Author Topic: PC has integrated graphics card - Options for running 15khz games?  (Read 2062 times)
jmcginley
  • Last login:September 22, 2023, 12:23:40 pm
I have an ACER Veriton L670G small form factor PC. Unfortunately I cannot change the graphics card because it's integrated into the motherboard.
It was just an extra PC I had lying around and was hoping I could use it in a vertical mame machine with a 25K7191 monitor. I looked at the titles that run at Medium and VGA resolutions in vertical orientation and I'm not interested in playing them, so it will be all Standard Res games on this machine.
I believe Soft-15khz is not compatible with the integrated graphics card, and as far as I can tell there would be no way for me to use ArcadeVGA.
Am I wrong? Will one of those work? If not, are there any other options available? What would be the drawbacks? I'm hoping to get as close to the real thing as possible without spending a ton of money.
dmckean
Re: PC has integrated graphics card - Options for running 15khz games?
« Reply #1 on: March 29, 2016, 03:32:58 pm »
You're not wrong, you can't use this PC for what you want to do. It will not output at 15Khz.
jtslade
  • Last login:February 13, 2025, 10:06:51 pm
  • Keep it looking originallish!
« Reply #2 on: March 29, 2016, 08:11:07 pm »
Get a amd with a Radeon built in for cheap
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
jmcginley
« Reply #3 on: March 29, 2016, 11:40:58 pm »
Well that sucks! Oh well, to eBay for a cheap PC I go!
