Author Topic: Pc control panel to Dreamcast?  (Read 2633 times)
Negativecreep0
  • Last login:November 28, 2020, 10:59:49 am
« on: January 13, 2004, 07:42:11 pm »
Is there a converter that will properly convert my IPAC4 interface pc mame control panel and turn it into workable dreamcast controllers? for player one and two? or do i have to build a seperate control panel and switch it everytime i wanna play dreamcast on my cab
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:Pc control panel to Dreamcast?
« Reply #1 on: January 13, 2004, 08:38:56 pm »
Short answer is "no".
What you would do is install a set of molex connectors (or db25 or whatever connector preference you have) between your control panel and ipac.  Then hack 2 dreamcast controllers to the same type of connectors.
Then you just unplug the ipac from your control panel, and plug in the hacked controllers whenever you want to switch between systems.
TalkingOctopus
    • My Arcade
« Reply #2 on: January 13, 2004, 09:49:13 pm »
Go here for more information about attaching a Dreamcast to arcade controls:
http://members.cox.net/joysticks/
Negativecreep0
« Reply #3 on: January 14, 2004, 12:09:34 pm »
Thanks guys I have found a solution This might help you all, who don't want to make two seperate panels and switch them every time.
http://www.agoranet.es/~ddv/cabinet/controles2.htm
I am going to do that, and have the knob to switch between dc and mame extended to the outside of the control panel some how. that way no opening up or switching cables. What do you guys think any info or words of wisdom? By the way the page was in spanish i translated it in american using altavista translator.
Dave_K.
    • Arcade Fever
« Reply #4 on: January 14, 2004, 12:49:03 pm »
Sure, a switchbox would work fine (if you use db25's as your common connectors)...make sure you get the correct ribbon cable that has wires which go straight through (or build your own cable with connectors) as most DB25 cables has wires that cross.
But to tell you the truth, you will have to open your cab and reach inside anyway to turn on the Dreamcast and/or put in a game CD...so I don't think its going to buy you much more than a couple seconds in turn around time.  Also how are you going to switch the audio and video/monitor connections?  ;D  See you will have to reach inside anyway!  You also don't want to leave your Dreamcast powered on with the PC at the same time for extended periods of time inside the cab as it can overheat.
« Last Edit: January 14, 2004, 12:54:24 pm by Dave_K. »
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #5 on: January 14, 2004, 12:57:50 pm »
maybe dreamcast emulator on PC would be better? would just require some software work instead of hardware which is probably easier. i never used a DC emu though im not sure if you need to put the CD in the PC or what, might be something you should look into
"Owens is the ringleader in the ass hat circus"  D K
Reverend_Ken
  • Last login:July 01, 2004, 08:50:55 pm
« Reply #6 on: January 14, 2004, 12:58:13 pm »
what if...
i use connectors and a splitter, then send signals to the ipac AND the hacked controller all the time?
or should i use a switch between the connectors to send signals to only one at a time?
-k
TalkingOctopus
    • My Arcade
« Reply #7 on: January 14, 2004, 02:19:58 pm »
There is no dreamcast emulator that does a good job playing commericial games.
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #8 on: January 14, 2004, 03:32:13 pm »
i understand the controller hack, how would you get the video to go to the DC if youre using a arcade monitor with arcade VGA?
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
« Reply #9 on: January 14, 2004, 03:40:30 pm »
buy a DC vga box, and hack it so it outputs 15khz.  VERY EASY to do.  many of these have a switch for switching between a PC and the DC.  That takes care of both the video and audio for you.
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
Serpent
  • Last login:December 02, 2003, 03:34:39 am
« Reply #10 on: January 14, 2004, 05:39:03 pm »
I've built my control panels using PSX pad hacks, and I don't have and I wont have a PSX or a PS2 hehe. I have two PSX-PC usb adaptors and two PSX-Dreamcast adaptors. This way I can use my control panels with my PC and my Dreamcast. These adaptors work flawlessly! Actually, if you plan and wire the buttons correctly, you will have the same button layout as with the Dreamcast Arcade Stick, and it will work with all games with no need to remap or configure anything.
Dave_K.
    • Arcade Fever
« Reply #11 on: January 15, 2004, 12:51:51 am »
what if...
You don't want to have both connected at the same time or you will short out one or both system inputs.  A switfch box or only one plugged in at a time is your only option.
Negativecreep0
« Reply #12 on: January 15, 2004, 10:43:31 am »
my setups will be a dreamcast in the cab connected to vga box hacked to output 15hz tv mode!. VGA mode looks like ---steaming pile of meadow muffin--- for 2d fighting games that is why im doing that. It hooks up easy to my D9200 wells gardner monitor, then i will have the pc speakers split to go into the vga box so i can hear it. finally the only thing i will have to do is yes, go to the back of the cabinet and switch games and turn on the dc everytime i wanna play dc games. Not to big a problem. I plan on playing M vs Capcom 2 most of the time anyway so i wont be switching games that often.
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #13 on: January 15, 2004, 11:38:59 am »
are there any pages with DC hacking walkthroughs? I plan on doing what serpent did, with 2 hacked PSX pads with DC adapters. is there info out there on the VGA hacking?
Luxury
    • arcadeZERO
« Reply #14 on: January 15, 2004, 12:04:19 pm »
Click on Game Consoles on the left
