Author Topic: 3 Sided Cocktail JAMMA question  (Read 1213 times)
goren1818
  • Last login:June 01, 2016, 06:24:54 pm
« on: April 10, 2016, 09:02:28 pm »
Hello!
I am brand new to the site. This is my first post. I joined hoping to find an answer to my question. I am looking to build a 3 sided cocktail multicade that rotates like this:
I would love to use this 900-in-1 board: [Link removed as per forum rule # 5]
I figured I would purchase this wiring harness to make life easier: [Link removed as per forum rule # 5]
My question is is this wiring harness all I need for the 4 control panels. I understand this will only be 2 player, but does it already have the double wires on the proper buttons so both player 1 controls and can be hooked up as well as player 2 for both vertical and horizontal play? Does this all make sense? I appreciate all the help! Any other tips for the build would be appreciated.
Thanks,
Goren1818
« Last Edit: April 11, 2016, 12:28:24 pm by DeLuSioNal29 »
goren1818
Re: 3 Sided Cocktail JAMMA question
« Reply #1 on: April 11, 2016, 03:41:06 pm »
I see my two links were removed. My apologies. The wire harness is made specifically for that kind of table and the jamma board is a 900 in 1
rgriesbeck
  • Last login:July 22, 2016, 08:29:42 pm
« Reply #2 on: June 11, 2016, 02:09:54 am »
I'm new here, but I just built a similar machine. I use the ipac4. Works great. My machine isn't setup to automatically rotate, but I just use a keyboard shortcut that is in the monitor driver, which is what I think the video creator did, he just binder it to a button...
