut                       3.0.0-1
freetype2                      2.6.3-1
fribidi                        0.19.7-1
fuse                           2.9.6-1
gamin                          0.1.10-8
gawk                           4.1.3-1
gc                             7.4.2-4
gcc                            6.1.1-1
gcc-libs                       6.1.1-1
gdbm                           1.11-1
gdk-pixbuf2                    2.34.0-2
gettext                        0.19.7-1
giflib                         5.1.2-1
git                            2.8.2-1
glew                           1.13.0-1
glib-networking                2.48.2-1
glib2                          2.48.0-2
glibc                          2.23-2
glproto                        1.4.17-1
glu                            9.0.0-4
gmp                            6.1.0-4
gnome-themes-standard          3.20-1
gnu-netcat                     0.7.1-5
gnupg                          2.1.12-1
gnutls                         3.4.11-2
gobject-introspection          1.48.0-1
gobject-introspection-runtime  1.48.0-1
gpgme                          1.6.0-2
gpm                            1.20.7-6
graphite                       1:1.3.8-1
grep                           2.25-1
groff                          1.22.3-6
gsettings-desktop-schemas      3.20.0-1
gsm                            1.0.14-1
gssproxy                       0.5.0-3
gtk-engines                    2.21.0-2
gtk-update-icon-cache          3.20.4-2
gtk2                           2.24.30-2
gtk3                           3.20.4-2
gtksourceview3                 3.20.3-1
guile                          2.0.11-3
gzip                           1.8-1
harfbuzz                       1.2.7-1
hdf5                           1.10.0-1
hdparm                         9.48-1
hicolor-icon-theme             0.15-1
htop                           2.0.1-1
hunspell                       1.3.4-1
hwids                          20160306-1
iana-etc                       20160314-1
icu                            57.1-1
imlib2                         1.4.9-1
inetutils                      1.9.4-2
iniparser                      4.0-2
inputproto                     2.3.2-1
iproute2                       4.5.0-2
iptables                       1.6.0-1
iputils                        20160308.0db72a4-1
jansson                        2.7-1
jasper                         1.900.1-15
jfsutils                       1.1.15-4
js17                           17.0.0-3
json-c                         0.12-2
json-glib                      1.2.0-1
kbd                            2.0.3-1
kbproto                        1.0.7-1
keyutils                       1.5.9-1
kmod                           22-1
krb5                           1.13.2-3
lame                           3.99.5-3
lcms2                          2.7-1
ldb                            1.1.26-1
ldns                           1.6.17-4
less                           481-2
libaio                         0.3.110-1
libarchive                     3.1.2-8
libass                         0.13.2-1
libassuan                      2.4.2-2
libasyncns                     0.8-5
libatasmart                    0.19-3
libatomic_ops                  7.4.2-1
libavc1394                     0.5.4-2
libbluray                      0.9.2-2
libbsd                         0.8.3-1
libcap                         2.25-1
libcap-ng                      0.7.7-1
libcddb                        1.3.2-4
libcdio                        0.93-3
libcroco                       0.6.11-1
libcups                        2.1.3-2
libdaemon                      0.14-3
libdatrie                      0.2.10-1
libdbus                        1.10.8-1
libdca                         0.0.5-4
libdmx                         1.1.3-1
libdrm                         2.4.68-1
libebml                        1.3.3-2
libedit                        20150325_3.1-2
libelf                         0.166-1
libepoxy                       1.3.1-1
libevdev                       1.4.6-1
libevent                       2.0.22-2
libexif                        0.6.21-2
libffi                         3.2.1-1
libfm                          1.2.4-1
libfm-extra                    1.2.4-1
libfontenc                     1.1.3-1
libgcrypt                      1.7.0-2
libgpg-error                   1.22-1
libgssglue                     0.4-2
libgudev                       230-1
libgusb                        0.2.9-1
libical                        2.0.0-2
libice                         1.0.9-1
libid3tag                      0.15.1b-8
libidn                         1.32-1
libiec61883                    1.2.0-4
libinput                       1.3.0-1
libjpeg-turbo                  1.4.2-2
libkate                        0.4.1-5
libkeybinder2                  0.3.0-2
libksba                        1.3.4-1
libldap                        2.4.44-1
libmad                         0.15.1b-7
libmikmod                      3.3.8-1
libmnl                         1.0.3-2
libmodplug                     0.8.8.5-2
libmpc                         1.0.3-2
libmpcdec                      1:0.1+r475-1
libnftnl                       1.0.5-1
libnl                          3.2.27-1
libnotify                      0.7.6-2
libogg                         1.3.2-1
libomxil-bellagio              0.9.3-1
libpcap                        1.7.4-1
libpciaccess                   0.13.4-1
libpipeline                    1.4.1-1
libpng                         1.6.21-1
libproxy                       0.4.12-1
libpulse                       8.0-3
libraw1394                     2.1.2-1
librpcsecgss                   0.19-8
librsvg                        2:2.40.15-2
libsamplerate                  0.1.8-3
libsasl                        2.1.26-7
libseccomp                     2.3.1-1
libsm                          1.2.2-2
libsndfile                     1.0.26-1
libsoup                        2.54.1-1
libsoxr                        0.1.2-1
libssh                         0.7.3-1
libssh2                        1.7.0-2
libsystemd                     229-3
libtar                         1.2.20-2
libtasn1                       4.8-2
libthai                        0.1.24-1
libtheora                      1.1.1-3
libtiff                        4.0.6-2
libtiger                       0.3.4-4
libtirpc                       1.0.1-2
libtool                        2.4.6-5
libtxc_dxtn                    1.0.1-6
libunique                      1.1.6-6
libunistring                   0.9.6-1
libunwind                      1.1-3
libusb                         1.0.20-1
libutempter                    1.1.6-2
libutil-linux                  2.28-1
libva                          1.7.0-1
libvdpau                       1.1.1-2
libvorbis                      1.3.5-1
libvpx                         1.5.0-4
libwacom                       0.18-1
libwbclient                    4.4.3-1
libwebp                        0.5.0-1
libwnck                        2.31.0-1
libx11                         1.6.3-1
libx264                        2:148.20160103-1
libxau                         1.0.8-2
libxaw                         1.0.13-1
libxcb                         1.11.1-1
libxcomposite                  0.4.4-2
libxcursor                     1.1.14-2
libxdamage                     1.1.4-2
libxdmcp                       1.1.2-1
libxext                        1.3.3-1
libxfixes                      5.0.1-1
libxfont                       1.5.1-1
libxft                         2.3.2-1
libxi                          1.7.6-1
libxinerama                    1.1.3-2
libxkbcommon                   0.6.1-1
libxkbcommon-x11               0.6.1-1
libxkbfile                     1.0.9-1
libxml2                        2.9.3+14+gd5bd2a9-1
libxmu                         1.1.2-1
libxpm                         3.5.11-1
libxrandr                      1.5.0-1
libxrender                     0.9.9-1
libxres                        1.0.7-1
libxshmfence                   1.2-1
libxt                          1.1.5-1
libxtst                        1.2.2-1
libxv                          1.0.10-1
libxvmc                        1.0.9-1
libxxf86dga                    1.1.4-1
libxxf86vm                     1.1.4-1
libyaml                        0.1.6-1
licenses                       20140629-1
linux-api-headers              4.5.2-1
linux-firmware                 20160315.deb1d83-1
linuxconsole                   1.5.1-1
llvm-libs                      3.8.0-1
logrotate                      3.9.2-1
lshw                           B.02.17-2
lsof                           4.89-1
ltrace                         0.7.3-1
lua                            5.3.2-1
lvm2                           2.02.150-1
lz4                            131-1
lzo                            2.09-1
m4                             1.4.17-1
make                           4.1-4
man-db                         2.7.5-1
man-pages                      4.06-1
mc                             4.8.17-1
mcpp                           2.7.2-5
mdadm                          3.4-1
meld                           3.16.0-1
menu-cache                     1.0.1-2
mesa                           11.2.2-1
mesa-libgl                     11.2.2-1
mime-types                     9-1
mkinitcpio                     19-1
mkinitcpio-busybox             1.24.1-1
mpfr                           3.1.4.p1-1
mpg123                         1.22.4-1
mtdev                          1.1.5-1
nano                           2.5.3-2
nasm                           2.11.08-2
ncurses                        6.0-4
net-tools                      1.60.20130531git-1
netcdf                         4.4.1rc1-1
netctl                         1.11-1
nettle                         3.2-2
nfs-utils                      1.3.3-3
nfsidmap                       0.26-1
npth                           1.2-1
nspr                           4.12-1
nss                            3.23-3
ntfs-3g                        2016.2.22-1
open-iscsi                     2.0_873-7
openal                         1.17.2-2
openbox                        3.6.1-3
opencore-amr                   0.1.3-2
openjpeg                       1.5.2-1
openresolv                     3.7.2-1
openssh                        7.2p2-1
openssl                        1.0.2.h-1
opus                           1.1.2-1
orc                            0.4.25-1
p11-kit                        0.23.2-1
p7zip                          15.14.1-1
package-query                  1.8-1
pacman                         5.0.1-3
pacman-mirrorlist              20160512-1
pam                            1.2.1-3
pambase                        20130928-1
pango                          1.40.1-1
pangox-compat                  0.0.2-2
parted                         3.2-4
patch                          2.7.5-1
pciutils                       3.4.1-1
pcmciautils                    018-7
pcre                           8.38-3
perl                           5.22.2-1
perl-error                     0.17024-1
pinentry                       0.9.7-2
pixman                         0.34.0-1
pkg-config                     0.29.1-1
plymouth-legacy                0.8.8-4
polkit                         0.113-4
popt                           1.16-7
procps-ng                      3.3.11-2
psmisc                         22.21-3
pth                            2.0.7-5
pygobject-devel                3.20.0-1
python                         3.5.1-2
python-beaker                  1.8.0-1
python-mako                    1.0.4-1
python-markupsafe              0.23-3
python-packaging               16.7-1
python-pyparsing               2.1.1-1
python-setuptools              1:21.0.0-1
python-six                     1.10.0-1
python2                        2.7.11-3
python2-beaker                 1.8.0-1
python2-cairo                  1.10.0-2
python2-gobject                3.20.0-1
python2-mako                   1.0.4-1
python2-markupsafe             0.23-3
python2-packaging              16.7-1
python2-pyparsing              2.1.1-1
python2-setuptools             1:21.0.0-1
python2-six                    1.10.0-1
qt5-base                       5.6.0-5
qtchooser                      53-2
randrproto                     1.5.0-1
readline                       6.3.008-3
recode                         3.6-8
recordproto                    1.14.2-2
reiserfsprogs                  3.6.24-1
renderproto                    0.11.1-3
rest                           0.7.93-1
rpcbind                        0.2.3-3
rsync                          3.1.2-1
rtmpdump                       1:2.4.r96.fa8646d-2
ruby                           2.3.1-1
run-parts                      4.7-1
s-nail                         14.8.8-1
samba                          4.4.3-1
schroedinger                   1.0.11-3
sdl                            1.2.15-7
sdl2                           2.0.4-2
sdl2_ttf                       2.0.14-1
sed                            4.2.2-3
sfml                           2.3.2-4
sg3_utils                      1.42-1
shadow                         4.2.1-3
shared-mime-info               1.6-2
slang                          2.3.0-1
smbclient                      4.4.3-1
speex                          1.2rc2-1
speexdsp                       1.2rc3-2
sqlite                         3.12.2-1
startup-notification           0.12-4
strace                         4.11-1
sudo                           1.8.16-1
sysfsutils                     2.1.0-9
syslinux                       6.03-6
systemd                        229-3
systemd-sysvcompat             229-3
taglib                         1.11-1
talloc                         2.1.6-1
tar                            1.28-1
tcpdump                        4.7.4-1
tdb                            1.3.8-1
tevent                         0.9.28-1
texinfo                        6.1-3
thin-provisioning-tools        0.6.1-2
tslib                          1.1-1
ttf-dejavu                     2.35-1
tzdata                         2016d-1
udisks                         1.0.5-2
unzip                          6.0-12
usbutils                       008-1
util-linux                     2.28-1
v4l-utils                      1.10.0-1
vi                             1:070224-2
vid.stab                       1.1-1
videoproto                     2.3.3-1
vim                            7.4.1797-1
vim-runtime                    7.4.1797-1
wayland                        1.10.0-1
wayland-protocols              1.3-1
wget                           1.17.1-2
which                          2.21-1
wireless_tools                 30.pre9-1
wpa_supplicant                 1:2.5-3
x265                           1.9-1
xbitmaps                       1.1.1-3
xcb-proto                      1.11-2
xcb-util                       0.4.0-1
xcb-util-image                 0.4.0-1
xcb-util-keysyms               0.4.0-1
xcb-util-wm                    0.4.1-1
xdotool                        3.20150503.1-1
xextproto                      7.3.0-1
xf86-input-evdev               2.10.2-1
xf86-input-joystick            1.6.2-6
xf86-video-ati                 1:7.7.0-1
xf86-video-fbdev               0.4.4-5
xf86-video-intel               1:2.99.917+645+g88733a7-1
xf86-video-nouveau             1.0.12-1
xf86-video-vesa                2.3.4-2
xf86dgaproto                   2.1-3
xf86vidmodeproto               2.3.1-3
xfsprogs                       4.5.0-1
xineramaproto                  1.2.1-3
xkeyboard-config               2.17-2
xorg-bdftopcf                  1.0.5-1
xorg-font-util                 1.3.1-1
xorg-font-utils                7.6-4
xorg-fonts-100dpi              1.0.3-2
xorg-fonts-alias               1.0.3-1
xorg-fonts-encodings           1.0.4-4
xorg-fonts-misc                1.0.3-4
xorg-fonts-type1               7.7-1
xorg-iceauth                   1.0.7-1
xorg-luit                      1.1.1-2
xorg-mkfontdir                 1.0.7-2
xorg-mkfontscale               1.1.2-1
xorg-server                    1.18.3-1
xorg-server-common             1.18.3-1
xorg-server-utils              7.6-4
xorg-sessreg                   1.1.0-1
xorg-setxkbmap                 1.3.1-1
xorg-utils                     7.6-9
xorg-xauth                     1.0.9-1
xorg-xbacklight                1.2.1-1
xorg-xcmsdb                    1.0.5-1
xorg-xdpyinfo                  1.3.2-1
xorg-xdriinfo                  1.0.5-1
xorg-xev                       1.2.2-1
xorg-xgamma                    1.0.6-1
xorg-xhost                     1.0.7-1
xorg-xinit                     1.3.4-4
xorg-xinput                    1.6.2-1
xorg-xkbcomp                   1.3.1-1
xorg-xlsatoms                  1.1.2-1
xorg-xlsclients                1.1.3-1
xorg-xmessage                  1.0.4-2
xorg-xmodmap                   1.0.9-1
xorg-xprop                     1.2.2-1
xorg-xrandr                    1.5.0-1
xorg-xrdb                      1.1.0-2
xorg-xrefresh                  1.0.5-1
xorg-xset                      1.2.3-1
xorg-xsetroot                  1.1.1-2
xorg-xvinfo                    1.1.3-1
xorg-xwininfo                  1.1.3-1
xproto                         7.0.28-1
xterm                          324-2
xvidcore                       1.3.4-1
xz                             5.2.2-1
yajl                           2.1.0-1
zlib                           1.2.8-4
ozfalcon
  • ZSystem
« Reply #12 on: May 13, 2016, 06:45:17 pm »
ATTACH your mame.ini file too.
RobeeJ
« Reply #13 on: May 14, 2016, 06:27:45 am »
Fixed! Thanks for the suggestions, I finally worked out what was going wrong.
Either hiscore.dat or history.dat from 172 seems to cause it, with my money being in history.dat since it appears to be freezing after Initializing and before it shows the info display.
I'm not sure why that would make it hit 100% cpu but I guess it isn't very tolerant of change.
RobeeJ
« Reply #14 on: May 14, 2016, 06:58:44 am »
How wrong could I be, it's the hiscore.dat which is causing it. I guess 172 version of hiscore is not compatible with 171.
ozfalcon
  • ZSystem
« Reply #15 on: May 14, 2016, 08:48:02 pm »
The hiscore.dat that comes with Mame 0.172 is indeed different formatting (For Lua hiscore support).
The question is how did it get to be in your path for hiscore data?
RobeeJ
« Reply #16 on: May 15, 2016, 02:40:19 pm »
MAME Extras :(
ozfalcon
  • ZSystem
« Reply #17 on: May 15, 2016, 07:14:47 pm »
MAME Extras :(
Is that another package available on Arch?
Or do you mean you copied it from a Mame 0.172 Extras (Art, Titles etc) archive (ie. Zip)?
« Last Edit: May 15, 2016, 07:37:12 pm by ozfalcon »
RobeeJ
« Reply #18 on: May 16, 2016, 02:50:31 am »
From the MAME Extras archive, not a package from Arch.
ozfalcon
  • ZSystem
« Reply #19 on: May 16, 2016, 06:51:33 pm »
Thats good, Nothing extra to keep an eye out for then.
RobeeJ
« Reply #20 on: May 17, 2016, 05:43:42 am »
I don't suppose someone has the MAME 171 hiscore.dat lying around they could attach? :)
I can't seem to find it. :(
ozfalcon
  • ZSystem
« Reply #21 on: May 17, 2016, 06:14:38 pm »
I'm pretty sure a modified hiscore.dat (Lua Script) only came with Mame 0.172 onward.
There is no change from 0.172 to 0.173 Lua Hiscore dat's.
The 0.172 Lua version I think is the same as the latest MKChamp version - But modified for Lua Script.
(The latest MKChamp version is dated 1/7/2015)
