Author Topic: Howler information request  (Read 1766 times)
ZoOl007
  • Last login:August 02, 2020, 12:03:38 pm
    • RGBcommander
« on: February 24, 2016, 09:47:33 am »
Hi people,
I'm looking to support the howler board in RGBcommander but I have trouble finding the vendor id as I don't know anybody who has such a board.
I know 4 boards are supported Device IDs 0x6800-0x6803 but what's the vendorID ? I can't contact the manufacturer for some reason... :cry:
If someone would be willing to share that info - and any other info, whatever...  - about the interface(s) it has etc that would be cool... :cheers:
regards.
FishBone_
  • Last login:December 16, 2016, 10:39:35 am
Re: Howler information request
« Reply #1 on: December 16, 2016, 10:39:35 am »
Working on setting up my first arcade-machine at the moment, and bought the howler from the kickstarter.
Setting it up with RetroPie i soon noticed the problem with support for the howler.
Found your RGB commander, and was hoping i could use it, but noticed the missing howler-support.
Not sure if you'll see this, but according to https://github.com/Mokosha/libhowler i believe the vendor id is 03eb  (Atmel Corp.)
Not so used to Linux, but I get the same result when i run the commands, and that driver works.
If you need me to do anything to test i'd be happy to help you :)
headkaze
  • 0x2b|~0x2b?
« Reply #2 on: December 16, 2016, 12:24:18 pm »
I wouldn't bother adding support as they appear to no longer manufacture them.
