Author Topic: Control panel CPO apply over material  (Read 1640 times)
majoly
  • Last login:February 11, 2016, 03:51:11 pm
« on: February 11, 2016, 11:01:55 am »
I was planning on ordering from gameongrafix. I would paste the CPO over a 1/8" thick plexi.
Would there be a reason why I should not do that?
If no got a better idea?
Re: Control panel CPO apply over material
« Reply #1 on: February 11, 2016, 12:22:30 pm »
what?
you put the CPO on the CP, and if the CPO doesnt have polycarb coating you put plexiglass/persiplex over top of it.
majoly
« Reply #2 on: February 11, 2016, 01:14:31 pm »
MDF is CP, over my CP I would put plexi, and over my plexi i would put the CPO
DaveMMR
« Reply #3 on: February 11, 2016, 01:20:35 pm »
The overlay goes on the wood/metal - the plexi goes above it all.   The plexi's purpose is to protect the artwork typically. If you put the overlay on the plexi you're defeating its purpose.
majoly
« Reply #4 on: February 11, 2016, 01:28:31 pm »
my reason on doing that is for physical limitations.
I need to apply my CPO on a 1/8" thick surface.
And from what Ive been told, game on grafix work wont require me to put a plexi over the CPO.
metal is the best option I guess?
DaveMMR
« Reply #5 on: February 11, 2016, 01:46:48 pm »
May I ask why the surface needs to be 1/8"?  I'm not following. I don't think the overlay cares about thinkness.
majoly
« Reply #6 on: February 11, 2016, 03:28:21 pm »
For my CP to be flat with the frame, the surface where I apply the CPO, to sit on all sides has to be 1/8 thick. Anything thicker will make the surface not even with the rest of the frame.
So from all choices I have
Plywood 1/8, plexi 1/8, metal 1/8, is plexi a bad choice or not to apply a CPO over
DaveMMR
« Reply #7 on: February 11, 2016, 04:24:29 pm »
I suppose you can apply it to the plexi if that's what you like - but if you're cutting holes wood would be easier.  (So long as you have support underneath. That's thin wood.)
Plexi/lexan, typically, is used as a "protector".  But if you have a reason to do it then it's fine - just not the usual way of using it which is why we were a tad confused.
