Author Topic: Groovy Arcade - Final touch to polish my cabinet experience  (Read 3050 times)
Cucurbitacée
  • Last login:October 04, 2021, 02:26:59 pm
« on: March 21, 2016, 03:44:28 pm »
Hi there,
I now have a cabinet fully working with Groovy Arcade. I'm very happy, but my OCD push me to try to adjust a few more things:
  • The display of the splash screen. There a some text information that display before the splash screen. I can see the login information too, as if the splash screen ends too soon. Is it possible to adjust the display of the splash screen so it hides more the system?
  • The rotation of the splash screen. As it's a vertical cabinet, it's now in the wrong direction. Is there already a rotated theme for Plymouth?
  • The display of nag screens. Here is the content of /home/arcade/mame.ini:
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   /home/roms/MAME/roms;
hashpath                  $HOME/hash
samplepath                /home/roms/MAME/samples
artpath                   /home/roms/MAME/artwork
ctrlrpath                 /home/roms/MAME/ctrlr
inipath                   $HOME/.mame;$HOME;.;$HOME/ini
fontpath                  /home/roms/MAME/fonts
cheatpath                 /home/roms/MAME/cheat
crosshairpath             /home/roms/MAME/crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             $HOME/cfg
nvram_directory           $HOME/nvram
memcard_directory         $HOME/memcard
input_directory           $HOME/inp
state_directory           $HOME/sta
snapshot_directory        $HOME/snap
diff_directory            $HOME/diff
comment_directory         $HOME/comments
hiscore_directory         $HOME/hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             1
use_overlays              1
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  0
lightgun                  1
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          1
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           lightgun
positional_device         keyboard
mouse_device              lightgun
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
bios
cheat                     0
skip_gameinfo             1
uifont                    default
ramsize
confirm_quit              1
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
http                      0
http_port                 8080
http_path                 web
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   0
disable_loading_patch     0
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor   generic_15
orientation   vertical
connector                 auto
interlace                 1
doublescan                1
cleanstretch              0
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# DEBUGGING OPTIONS
oslog                     0
watchdog                  0
# PERFORMANCE OPTIONS
multithreading            1
numprocessors             auto
sdlvideofps               0
bench                     0
# VIDEO OPTIONS
video                     opengl
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             0
centerh                   1
centerv                   1
waitvsync                 1
scalemode                 none
# OpenGL-SPECIFIC OPTIONS
filter                    0
prescale                  1
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl   0
gl_glsl_filter            1
glsl_shader_mame0         /home/arcade/CRT/shader/glsl_plain
glsl_shader_mame1         /home/arcade/CRT/CRT-geom
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
gl_glsl_vid_attr          1
# PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect    4:3
resolution                auto
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
switchres                 1
useallheads               0
# SOUND OPTIONS
audio_latency             2
# SDL KEYBOARD MAPPING
keymap                    0
keymap_file               keymap.dat
uimodekey                 SCRLOCK
# SDL JOYSTICK MAPPING
joy_idx1                  auto
joy_idx2                  auto
joy_idx3                  auto
joy_idx4                  auto
joy_idx5                  auto
joy_idx6                  auto
joy_idx7                  auto
joy_idx8                  auto
sixaxis                   0
# SDL LIGHTGUN MAPPING
lightgun_index1           WiiMote0
lightgun_index2           WiiMote1
lightgun_index3           auto
lightgun_index4           auto
lightgun_index5           auto
lightgun_index6           auto
lightgun_index7           auto
lightgun_index8           auto
# SDL LOWLEVEL DRIVER OPTIONS
videodriver               auto
audiodriver               auto
gl_lib                    auto
    It seems the settings below are not working:
Code: [Select]
use_backdrops             1
use_overlays              1
skip_gameinfo             1
confirm_quit              1 <- This was only for test purpose.
    Is there another mame.ini located somewhere else? I'm using Attract Mode too, does it have something to do with this?
Please have a look at this to illustrate my point.
Many thanks in advance. :)
Cucurbitacée
Re: Groovy Arcade - Final touch to polish my cabinet experience
« Reply #1 on: March 25, 2016, 08:20:06 am »
Hi,
I've made some progress, so I'll answer some of my questions myself.
  • The display of the splash screen. From what I understand, there is no smooth transition between Plymouth and Openbox. Could anyone confirm this?
  • The rotation of the splash screen. It seems there is no ready-made vertical theme, but from the documentation, it shouldn't be hard to do.
  • The display of nag screens. I didn't realize that the parameters where taken from ume.ini, not mame.ini. It's now working as intended. :laugh:
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #2 on: March 25, 2016, 10:29:22 am »
You can get ride of the text (login) messages and have smooth transition from plymouth to your front end.
First, in your systemd override file (or autologin) use the following line
Code: [Select]
ExecStart=-/sbin/agetty --autologin arcade --noissue --skip-login --noclear %I 38400 linux
Secondly, within the arcade home folder, edit your .bash_profile and replace the startx line with the following one.
Code: [Select]
startx -- -nocursor -quiet 2>&1 &>  /dev/null
2. Rotation....
You just need to rotate the splash picture located at: /usr/share/plymouth/arch-logo.png
and regenerate your initramfs
Code: [Select]
mkinitcpio -p linux
3. Nag screen....
I do not understand your issue. The setting is right.
Code: [Select]
Cucurbitacée
« Reply #3 on: March 25, 2016, 02:23:18 pm »
Thanks for your support Doozer, it's now almost perfect. I still see some one line text before and after Plymouth splash screen, but I can totally live with that. :applaud:
It seems that on the stock latest Groovy Arcade Linux distribution groovymame is a link to groovyume, so editing mame.ini had no effect because ume.ini is the actual config file. :P
Doozer
  • Z80 ERROR
« Reply #4 on: March 29, 2016, 04:35:27 am »
Happy to hear about your progresses.
In the latest mame releases, ume.ini file does not exist any more. UME and MAME have been merged under the mame name. Therefore, the mame.ini file shall be used instead.
The before splash visuals must be the syslinux/grub bootloader text. This can be hidden by editing the binary and `spacing` the text. Or by editing the source and compiling it.
With the previous modifications, you should only see the cursor underscore character.
