Author Topic: Sequiential shifter  (Read 4233 times)
charliew
  • Last login:February 07, 2020, 08:31:12 pm
Sequiential shifter
« on: February 25, 2016, 08:43:57 pm »
Hi guys! I have never had the chance to try either Model 2 emu or Supermodel. Can you tell if those emulators will work with a sequiential shifter for the 4 speed shifter games?
  • Last login:February 21, 2026, 05:58:33 pm
Re: Sequiential shifter
« Reply #1 on: February 25, 2016, 09:27:07 pm »
I don't think they do.  They all have automatic trans. modes though so you don't need a shifter to play them.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #2 on: February 25, 2016, 09:53:18 pm »
You have to use a shifter hack but it works. Only problem is if you stay in the same game and start a new race it'll hold its position. So if you ended in 4th gear on previous race it'll still be in 4th gear when you start next race.
charliew
Sequiential shifter
« Reply #3 on: February 25, 2016, 09:56:48 pm »
What kind of hack is that? What is it called?
brad808
« Reply #4 on: February 25, 2016, 10:09:17 pm »
Xiaou2
  • Last login:Yesterday at 05:46:32 am
  • NOM NOM NOM
« Reply #5 on: February 26, 2016, 05:09:39 am »
 Most driving games give you higher top speeds,  and higher acceleration,  if you choose manual shifting.
baritonomarchetto
  • Last login:March 02, 2026, 07:09:37 am
« Reply #6 on: February 26, 2016, 05:47:06 am »
Up to my head supermodel actually supports sequential shifting, but my hardware is too low to run SM emu so you should verify
  • Moderator
« Reply #7 on: February 26, 2016, 06:47:34 am »
It does.  The shifter support in supermodel is done right.  I wish MAME and M2 were done the same way.
« Reply #8 on: February 26, 2016, 02:48:56 pm »
Mame's a bit trickier because of the fact that it doesn't detect fake keystrokes, but I think it's doable.
If an app was built that allowed some sort of external communication, mamehooker could reset it back to 1st upon loading a game or other events.  Probably the easiest way to make sure it goes back to 1st would be to reset the gears any time the start button is pressed.  You wouldn't press that while racing but you most likely would press it at least once when going through the menus.
An integrated solution in mame itself is also doable, but it'd be a pain in the butt because the driver for every effected racing game would have to be modified.
  • Moderator
« Reply #9 on: February 26, 2016, 03:25:58 pm »
FYI, Racermame accepts fake keystrokes.
« Reply #10 on: February 27, 2016, 06:53:36 pm »
Well it shouldn't be terribly hard then.  It could probably be done via auto hot key.  It just needs a counter and the ability to monitor the start button and the shiftup/shiftdown buttons.
I'm still debating on if I'll do an analog h-shifter or not.  If I don't I'll write a modified app.
eldiego
  • Last login:June 07, 2024, 11:18:22 pm
  • I do my daytona twin, arcade 4 players and vpin!!!
« Reply #11 on: March 20, 2016, 11:47:57 am »
Yes You need a soft like h2seq. You can download it from http://www.racermame.altervista.org/download.htm
