Author Topic: 3 switches 4 position how can i do?  (Read 3307 times)
eldiego
  • Last login:June 07, 2024, 11:18:22 pm
  • I do my daytona twin, arcade 4 players and vpin!!!
« on: February 06, 2016, 12:57:18 pm »
Hi all, i bought a daytona cabinet twin without any pcb, only with monitor chasis and control panel (gear and steering Wheel and motors), i am thinkin use my pc steering Wheel hacked with the daytona, but i don t know how to resolve the issue of the 3 switches of the  4 gear shift using a logitech steering wheel or other like this. Maybe anyone can help me.
Thanks you!
  • Moderator
  • Last login:Today at 10:39:28 am
Re: 3 switches 4 position how can i do?
« Reply #1 on: February 06, 2016, 01:30:58 pm »
skip to the last couple posts for the best solution:
http://forum.arcadecontrols.com/index.php/topic,106709.msg1130503.html#msg1130503
Easiest method would be just to couple that with a keyboard encoder rather than trying to hack it into a Logitech wheel.
Just about all games and emulators support both a controller and a keyboard simultaneously.  (I can't think of any that don't)
It also depends on which Logitech wheel you're using.
The Momo I hacked posted as different buttons depending on which of two ground wires were used.
I figured out what was needed to replace a G27 shifter with regular switches in this thread, but never got around to actually building it.
http://forum.arcadecontrols.com/index.php/topic,134988.msg1393116.html#msg1393116
EDIT:  This should be added to the driving cab info thread.  I'll try to do a better job of explaining the options when I get around to adding it there.
« Last Edit: February 06, 2016, 02:48:01 pm by BadMouth »
eldiego
« Reply #2 on: February 07, 2016, 11:57:08 am »
Thanks you!
In reply to Badmouth, Hiljak say
"FYI, the above is not the correct pinout.
See here for basic pinout from chip data sheet.
http://circuits.datasheetdir.com/255/74LS138-pinout.jpg"
At the end, wich is the correct?
  • Moderator
« Reply #3 on: February 07, 2016, 12:26:42 pm »
Thanks you!
I haven't personally done this, but I would assume the one at the end is correct.
I'd trust the manufacturer's datasheet or at least start out believing it most likely to be correct.
terminator2k2
  • Last login:February 10, 2025, 05:35:27 pm
« Reply #4 on: February 07, 2016, 03:52:50 pm »
eldiego
« Reply #5 on: February 07, 2016, 10:06:20 pm »
thanks
