Author Topic: VisualBoyAdvance Keyboard Codes  (Read 4865 times)
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
« on: January 15, 2004, 02:50:01 am »
I'm looking for a chart with hexadecimal keyboard codes so I can remap the controls in VisualBoyAdvance-SDL commandline version. So far everything I've found from searching the net doesn't seem right. I want to use a little different key set than Stuzza's MAME keys version.
I'm planning to use a combination of the following keys:
A, B, C, X, Y, Z, Left Alt, Left Shift, Left Control, Space
"Three warps to the Bugger homeworld"
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
Re:VisualBoyAdvance Keyboard Codes
« Reply #1 on: January 15, 2004, 03:19:47 am »
You need to download the SDL Configurator for the SDL version of VisualBoy Advance from the VBA website. The file you need is "SDLTest-Win32.zip" I think?
This has an exe that you run which will give you the values for any key pressed which you can then enter into the VisualBoyAdvance.cfg file.
The VBA site seems to be down at the moment?  i still have the SDLTest program on my Hard Drive and according to me, the keycodes you need are:
A = 0061
B = 0062
C = 0063
X = 0078
Y = 0079
Z = 007a
Left Alt = 0134
Left Shift = 0130
Left Control = 0132
Space = 0020
If you need the program, pm me and I'll send it to you.
arcadecab
  • Last login:September 26, 2007, 06:17:06 pm
« Reply #2 on: January 15, 2004, 10:31:57 am »
I just came across this situation last night.  I am looking to map the keys to my gamepad with VisualboyAdvance-SDL version from Stuzza's site, and I do not know how to do it.  Since it is commandline, there is no gui like the other emulators that has input selection or otherwise as an option.  Is the download you mentioned needed to map the keys to my gamepad or what else can I do?
Thanks.
BTW, Stuzza--I am also trying to get MekaW to remap keys for my gamepad.  I should be able to just click on the key in the configuation menu for Joystick 1 with gamepad selected, but it will not allow me.  Any tips on how to get MekaW to recognize the keys to the gamepad that I use.
Thanks.
stuzza
    • ScreenshotArchive
« Reply #3 on: January 15, 2004, 05:52:10 pm »
Thanks.
Thanks.
If you have no luck setting it up with the gamepad directly, perhaps you could try the JoyToKey program.  Both of the above emulators map fine to keyboard keys, so if you use JoyToKey, you might have more luck.  I havn't used JoyToKey myself, but from what I've heard it is pretty straight forward to use.
Zapper
« Reply #4 on: January 15, 2004, 08:32:33 pm »
Those codes work great. Thanks stuzza ;D
