Author Topic: Where should this k7000 wire connect?  (Read 2079 times)
danielm7999
  • Last login:January 11, 2017, 02:01:48 pm
    • Daniel Mercer Art
« on: February 18, 2016, 01:59:09 am »
This  chassis wire was disconnected from its origin when I bought the game. Any idea where the unconnected end should be installed exactly? It seems to be a ground wire...but I dont see any part or place that seems appropriate for it.
- Daniel Mercer Art
danielm7999
    • Daniel Mercer Art
Re: Where should this k7000 wire connect?
« Reply #1 on: February 18, 2016, 02:09:53 am »
Oh damn, could it be this spot on the neck board? Neck boards have 2 ground wires connected to them, right? Looks like a wire was broken off at the base of the board.
What kinda damage would that have done if the game was run without this wire grounded?
- Daniel Mercer Art
grantspain
« Reply #2 on: February 18, 2016, 03:08:02 am »
no damage would be done
danielm7999
    • Daniel Mercer Art
« Reply #3 on: February 18, 2016, 02:41:47 pm »
Also, upon close inspection of the rubber anode cup on my new flyback Ive noticed there is a very small pinhole that goes through the rubber. Its barely noticeable but Im wondering if this will pose a problem with arcs flying out? Surely not, right??
- Daniel Mercer Art
« Reply #4 on: February 18, 2016, 03:31:50 pm »
Supremely unlikely. Calm your tits by putting a small piece of electrical tape on it.
danielm7999
    • Daniel Mercer Art
« Reply #5 on: February 18, 2016, 03:39:23 pm »
Thanks bro, I figured, just wanted to be sure. Commencing tit calming now!  :lol
- Daniel Mercer Art
Alaska
  • Last login:January 02, 2025, 06:25:46 pm
  • Fight inflation not farmers
« Reply #6 on: February 18, 2016, 06:29:53 pm »
That is exactly where the wire should be soldered to. There is a reading of 8K I believe on the neck board where that wire should attach. The grounding wire is then bolted to your chassis next the flyback. Visit this forum for additional photos and help http://forum.arcadecontrols.com/index.php/topic,148062.0.html
If you turned the game on without that wire connected then the tube would not turn on. No damage will have occurred as a result. I did the same thing  ;)
danielm7999
    • Daniel Mercer Art
« Reply #7 on: February 18, 2016, 06:31:58 pm »
Great, thanks buddy, I appreciate it! I soldered it to the board and all is working (besides an unrelated issue with a dim monitor). Thanks!
- Daniel Mercer Art
