Author Topic: Vertical games on horizontal monitor running in 480i  (Read 3747 times)
Jonny G
  • Last login:March 04, 2024, 05:59:46 pm
« on: February 21, 2016, 03:45:22 pm »
After trying to work out why Frogger is running so slowly whilst testing out the framedelay option, I've found the only way to get it to full speed is to enable triplebuffer and syncrefresh in mame.ini
However looking at the machine info it shows that it's running in 2560 x 480i @ 60.606Hz, 15.788
(while we're here, I haven't disabled any of the info screens in mame.ini at boot but im still not seeing them upon loading a game, I'm having to go into the tab menu and look in machine info. How do I revert to seeing them on boot?)
I'm running an HD4850 (Atom Flashed) under Win7 on a Hantarex MTC9000, I followed Calamity's guide on setup and installation of super resolutions for HD4xxx cards which seems fine on all horiz games.
I'm presuming I've done something wrong for vertical games to be displaying at 480i haven't I? Here's my current mame.ini
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               1
sleep                     0
speed                     1.0
refreshspeed              1
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.50
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
console                   0
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   arcade_15
orientation               horizontal
connector                 auto
interlace                 1
doublescan                1
cleanstretch              2
changeres                 1
powerstrip                0
lock_system_modes         1
lock_unsupported_modes    1
refresh_dont_care         0
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                15625-16670, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.160, 1.056, 0, 0, 192, 288, 448, 576
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
multithreading            1
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     d3d
numscreens                1
window                    0
maximize                  1
keepaspect                1
unevenstretch             0
waitvsync                 0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                2560x0
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    0
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
# WINDOWS PERFORMANCE OPTIONS
priority                  1
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
curvature                 0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   1.0,0.0
converge_x                0.25,0.00,-0.25
converge_y                0.0,0.25,-0.25
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.5
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.25
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.04
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.02
bloom_lvl9_weight         0.01
bloom_lvl10_weight        0.01
# FULL SCREEN OPTIONS
triplebuffer              1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
EDIT: Just checked 1942 rev b and it's running at 2560 x 256p @58.484Hz, 15.200kHz. Is this the closest I'm going to get to 256x224 @60Hz on my setup?
EDIT 2: This is weird, I've just made a frogger.ini and saved it in the ini folder. Tested it to make sure it affects the game by setting "ror 1" and it does. However if I set "syncrefresh 0" in mame.ini then set "syncrefresh 1" in frogger ini, the game starts running really slowly again. What am I missing?
« Last Edit: February 21, 2016, 04:05:15 pm by Jonny G »
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 03:43:51 am
  • Quote me with care
Re: Vertical games on horizontal monitor running in 480i
« Reply #1 on: February 21, 2016, 04:17:45 pm »
Several issues going on.
Frogger & Galaxian use the same driver, previously there was a hack in GM to make those run at 256p when rotated. This hack was removed since 0.169, since users have been complaining about it. MAME reports emulates as 768x224 (this is correct), so to run them on a horizontal monitor you either need to use interlace or force 256p in an ini file (which probably will result in scaling artifacts anyway).
Interlaced modes run at half speed for the HD 4xxx cards. You can "fix" it by forcing positive sync in a custom crt_range (do a search in the pinned threads), but this won't work with most arcade monitors.
Frame delay should fix this by the way, so I'm not sure what's going on (you're missing the log like everyone else these days).
Steps to create a log:
Jonny G
« Reply #2 on: February 21, 2016, 04:39:27 pm »
Thanks Calamity, i'll get a log up tomorrow, was just sneaking 5 minutes with the cab before bed! Would I force 256p in the frogger.ini by setting "resolution 2560x256"?
« Last Edit: February 21, 2016, 04:41:29 pm by Jonny G »
Jonny G
« Reply #3 on: February 23, 2016, 04:36:14 am »
Decided I'll get an HD 5450 and see how that goes.
Jonny G
« Reply #4 on: February 23, 2016, 06:27:19 pm »
OK got myself an HD5450 and all installed fine with super resolutions. Frogger is still running in 480i as expected but seems to now be at full speed without special edits and frame delay. I made a log anyway, does this all look OK to you?
Code: [Select]
SwitchRes: v0.015l, Monitor: custom, Orientation: horizontal, Modeline generation: enabled
SwitchRes: Monitor range 15625.00-16200.00,49.50-65.00,2.000,4.700,8.000,0.064,0.192,1.024,0,0,192,288,448,576
SwitchRes: \\.\DISPLAY10: ATI Radeon HD 5450 (CRT Emudriver - WDDM v1.20) (PCI\VEN_1002&DEV_68F9&SUBSYS_04731043&REV_00)
SwitchRes: Device key: System\CurrentControlSet\Control\Video\{4991700E-D873-4F9C-8784-F193AD37CCE6}\0000
ATI/AMD ADL init
ADL functions retrieved successfully.
Switchres: Searching for custom video modes...
Switchres: [  1]  640x 480 @ 30* : ATI ADL timing "640x480_30 15.685000KHz 59.980881Hz" 13.050000 640 664 728 832 480 483 489 523 interlace  -hsync -vsync
Switchres: [  2]  640x 480 @ 60 : ATI ADL timing "640x480_60 15.685000KHz 59.980881Hz" 13.050000 640 664 728 832 480 483 489 523 interlace  -hsync -vsync
Switchres: [  3]  720x 480 @ 60 : system mode
Switchres: [  4] 2560x 240 @ 60 : ATI ADL timing "2560x240_60 15.661000KHz 60.003830Hz" 52.120000 2560 2664 2912 3328 240 242 245 261   -hsync -vsync
Switchres: [  5] 2560x 248 @ 60 : ATI ADL timing "2560x248_60 16.139000KHz 59.996281Hz" 54.230000 2560 2672 2928 3360 248 250 253 269   -hsync -vsync
Switchres: [  6] 2560x 256 @ 58 : ATI ADL timing "2560x256_58 16.199000KHz 58.480145Hz" 54.430000 2560 2672 2928 3360 256 258 261 277   -hsync -vsync
Switchres: [  7] 2560x 264 @ 57 : ATI ADL timing "2560x264_57 16.199000KHz 56.838596Hz" 54.430000 2560 2672 2928 3360 264 266 269 285   -hsync -vsync
Switchres: [  8] 2560x 272 @ 55 : ATI ADL timing "2560x272_55 16.199000KHz 55.286690Hz" 54.430000 2560 2672 2928 3360 272 274 277 293   -hsync -vsync
Switchres: [  9] 2560x 280 @ 54 : ATI ADL timing "2560x280_54 16.199000KHz 53.817276Hz" 54.430000 2560 2672 2928 3360 280 282 285 301   -hsync -vsync
Switchres: [ 10] 2560x 288 @ 52 : ATI ADL timing "2560x288_52 16.199000KHz 52.423946Hz" 54.430000 2560 2672 2928 3360 288 290 293 309   -hsync -vsync
Switchres: [ 11] 2560x 448 @ 60 : ATI ADL timing "2560x448_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 448 467 473 523 interlace  -hsync -vsync
Switchres: [ 12] 2560x 464 @ 60 : ATI ADL timing "2560x464_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 464 475 481 523 interlace  -hsync -vsync
Switchres: [ 13] 2560x 480 @ 60 : ATI ADL timing "2560x480_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 480 483 489 523 interlace  -hsync -vsync
Switchres: [ 14] 2560x 496 @ 60 : ATI ADL timing "2560x496_60 16.169000KHz 59.996288Hz" 54.330000 2560 2672 2928 3360 496 499 505 539 interlace  -hsync -vsync
Switchres: [ 15] 2560x 512 @ 58 : ATI ADL timing "2560x512_58 16.229000KHz 58.482883Hz" 54.660000 2560 2672 2928 3368 512 515 521 555 interlace  -hsync -vsync
Switchres: [ 16] 2560x 544 @ 55 : ATI ADL timing "2560x544_55 16.226000KHz 55.284496Hz" 54.650000 2560 2672 2928 3368 544 547 553 587 interlace  -hsync -vsync
Switchres: [ 17] 2560x 560 @ 54 : ATI ADL timing "2560x560_54 16.226000KHz 53.817577Hz" 54.650000 2560 2672 2928 3368 560 563 569 603 interlace  -hsync -vsync
SwitchRes: Found 16 custom of 17 active video modes
SwitchRes: -resolution was forced as 2560x0
SwitchRes: Entering switchres_modeline_setup
SwitchRes: v0.015l:[frogger] Calculating best video mode for 224x768@60.606060 orientation: rotated
SwitchRes: [ 640]x[ 480]_[30=59.980881Hz] - locked
SwitchRes: [ 640]x[ 480]_(60=59.980881Hz) - locked
SwitchRes: [ 720]x[ 480]_[60=60.000000Hz] - locked
SwitchRes: [2560]x[ 240]_(60=60.003830Hz)
   rng(0): 2560 x 240_60.606060p 15.757576 [fract] scale(6, 1, 1) diff(6.67, 0.00, 0.0000) ratio(11.429, 0.313)
SwitchRes: [2560]x[ 248]_(60=59.996281Hz)
   rng(0): 2560 x 248_60.223049p 16.200000 [fract] scale(6, 1, 1) diff(6.67, 0.00, -0.3830) ratio(11.429, 0.323)
SwitchRes: [2560]x[ 256]_(58=58.480145Hz)
   rng(0): 2560 x 256_58.483753p 16.200000 [fract] scale(6, 1, 1) diff(6.67, 0.00, -2.1223) ratio(11.429, 0.333)
SwitchRes: [2560]x[ 264]_(57=56.838596Hz)
   rng(0): 2560 x 264_56.842106p 16.200000 [fract] scale(6, 1, 1) diff(6.67, 0.00, -3.7640) ratio(11.429, 0.344)
SwitchRes: [2560]x[ 272]_(55=55.286690Hz)
   rng(0): 2560 x 272_55.290104p 16.200000 [fract] scale(6, 1, 1) diff(6.67, 0.00, -5.3160) ratio(11.429, 0.354)
SwitchRes: [2560]x[ 280]_(54=53.817276Hz)
   rng(0): 2560 x 280_53.820599p 16.200000 [fract] scale(6, 1, 1) diff(6.67, 0.00, -6.7855) ratio(11.429, 0.365)
SwitchRes: [2560]x[ 288]_(52=52.423946Hz)
   rng(0): 2560 x 288_52.427185p 16.200000 [fract] scale(6, 1, 1) diff(6.67, 0.00, -8.1789) ratio(11.429, 0.375)
SwitchRes: [2560]x[ 448]_(60=60.003822Hz)
   rng(0): 2560 x 448_60.606060i 15.666667 [fract] scale(6, 1, 1) diff(6.67, 0.00, 0.0000) ratio(11.429, 0.583)
SwitchRes: [2560]x[ 464]_(60=60.003822Hz)
   rng(0): 2560 x 464_60.606060i 15.666667 [fract] scale(6, 1, 1) diff(6.67, 0.00, 0.0000) ratio(11.429, 0.604)
SwitchRes: [2560]x[ 480]_(60=60.003822Hz)
   rng(0): 2560 x 480_60.606060i 15.787879 [fract] scale(6, 1, 1) diff(6.67, 0.00, 0.0000) ratio(11.429, 0.625)
SwitchRes: [2560]x[ 496]_(60=59.996288Hz)
   rng(0): 2560 x 496_60.223049i 16.230112 [fract] scale(6, 1, 1) diff(6.67, 0.00, -0.3830) ratio(11.429, 0.646)
SwitchRes: [2560]x[ 512]_(58=58.482883Hz)
   rng(0): 2560 x 512_58.483753i 16.229242 [fract] scale(6, 1, 1) diff(6.67, 0.00, -2.1223) ratio(11.429, 0.667)
SwitchRes: [2560]x[ 544]_(55=55.284496Hz)
   rng(0): 2560 x 544_55.290104i 16.227645 [fract] scale(6, 1, 1) diff(6.67, 0.00, -5.3160) ratio(11.429, 0.708)
SwitchRes: [2560]x[ 560]_(54=53.817577Hz)
   rng(0): 2560 x 560_53.820599i 16.226910 [fract] scale(6, 1, 1) diff(6.67, 0.00, -6.7855) ratio(11.429, 0.729)
SwitchRes: [frogger] (1) vertical (224x768@60.606060)->(2560x480@60.606060)
SwitchRes: Modeline "2560x480_60 15.787879KHz 60.606060Hz" 52.668364 2560 2664 2912 3336 480 482 488 521 interlace  -hsync -vsync
Switchres: saving    ATI ADL timing "2560x480_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 480 483 489 523 interlace  -hsync -vsync
Switchres: updating  ATI ADL timing "2560x480_60 15.785000KHz 60.595009Hz" 52.660000 2560 2664 2912 3336 480 482 488 521 interlace  -hsync -vsync
SwitchRes: Setting option -rotate
SwitchRes: Setting option -noror
SwitchRes: Setting option -noautoror
SwitchRes: Setting option -norol
SwitchRes: Setting option -noautorol
SwitchRes: Setting option -noblack_frame_insertion
SwitchRes: Setting option -multithreading
SwitchRes: Setting option -notriplebuffer
SwitchRes: Setting option -syncrefresh
SwitchRes: Setting option -waitvsync
SwitchRes: Setting option -nohwstretch
SwitchRes: Setting option -keepaspect
SwitchRes: Setting option -filter
SwitchRes: Setting option -prescale 1
Video: Monitor 0000000005850F68 = "\\.\DISPLAY10" (primary)
Direct3D: Warning - Unable find any D3D9 DLLs; disabling post-effect rendering
Direct3D: Using Direct3D 9
window_proc: WM_NCACTIVATE
blit_lock = TRUE
Physical width 640, height 480
Direct3D: Configuring adapter #0 = ATI Radeon HD 5450 (CRT Emudriver - WDDM v1.20)
Direct3D: Adapter has Vendor ID: 1002 and Device ID: 68F9
Direct3D: Using dynamic textures
Direct3D: YUV format = RGB
Direct3D: Max texture size = 16384x16384
Direct3D: Device created at 2560x480
Direct3D: First scanline: 19, Last scanline: 499, Break scanline: 499, Delay scanline: -33
blit_unlock = TRUE
window_proc: WM_PAINT
Blitting thread created
winwindow_video_window_create: blit_lock = TRUE
Blitting thread started
RawInput: APIs detected
Input: Adding Mouse #0: HID-compliant mouse
Input: Adding Gun #0: HID-compliant mouse
Input: Adding Kbd #0: HID Keyboard Device
Input: Adding Kbd #1: HID Keyboard Device
Input: Adding Mouse #1: HID-compliant mouse
Input: Adding Gun #1: HID-compliant mouse
DirectInput: Using DirectInput 8
blit_lock = FALSE
window_proc: WM_PAINT:END
stream_buffer_size = 37888
DirectSound: Primary buffer: 48000 Hz, 16 bits, 2 channels
Region ':maincpu' created
Region ':audiocpu' created
Region ':gfx1' created
Region ':proms' created
Starting Frogger ':'
Optional shared pointer 'decrypted_opcodes' not found
Optional device 'ppi8255_2' not found
Optional device 'digitalker' not found
Optional device 'cclimber_audio:aysnd' not found
Optional device '8910.2' not found
Optional device '8910.1' not found
Optional device 'dac' not found
Optional device 'audio2' not found
  (missing dependencies; rescheduling)
Starting Z80 ':maincpu'
Starting gfxdecode ':gfxdecode'
Starting palette ':palette'
Starting Video Screen ':screen'
Optional device 'finder_dummy_tag' not found
Adjusting target speed to 98.5% (hw=60.00Hz, game=60.61Hz, adjusted=59.70Hz)
Starting Timer ':stars'
Starting Speaker ':mono'
Starting 8255 PPI ':ppi8255_0'
Starting 8255 PPI ':ppi8255_1'
Starting Z80 ':audiocpu'
Starting AY-3-8910A ':8910.0'
Starting DISCRETE ':konami'
Average speed: 99.98% (9 seconds)
Switchres: restoring ATI ADL timing "2560x480_60 15.691000KHz 60.003822Hz" 52.220000 2560 2664 2912 3328 480 483 489 523 interlace  -hsync -vsync
ATI/AMD ADL close
blit_lock = TRUE
window_proc: WM_DESTROY
blit_lock = TRUE
Blitting thread destroyed
and here's my mame.ini again...
Code: [Select]
readconfig                1
writeconfig               0
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
cfg_directory             cfg
input_directory           inp
state_directory           sta
diff_directory            diff
state
autosave                  0
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               1
sleep                     0
speed                     1.0
refreshspeed              1
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.25
effect                    none
antialias                 1
beam_width_min            1.0
beam_width_max            1.0
flicker                   0
samplerate                48000
samples                   1
volume                    0
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
natural                   0
coin_impulse              0
mouse_device              mouse
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ramsize
confirm_quit              0
ui_mouse                  0
autoboot_command
autoboot_delay            2
autoboot_script
console                   0
monitor                   custom
connector                 auto
interlace                 1
doublescan                1
cleanstretch              2
changeres                 1
powerstrip                0
lock_system_modes         1
refresh_dont_care         0
dotclock_min              0
frame_delay               0
vsync_offset              0
modeline                  auto
ps_timing                 auto
lcd_range                 auto
crt_range0                15625-16200, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
debugger                  auto
debugger_font             auto
watchdog                  0
multithreading            1
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     auto
numscreens                1
window                    0
maximize                  1
keepaspect                1
unevenstretch             0
waitvsync                 0
screen                    auto
aspect                    4:3
resolution                2560x0
view                      auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
switchres                 1
filter                    0
prescale                  1
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
# OSD SOUND OPTIONS
sound                     auto
audio_latency             2.0
priority                  1
profile                   0
menu                      0
hwstretch                 0
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_write
curvature                 0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   1.0,0.0
saturation                1.4
offset                    0.0,0.0,0.0
power                     0.8,0.8,0.8
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
bloom_blend_mode          0
bloom_scale               0.25
triplebuffer              0
global_inputs             0
dual_lightgun             0
Calamity
  • Moderator
  • Online Online
« Reply #5 on: February 24, 2016, 07:14:29 am »
Looks ok now :)
Jonny G
« Reply #6 on: February 24, 2016, 10:19:05 am »
You must be sick of me thanking you by now, but you know I appreciate you having a look to make sure things are as good as they can be.
