Author Topic: Help Adjusting Mini-Flightstick (GGG Night Mission)  (Read 1902 times)
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« on: February 01, 2016, 09:12:56 pm »
I recently got a pair of Night Mission Mini-Flightsticks from GroovyGameGear.  I initially had trouble hitting the diagonals so I bent the switch levers in quite a bit.  The diagonals work fine now.  There are still 2 issues:
1. The joysticks feel very loose.  The first picture demonstrates how much I can move the stick before they click the switches.  Very little effort is required to move them like this.
2. Occassionally, the stick will get stuck in a direction and won't return unless I push it back (very little force). I can alleviate the problem but lessening the amount of bend I have on the switches but then I run into the diagonal issue again.
Any thoughts on how to improve them?
« Last Edit: February 04, 2016, 10:44:01 am by DarthMarino »
RandyT
  • Last login:December 17, 2025, 10:08:10 am
    • GroovyGameGear.com
Re: Help Adjusting Mini-Flightstick (GGG Night Mission)
« Reply #1 on: February 02, 2016, 02:24:00 pm »
First question:  Did you replace all of the parts of the stick correctly after removing them to install the unit?  These sticks have almost no play, and a strong return to center, so if you have that kind of slop, I'm guessing something is missing, or installed incorrectly.
DarthMarino
« Reply #2 on: February 02, 2016, 03:01:47 pm »
I'm hoping that's the case.  Everything is installed in this order from top to bottom:
Dust Washer
Pivot
Main Housing
Spring Stopper (larger diameter on top)
Spring (larger diameter on top)
Actuator (larger diameter on top)
E-clip
DarthMarino
« Reply #3 on: February 03, 2016, 08:45:35 pm »
I flipped the spring and it feels a bit better but I am still having an issue with the diagonals.  I think the switches are just too hard to push  in.
« Last Edit: February 04, 2016, 01:19:30 pm by DarthMarino »
RandyT
« Reply #4 on: February 04, 2016, 03:36:30 pm »
Is the hole in the panel too small?  If you have interference with the throw, it might be limiting your diagonals.  I don't see that kind of issue with any of the sticks here.
DarthMarino
« Reply #5 on: February 05, 2016, 10:03:46 am »
The shafts aren't hitting the sides. I took one out of the panel to make sure but it feels the same way. I just think the switches are a bit tighter than I'm used to.  I may replace them at some point but they feel pretty good now.
