Author Topic: Unable to output video signal unless VGA monitor is connected during boot  (Read 2475 times)
BubbaMc
  • Last login:October 10, 2017, 05:46:00 am
Hi Guys,
I can only get a video signal from Windows 7 if an ordinary VGA monitor is connected when Windows starts up.
i.e. Booting with no monitor attached results in no video signal once Windows 7 desktop has appeared (I can hear the startup chime and connecting the monitor at this time results in no picture). The same behavior occurs when a 15khz monitor is connected.
However, booting with a VGA monitor attached results in picture when Windows starts, at which time connecting a 15khz monitor works.
Has anyone experienced this problem before? How can I boot the machine successfully with only a 15khz monitor connected?
Regular video card drivers do not give rise to this issue, only the CRTEmudriver. I.e I can boot with nothing connected, attaching a monitor after Windows starts results in a picture.
Sega Astro City/Nanao MS9
Dell Optiplex 960
Radeon HD4350
Windows 7 in Test Mode with CRTEmudriver
« Last Edit: February 20, 2016, 10:41:04 am by BubbaMc »
Calamity
  • Moderator
  • Last login:Today at 04:20:08 am
  • Quote me with care
Re: Unable to output video signal unless VGA monitor is connected during boot
« Reply #1 on: February 20, 2016, 02:06:36 pm »
This issue is fixed in CRT Emudriver 2.0. Follow this guide: http://geedorah.com/eiusdemmodi/forum/viewtopic.php?id=298
Steps to create a log:
BubbaMc
« Reply #2 on: February 20, 2016, 08:08:12 pm »
Thanks mate, I'll give that a try!
BubbaMc
« Reply #3 on: February 21, 2016, 05:21:27 am »
Everything worked up until executing mame with the -resolution 2560x0 -cleanstretch 2 options.
Toki launched in 640x480 interlaced.
Adding -resolution 2560x0 -cleanstretch 2 to mame.ini resulted in 640x480 interlaced also.
I could only get super resolutions to work by forcing one with ArcadeOSD, which works great except then I can't read anything on the Windows desktop
Any ideas why -resolution 2560x0 -cleanstretch 2 options wouldn't work?
BubbaMc
« Reply #4 on: February 21, 2016, 08:14:29 am »
I got it to work!
Problem was I had Nanao MS9 selected in Vmmaker. Changing the monitor to generic 15khz did the trick.
